Question about Home Fencing
Necht Parts -i need to replace my timer dial clip, the inside - ModelHB0420C(B)
Serial no : GH007470
2 Suggested Answers
SOURCE: need replacement parts -- on and off clips for old...
Tripper order form at the Intermatic Inc. website:
http://www.intermatic.com/~/media/Files/Intermatic/Other/866%20tripperorderform_6%2014%202010.ashx
Posted on Oct 01, 2010
Clock generator dial
If this is Woods timer, then there are no replacement parts.
I am not familiar with KMD as a model number or brand.
Copy following link to identify same-similar timer.
http://waterheatertimer.org/Woods-timers-and-manuals.html
Add comment and describe timer in detail or attach photo.
The only timers on market today with replacement parts are Intermatic. And some Tork.
http://waterheatertimer.org/intermatic-timers-and-manuals.html
http://waterheatertimer.org/intermatic-trippers-and-parts.html#T100
Gene
k
Aug 05, 2013 | Coleman Cable Woods 59402 40Amp Timer for...
Removing a whirlpool timer dial?
We are sorry to hear of the problem with your Whirlpool appliance. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at Whirlpool_reviews@Whirlpool.com for further assistance. Please proivde your full name, address and the model and serial number for your washer.
Apr 01, 2017 | Whirlpool LSB6000PQ Top Load Washer
How to I click the red clip back onto the dial of my Intermatic Outdoor Light Timer? Thank you
Timer is not identified
Usually you line up tripper with hour or half-hour shown on dial, and then push the tripper all the way down into place.
Some older timers require you to push in the center part of timer and then insert tripper.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#trippers
http://waterheatertimer.org/How-to-set-timers.html
Jul 06, 2011 | Intermatic Hardware & Accessories
How do I set the timer for the malibupower pack
set the dial to the corect time by turning the dial. remove the clips by pulling straight out. reinsert clips on the desired times for on and off red on black off
May 24, 2010 | Intermatic & Malibu& 300 Watt Power/Pack...
Washer continues to run but the timer stops at 42 minutes
OK I see it.
Most likely problem is the timer. The timer tells the machine what to do and when. Yours is sticking at the 42min mark.
I do not see the model number so I'll take an assumption.
Digital timers are integral to the control panel and can be replaced as part of the panel.
Rotary dial timers are easily removed and replaced.
Switch the breaker off. Do not touch the control panel without first having done so.
To remove the control panel there are screws around the outside of the door frame and on some units from inside the machine on the door frame. Remove them and the control panel will be exposed.
If you have a rotary dial timer remove the control knob (pulls off) and the screws retaining the timer inside the control panel. You can sometimes "fiddle" with this style timer and get it going again. It is usually just dirt struck in the mechanism stopping it turning. But it is not expensive and I'd just replace it.
Digital is another system. If you can remove the timer section as a unit then you can replace it. Fist I would get the model number and go to your local parts dealer. Ask it you can get just the timer. If so replace it. There are no serviceable parts in an digital timer.
I hope this helps you. Please rate it is it helps clarify for you.
Mar 10, 2010 | Whirlpool Dishwashers
I want to set the timer and I don't know how
The timer has a dial and an arrow pointing to a certain time. Turn the dial to the correct time of the day ex. it is 2 p.m. rotate the dial so as the arrow points at 2 p.m. Then their are some clips around the dial 2 or 4 or more has to be in pairs. If you want to start sprinkling at 3:00 pm and stop at 3:20 pm put one clip at 3:00 pm and the other clip at 3:20 pm. One clip turns the sprinkler on and the other turns it off.
Jan 24, 2010 | Intermatic R8806P101C -...
Wash cycle dial wont turn...will still push in and pull to start
We have a GE WJRR4170 washer, with the same problem. At first I thought I might have to unscrew the entire control panel just to replace the knob. However, replacing the knob turns out to be easy.
Right behind the knob, holding it in place, is a nylon/plastic retainer clip. If you pull out the knob (into the "start" position), you will get easier access to the retainer clip. You can use a flathead screwdriver to push the clip out. The knob then will slide easily off the metal stem. A GE replacement knob costs $9 or $10, depending on the source.
Shame on GE, but the knob is designed terribly. The part of it that engages the dial has eight, flimsy plastic teeth. At any time, four of these are supposed to engage four little slots in the dial. However, the way the knob is designed, there will be a lot of wear and tear on these plastic teeth, so they'll wear out on every single machine.
Good luck to the many people who will have this problem!
Jul 26, 2009 | GE WJSR4160DWW Top Load Washer
Control knob will not turn to desired setting
the timer knob has a clip that will allow you to remove the knob from the timer. it is between the knob and the dial. what happens is the knob has gear like teeth that will become stripped out.it is easy to replace but alittle hard to remove. you need to get a small screwdriver and go behind the knob, pull on it alittle and you will see the clip, then use the screwdriver to push the clip out of the knob, then the knob will pull of and you can replace it.
Dec 28, 2008 | GE WJRR4170E Top Load Washer
The pull start is broken for our kids necht 2003 quad bike?
can som1 help me got new pullstart it will go on but wont grip totally lost .any help would be gratefull..thx
Dec 23, 2008 | Techtronic Industries, Inc. Ltd. Ryobi...
Removing the busted dial
if it is the timer dial just pull the heck out of it but some have a clip on the backside of the dial itself remove this pin and it will come off in your hand you can contact Ge aor repair clinic.com or even a local appliance dealer ( Used or parts dealer) in your area can order it for ya
Dec 22, 2007 | GE WBSR3140DW Top Load Washer
Home Fencing Logo
69 people viewed this question
Top Home Fencing Experts
 Russ Hill
Russ Hill
Tom Chichester
ray gallant
Are you a Home Fencing Expert? Answer questions, earn points and help others
