Question about EnGenius ESR1221N2 Dual Band Wireless N Router
Engenius esr1221n2 needs to be reset after every power outage. How to make it work again without reseting/rebooting every time?
    New Friend:
There's no way to not have to reset after the power goes out, I have the same problem, but if you just unplug your router for 30 seconds, then plug back in, it should work, listen to the ticks of the clock on your wall, if you have one.
Posted on Nov 20, 2013
Dishwasher does not start
I had this problem and solved it by merely switching the associated circuit breaker off and on again. Something of a "hard reboot." Annoying ... and ... if it happens repeatedly (tonight was the first time), someting I will pursue fixing while hte d/w is still under warrwentey (It was purchased/installed less than three months ago.)
Dec 12, 2012 | Kenmore 18" Built-In Dishwasher -...
DIR-815 Signal strength excellent but no internet
Possibly the power outage caused your modem to reset. The wired connection would still work. first thing I would try is to reset the modem with the reset button, login to the management console and put in your network name and password again.
Dec 21, 2017 | ASI Computers & Internet
Power outage unable to connect wirelessly e1000
Make sure power is back up. Check both ISP modem and router indicator lights are normal. Test ISP connection with cable. If all is still OK then use the reset button in the back of the router.
FYI - ISP modem might also have a reset. I had to this for TV even though everything said OK.
Aug 29, 2012 | Cisco Linksys E1000 WirelessN Broadband...
After power outage I Can't connect without bypassing router
If you can connect directly then, the problem is the wrt54g router. Possible problems:
1) Power Outage damaged the router
2) Power Outage reseted the router
For the second scenario, you should got to the browser and type: http://192.168.1.1/ and check whether you can enter or not. If not, you need to configure the gateway IP on your PC to 192.168.1.1
May 25, 2009 | Linksys Wireless-G WRT54G Router
How do i reset my engenius senao eoc 3220 outdoor radio
back side one reset button is there pull out the power cable then pull in that same time you have to press the reset button for three to five sec then all lied's blink all to gather then your default ip address is came then you again configure at default ip
Apr 15, 2009 | EnGenius EOC-3220 (EOC3220)
Whirlpool electric range won't work
We read on another site that sometimes an electical surge messes something up and that if you unplug the range for a few minutes it will reset. So we unplugged our range and when we plugged it in again it worked fine.
Mar 24, 2009 | Whirlpool RF368 Electric Kitchen Range
Resetting EnGenius EOC 3610
Dear Venmattey,
please follow these steps, it works:
1. Connect the EOC-3610 to your computer with a null modem serial cable.
2.Start a HyperTerminal session: Click Start and then select Programs-> Accessories -> Communications -> HyperTerminal.
3. After the HyperTerminal window appears:
a. Give this new connection a name. Ex: EOC-3610.
b. Select correct COM port. Ex:COM1.
c.Set baud rate as "38400", data bits "8", parity "none", stop bits "1",and flow control as "None". Then press “OK” to bring up theHyperTerminal window.
d. Unplug the power on the POE injector and wait 5 seconds then plug the power back in.
4. Wait until the "#" is displayed in the HyperTerminal window.
5. Type "flash reset", then hit enter.
6. Type "reboot", then hit enter. After the device reboots, all settings will be at factory default.
NEW: Keenan Systems has written a software that will soft reset the 3610 series back to factory reset. Thisfree software is provided "AS IS" by Keenan Systems and is notsupported or guaranteed by EnGenius Technologies. Use at your own risk.
Be Happy Always
Regards
Dec 03, 2008 | EnGenius Computers & Internet
Restart problem
You may have to hard reset it by unplugging the cord itself and plugging it back in. When power comes back during power shortage, there may be a power surge rushing to the modem/router causing it to behave abnormally. Also, you may want to put power surge protection on it as it may damage you modem/router as i did mine.
Sep 17, 2008 | Acer Aspire 5100 Notebook
Restart problem
eu não esto consegundo estala no meu pc pressizo de alsilio por favor
Sep 07, 2008 | Belkin (F5D7230-4) Router (587009)
Maytag washer not reset after power outage
The magnetic switch was stuck due to power outage / contactor are spark connect the contactor stuck together .Magnetic switch to replace.
Jan 09, 2008 | Maytag Atlantis MAV6000 Top Load Washer
EnGenius ESR1221N2 Dual Band Wireless N Router Logo
94 people viewed this question
Top EnGenius Computers & Internet Experts
rdarell
Level 1 Expert
Karen Gibson
Level 1 Expert
Are you an EnGenius Computer and Internet Expert? Answer questions, earn points and help others
