Hh.exe - ordinal not found - Computers & Internet
How do i solve an error about the ordinal 231 missing in the dynamic link library ietutil.dll.
I would run a registry cleaning programme. There are lots of free ones out there that work.
Nov 05, 2014 | Computers & Internet
HH error code? on magic chef mcbc580dbt
I, too, have just seen (late June 2013) the "HH" code on my Magic Chef wine cooler (and it is running too cold and I can't reset the temperature). Have you found a solution since your posting of about 1 year ago?
Jun 27, 2012 | Magic Chef MCWC30MCG Compact Wine Cooler
Ordinal 5372 can't be found in dynamic library xlive.dll how do I fix this problem. thanks
Ordinal 5372 can't be found in dynamic library xlive.dll how do FIX THIS PROBLEM
Jul 05, 2011 | Computers & Internet
I have a Garmin 250W. Is it possible to search and target a location by latitude and longitude rather than post code in France
You can definitely route using co-ordinates, this search option can found under "Where To?" it may be located a couple of pages down so go through the pages to see "Co-Ordinates" from here you would be able to enter your latitude and longitude.
Hope this helps!
Apr 26, 2011 | Garmin nuvi 250W GPS Receiver
I have Yahoo! Messenger version 11. The first time Y! M go good, perfect. But the 2th time apair the mesage: ?YahooMessenger.exe - Ordinal Not Found?. I download all the versions of Yahoo! Messenger and...
dear frnd,
"""The ordinal 17 could not be located in the dynamic link library...
Comment by scadasw (see profile) - August 30, 2005
Yahoo! Messenger with voice (7,0,0,426) was compiled with an older version of MAPI32.DLL library. If you use MAPI32.DLL ver. 1.0.2536.0 (very recent: 1999!) it works."""
Above was quoted from a website. Um, is that same version you have now?
This might also help, but first, make note of exactly where your good, working mapi32.dll file is located, and make a copy of it to have for a quick replacement...in case fixmapi.exe puts a not-compatible version back but I dont think it should....
run this file located in c:\windows\system32\fixmapi.exe
You do want to sign out of and be sure ypager is not running before trying fixmapi.
Here is the Microsoft info on what fixmapi.exe does: http://support.microsoft.com/?kbid=228457
Note what it says about if you are using Microsoft Outlook (not same as Outlook Express)
Dec 26, 2010 | Computers & Internet
Acer Aspire One error when trying to connect to internet: iexplore.exe - Ordinal Not Found The ordinal 650 could not be located in the dynamic link library iertutil.dll. Sometimes the number (650) is...
1. Install another browser: For e.g. FLOCK
2. Are you able to browse?
If so then we have isolated the problem to Internet Explorer:
1. Which version of IE are you using?
Either way:
1. uninstall it completely
2. Download and reinstall the latest version of IE
And just in case please do a VIRUS SCAN:
1. DiskClean up of C drive (always do this before a virus scan)
2. Total Virus Scan of Hard Disk (make sure Virus application is updated first)
About System Restore:
Windows does not allow you do to a restore from before it happened because it did not save any restore date from prior to (perhaps system restore is not enabled so be sure to double check this); therefore:
1. You're going to have to try to fix this isolated problem manually
OR
2. RESTORE to factory settings: take all ur data off and restore to factory settings and then put ur data back thereafter.
CAH
CAH
Mar 16, 2010 | Acer Aspire One Netbook 8.9" Notebook
Hi, i got a eMachines el1200-07w preloaded with vista basic. i'm somewhat new to modding the aero interface (themes, bootscreens,visual styles/msstyles) on vista. Problem?: i was installing a Windows 7...
Regarding on your problem, User32.dll is a Dynamic-link library (DLL) that implements the Windows User API Client Library. It is a core file for several versions of the Microsoft Windows operating system and it is very important in any Windows Operating System. If this file is damaged or deleted, the operating system will not work. Ordinal 2000 is part of the dynamic link library or DLL in USER32.dll it usually refers to the module and code under USER32.dll.
My recommendation: Please check first the installer you have downloaded if it is compatible with your current operating system. Make sure that the program you want to install are supported with your OS to prevent this problem again.
Thanks
Sep 05, 2009 | Microsoft Windows Vista Home Basic Edition
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
