Question about Whirlpool RBS275PD Electric Single Oven
Reset cooker - Whirlpool RBS275PD Electric Single Oven
  • 54 Answers
Turn off breaker for 5 minutes and then turn it back on.
Posted on Nov 23, 2013
My zanussi cooker isn't working after a power cut...even the timer/clock isn't flashing to reset wht can I do
Claire. Have you checked the cooker supply switch? (Usually on the wall near the cooker) If it has a neon light is this on? If not or no neon check the circuit fuse/mcb in the fuseboard. Allan Pointer.
Apr 06, 2016 | Zanussi Ovens
Bypass a faulty timer unit on a stoves 720ef cooker. . . . My partner tried this today on my cooker and now there is no power to the cooker at all!! Is there a chance he's managed to do the wr
I would suggest the wrong wires were cut off and joined. If the ground wire touches the power wire a fuse or circuit breaker will blow.. Before you do anything more make sure the curcuit breaker is not blown. If it is reset it and turn the cooker back on. If the breaker blows again then it is wired wrong.
Dec 16, 2014 | Stoves 720EF Electric Double Oven
How can I reset my timer to manual on mylevc66w cooker
Well, not your EXACT cooker, but next one The lecv67, should be the same instructions.
Download here
http://www.leisurecooker.co.uk/Products/Download?filename=LEVC67.pdf
Page 20 and 21 refer to what you want.
Sep 16, 2014 | Ovens
IS IT NORMAL FOR THE FUSE TO BLOW WHEN A HEATING ELEMENT DIES IN THE FAN HEATER IN MY ELECTRRLUX COOKER?
The heating element is shorting out and causing it to blow the fuse
Aug 25, 2014 | Ovens
I have a stoves 720ef anf for no obvious reason the clock resets to 23.59 and the oven turns off, can you suggest anything
You obviously have a power loss somewhere. The oven will not work unless a time is set on the clock. I would suggest you have problem with the feed to the cooker which an electician should be able to check it out. If anything else is wrong on the cooker, it shouldn't reset the clock.
Nov 28, 2011 | Stoves 720EF Electric Double Oven
Cooker clock requires resetting
You need to press 2 or more of the timer/clock buttons in seqeunce to cancel the auto setting.
The sequence of buttons varies according to the make of cooker, so just keep pressing the buttons until you hit the correct sequence.
Hope this helps.
Jan 06, 2010 | Ovens
Clock on cooker flashing
Just to let you know that i have solved the problem with my cooker, (clock flashing after electric going off) i held down the cook period button and the end time button, then i was able to reset the clock by pressing the +button.
Apr 28, 2009 | Hotpoint UY46 Style Line Stainless Steel...
I need to reset the clock on my AEG cooker model No S75408 KG
I am assuming you have a touch pad for the clock. You can hold down the time button for a few seconds an it should start blinking. If it doesn't work, try pushing the "set" button for a few seconds. Usually, you can find it by trying all of the buttons til you get the right one. Then, you can adjust the time by moving the up and down arrows.
Jan 29, 2009 | Ovens
Cant set cooker clock so cant use oven as a result
You will probably have to replace the cooker clock. Do any of the other parts work? This fortunately is not that expensive and you were blessed not to have more damage than this.
Jan 29, 2009 | Hotpoint DY46 Style Line Stainless Steel...
Whirlpool RBS275PD Electric Single Oven Logo
35 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal DeAngelo
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
