Question about Casio Pathfinder PAG80-1V Watch
Casio pathfinder pag 80 I was in the WT (world time) mode going through the different Cities and setting them in either DST or nonDST, when I was almost finished the watch suddenly began showin OP EN
E) mode going through the different Cities and setting them in either DST or nonDST, when I was almost finished the watch suddenly began showin OP EN in the upper display area and now it is stuck. I can't get any function back to work. Why?
  • 73 Answers
SOURCE: Repliciment wrist gand for Casio Pathfinder
you can go to this link and in the upper right corner type in the model number not the module number (there are instructions for finding the model number if you don't know it) I found a band for a watch that is over 8 years old on here.
http://www.fsiwebs.com/shopcart3/SC_ProdList.asp?
Posted on Jan 07, 2008
  • 3 Answers
SOURCE: CASIO PAG-40 Keeps good time but buttons stopped working
open the backside.
probably the light switch contact at the six side of the watch (attached to the steel mainframe) may have contact with the electronic cirquit
Posted on Mar 06, 2008
SOURCE: I have a Casio Data
Press the lower left button and hold it there. It will stop the display cycling mode
Posted on Aug 06, 2008
cmcduncand
  • 714 Answers
SOURCE: My Casio Pathfinder PAG-50 when I go into compass
http://world.casio.com/wat/download/en/manual/
Use the four numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps.
R/
David
Posted on Feb 09, 2010
escapement
  • 2334 Answers
SOURCE: I have a Casio Pathfinder PAG-70 that reads
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all CASIO watch manuals.Rate me, please
Posted on Mar 15, 2010
Summertime reset for casio watch stl-s100m
Go to WT(World Time) function (down-left button) ,find your actual time city and choose, by pressing the upper-left (SET) button for 2-3 seconds, between DST (Summertime) and Blank (Normal Time).
Apr 08, 2017 | Casio Watches
My casio wave ceptor 3054 wv-58a is not working right. I live in Phoenix,Arizona and we don't observe daylight savings time and when I went to take it out of dst mode the day of the week is in a foreign...
The correct time zone setting for Arizona on this watch is YEA (Edmonton International Airport). Hold the adjust button for several seconds until the three code time zone starts flashing, then use the forward/back buttons to select YEA.You need to keep the DST mode off, so press mode once, then the forward button to select off in the DST select screen. From there, you can then press mode to manually adjust each time/date area individually. The final thing that you can adjust is the language, choose ENG for english. Press adjust to keep your settings, and you should be good to go.
Mar 14, 2011 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Daylight savings time change casio atomic watch has not changed is there a way to change it manually
An example for G-shock: I searched for casio g-shock manual and got this: http://world.casio.com/wat/download/en/manual/
You enter model from back of watch and it gives you a searchable PDF manual.
For mine, model 2638 (and likely most G-shocks), you press and hold the upper left (Adjust) button until the City Code flashes. You then press the lower left (Mode) to enter DST mode then press the lower right (Receive) as it cycles through On, Off and Auto.
On moves 1 hour forward, Off moves 1 hour back. After you select, you press the upper left button (Adjust) twice and it's set. I would not pick Auto anymore as my watch is still set to the original DST days which were changed in the US years ago and no longer match, I don't believe the DST days used can be changed by the user and I don't believe Auto receive adjusts for DST.
Mar 13, 2011 | Casio Watches
Cannot change to summer time for UK
Try pressing the mode button until you come to a message that says something like "DST" and experiment with the other buttons to turn it from "OFF" to "ON".
Mar 29, 2010 | Watches
I am unable to set the time because the function button (top left over the 10 O'clock position. I had a local watchmaker tell me the button moves, but it has no effect on the electronics. Casio has an...
I have a different model of Casio but I suspect that the operation is the same.
To change DST you should press the button (8 O'clock) to give world time. This should be showing your city.
You should then use the button you mention to toggle between DST & ST. (ST is no DST display!).
If this does not work and you wish to read through instructions for your particular model, then go to casio.com, select "support", and under "technical support" select "manuals", then "watches", agree terms, and the select "watch manuals archive", insert the required number off the back of your watch and download the instructions.
Jan 28, 2010 | Casio Sea-Pathfinder SPF40-1V Wrist Watch
My Casio Pathfinder PAG-50 when I go into compass mode shows ---* is there a way to set the compass?
R/
David
Jan 01, 2010 | Casio Pathfinder Triple Sensor PAG501V...
Echo drive skyhawk,My watch's time zone is always one hour behind
You posted this in January, which is not during daylight savings time. The SMT setting doesn't turn on automatic DST switching for a particular timezone; rather, it is a manual override to adjust timezones to DST when it is actually active. There is no automatic DST adjustment for this watch (according to their FAQ). Turn SMT to OF for all timezones during winter months, and ON for applicable timezones during SuMmer Time (SMT).
Jan 17, 2009 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
How do I get the wave ceptor to come on ?Casio-2688
Try Googling (casio)(2688)(manual) without parens for instructions.
May 08, 2017 | Casio Watches
open the backside.
Jan 13, 2008 | Casio PRG-40T-7 Pathfinder
Casio Pathfinder PAG80-1V Watch Logo
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Jimmy Accardi
Are you a Casio Watch Expert? Answer questions, earn points and help others
