Question about Philips Consumer Electronics Philips 32 Pfl3506/f7 Widescreen Lcd Tv,
Philips 32PFL3506/F7 shut off after two seconds of power on
When I disconnect the flex from the converter to the assembly LCD the screen brights white but at the moment to connect it again it shut off
Philips 42PFL3704D/F7. Why does it keep restarting?
Philips 42pfl3704d/f7 power reset when HDMI, USB, or cable ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
Oct 9, 2012 - 5 posts - ‎2 authors
Philips 42pfl3704d/f7 power reset when HDMI, USB, or cable attached ... or Cable TV to unit the power resets, philips screen comes on and keeps on resetting. ... I tried a cable to the tv without the box and I do get picture.
Philips 42PFL3704D/F7 42-Inch 1080p LCD HDTV
www.amazon.com/Philips-42PFL3704D-F7.../B001LP...
Amazon.com, Inc.
Rating: 3.3 - ‎50 reviews
Amazon.com: Philips 42PFL3704D/F7 42-Inch 1080p LCD HDTV: Electronics. ... Will do all I can to prevent others from getting ripped off by Philips. ... came up every few weeks and would take an hour or so of reset before working properly.
Visit the support page for your Philips LCD TV 42PFL3704D ...
www.philips.ca > philips > Televisions > 3000 series
PhilipsFind support for your LCD TV 42PFL3704D/F7. ... How do I output sound from myPhilips TV to external audio devices such as Home Theaters, Soundbars, AV ...
42" Philips 42PFL3704D/F7 LCD TV WON'T COME ON - A
Dec 29, 2015 | Televison & Video
No power coming for Philips LCD tv
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and precious time.
Aug 24, 2014 | Philips Consumer Electronics Philips 32"...
Philips 47pfl7403d/f7 LCD TV When the TV is
first you may check the T-CON board if thats ok then the problem is coming from your set panel .
Sep 01, 2013 | Philips Televison & Video
Why does my Philips 40" flat screen tv shut off 15 seconds after I turn it on?
The symptom you describe suggests power supply failure. It is still working but fading fast
Mar 24, 2013 | Philips 40pfl3706/f7 Lcd Flat Panel Tv
Mjpeg video wont work
I do not sure whether this can help you, this article mainly tell you how to convert mjpeg to imovie, but you also can convert to other format, good luck.
Oct 01, 2012 | Philips 32PFL3506/F7 - 32 Widescreen 720p...
LCD screen glows super bright then shuts down with red pwr lite
The ps voltages need to checked with inverter plugged in otherwise you can't verify a p/s failure. most likely you will need a new inverter/ps. Julio milleniumtvsvc@gmail.com
Jul 22, 2009 | Televison & Video
Philips Consumer Electronics Philips 32 Pfl3506/f7 Widescreen Lcd Tv, Logo
51 people viewed this question
Top Philips Consumer Electronics Televison & Video Experts
Electro Med Services...
Are you a Philips Consumer Electronics Televison and Video Expert? Answer questions, earn points and help others
