Question about KitchenAid Architect Series II KSSO42QTX 42" Built-In Side-By-Side Refrigerator with In-Door-Ice Dis...
Handle loose - KitchenAid Architect Series II KSSO42QTX 42" Built-In Side-By-Side Refrigerator with In-Door-Ice Dis...
    Sergeant:
  • 479 Answers
Should be screws coming in from the end of the door several from top of door to bottom
Posted on Nov 23, 2013
How do I do fix the handle of my Matag refrigerator #M1TXEMMW803. It is loose on the bottom.
Maytag Repair - YouTube
? 2:17
https://www.youtube.com/watch?v=KcPy_PWb_Iw
Aug 27, 2013 - Uploaded by hpaiz69
Maytag Side by Side Loose Door Handle Repair. ... RefrigeratorDiagnostic & Repair - Not cooling ...
LG Refrigerator Repair (Part #AED37133117) - YouTube
? 1:01
https://www.youtube.com/watch?v=BXupc6y_wgw
Jul 9, 2013 - Uploaded by RepairClinic.com
The most common reason for replacing the handle is when it . ...Fridge Freezer Door Handle Replacement ...
How to fix a loose Refrigerator Handle - YouTube
? 0:30
https://www.youtube.com/watch?v=4IO60zkMXpw
Dec 12, 2013 - Uploaded by Charles Joyner
How to fix a loose Refrigerator Handle .... Refrigerator Repair - Door & handle, Amana , Whirlpool, Maytag ...
Jan 05, 2016 | Cars & Trucks
Bosch refrigerator door handle is loose
there is only one screw on the handles from what i found out from fixing my loose handle. the bottom of the door handle has one screw. once you loosen that one up then you lift it and it comes out at the top enough to slide the handle out and tighten it.
Aug 03, 2014 | Bosch Evolution 800 B20CS80SNS Stainless...
The handle is loose and the screw seems to be as tight as possible. It is a Moen single handle tub set.
might be that the spacer is missing. there is a small brass spacer located between the handle and the stem. if this is missing, your handle will feel like it's loose.
Jul 24, 2010 | Moen 3189 Legend One Handle Tub And Shower...
Loose handle on door
The door handles mount on hex bolts sticking out of the door, the door handles have key hole inserts that match with the bolts. The door handles are then slid in one direction to lock the handles in place. Removal is the reverse. To tighten the door handle screw the bolt out enough that you can still put the handle over the bolt heads and slide the handle to lock the handle in place.
Apr 12, 2009 | GE Profile Stainless Bottom-Freezer...
Loose door handle
I just FINALLY fixed mine...  Popped little cover pieces off top and bottom of handle with a plastic bread bag tag slid along space created by loose handle (did not scratch finish on door).  That exposed the screws which could be tightened with a phillips screw driver; the cover pieces then snap back on the ends of the handle.
Apr 06, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Loose Oven door handle
Ok you need to use plastic or rubber washers against the glass so it doesn't break. To stop the handle comming loose again you need to put "Lock Tight" on the screw threads then tighten carefully only untill the handle isn't loose. You can get this from any good hardware store. cheers
Please give feedback
Mar 23, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Door handles loose
i have a whirlpool conquest side by side and had loose handles,couldn't figure out.but then i grabbed handle and push in and up,handles slide off you can then tighten bolts then slide it back on.hope this helps.n
Oct 14, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
LOOSE DOOR HANDLE whirlpool frige GC5SHEXNQ00
Pulled the handle up to release it from the clips on the door. The screw in the plastic door handle that attaches the handle to the door clip was striped. I used a small amount of J B Weld epoxy to repair and reattach the screw. Realign the handle with the clips and push handle down to reinstall.
Jul 29, 2008 | Refrigerators
Loose handles - GE monogram model # ZFSB25DMD SS
try removing the handle, that will expose the mounts for the handle. You should be able to tighten them after removing the handle.
Jan 08, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Refrigerator side by side loose door handles
I was actually trying to find a solution to this problem myself though I'm pretty sure I already know the solution. Try this: grip the handle that's loose firmly and jerk it up. The handle should come up and the straight out to reveal the spring clip mechanism holding the handle on. Tighten the screws on this and then put the handle back on by pushing it towards the fridge and jerking it down. You make want to protect the fridge above and below were the handle attaches so you don't scratch the fridge door when pulling the handle on or off.
Oct 29, 2007 | GE GSH22JFR Side by Side Refrigerator
KitchenAid Architect Series II KSSO42QTX 42" Built-In Side-By-Side Refrigerator with In-Door-Ice Dis... Logo
61 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
