Question about RCA RTS202E 200W Home Theater Sound Bar with built-in DVD Player
RCA RTS202 POWERBAR SHUT OFF
It won't turn on. When I unplug it for awhile and turn it back on the blue standby light turns on, but when I try to turn it on or touch any other button it shuts off again?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • RCA Master
  • 924 Answers
There are many issues that may be at play here. Most likely, you are experiencing DC Offset(meaning you have a damaged amplifier). For more information, please visit my website at audioserviceclinic.com. Thank you.
Posted on Nov 21, 2013
4 Suggested Answers
MakikiChris
  • 84 Answers
SOURCE: RCA RTD258 Not working
Do you have a DVD in the player? If an incompatible region code disc was left in the player upon shutdown, it will cause your particular system to lockup. Your unit has a 1 year warranty, and you can easily obtain over the phone help from RCA by calling 580-634-0366 and have your unit?s date of purchase and model/serial number ready. The model/serial number information is on the back of your unit. During your phone call the Technician will determine if you should receive a replacement unit, and if so, will provide you all of the relavent information and a Service Request Number for your tracking convenience. Keep this SR# permanently so you can cite your history should future problems arise, also, a helpful tip is should you utilize a Passcode for your system and forget it, the Master Passcode is 9688.
Posted on Jul 31, 2007
SOURCE: RCA RT2770 receiver won't turn on!
For the noise when it starts try this. Remove cover and you will see a small fan held in place by 2 screws. Remove these screws and then remove fan. On the back of the fan you will see a sticker. Remove this sticker and apply 1...just 1 drop of oil onto the now exposed shaft. Replace the sticker, the fan and the 2 screws.
Posted on Jul 24, 2009
youngbrooke8
SOURCE: I have an RCA Home
I have the same exact one...and the same problem....i am about to call rca...screw walmart
Posted on Aug 10, 2012
What parts might be bad if tv powers on, standby light turns blue, but still no picture or sound?
If back-light is OK, the fault will be with its T'Con board. If you wish to get some details; check the site linked here. Pull up older posts.
Oct 08, 2016 | RCA 42PA30RQ 42 Class Plasma TV - 1024 x...
Sound bar keeps turning off automatically
Main board [system control side circuit] fault. Contact any service technician. Gopakumar Gopalan Google
Jan 19, 2015 | RCA Televison & Video
I have a 55" Panasonic flat screen that won't turn
Try disconnecting all of your HDMI cables and plugging the power cord of the TV into another wall outlet. If this resolves the issue, you may have had a small power surge from either your wall outlet or one of your source devices. It is recommended to connect your TV to a surge protector if you haven't done so already.
Sep 29, 2013 | Televison & Video
My pioneer plasma tv in standby mode and wont turn on
Try restting it by unplugging the tv for a few mins and it should rest to original factory default settings but leave it unplugged 10-15 mins to be sure.
Dec 18, 2011 | Pioneer PDP-4270HD 42 in. Plasma...
I have a RCA DVD Home theater system and I plug it in and the blue standby light comes on, but when I push it or other buttons on the unit, it just powers off and then won't turn turn back on at all....
I am having the same problem...i plug it in the standby light xomes on but i press the power button and nothing happens...mine is a rca rtd315wr model
Sep 03, 2011 | RCA RT2360 System
Flat scren wont turn on
Try a power drain:
1. Unplug the TV's power cable so that the TV is not grounded to the house.  Do not simply turn off a powerbar if one is in use. 2. Press and HOLD the TV's own power button for one minute to drain the internal capacitors. 3. Plug the TV back into a wall outlet versus a powerbar, if one is in use and see if this makes a difference.
If the TV does not turn on, are you able to see any indication from an internal LED light in the back of the TV?  If not, the problem is usually with the power supply. If you do see a LED light anywhere, then you know the TV is getting power but the TV's mainboard is at fault.  In either case service would be required if the power drain does not resolve this.
Mar 24, 2009 | Sony Televison & Video
Ilo tv isn't working
Try a power drain:
1. Unplug the TV's power cable so that the TV is not grounded to the house.  Do not simply turn off a powerbar if one is in use. 2. Press and HOLD the TV's own power button for one minute to drain the capacitors. 3. Plug the TV back into a wall outlet versus a powerbar, if one is in use and see if this makes a difference.
If the TV still won't turn on but you have a LED light flashing, the problem is usually with the TV's mainboard and not the power supply or the LED wouldn't even be on.  Service is likely required.
Mar 24, 2009 | Televison & Video
RCA D52W136D 52 in. TV/DVD Wont turn on
Does the standby light flash in a set pattern? Some tv have a error code system which pinpoints the fault by flashing the standby light a certain number of times. Other than that my best guess would be a fault on the power supply or a fuse blown internally. Good luck.
Apr 08, 2008 | RCA D52W136D 52 in. TV/DVD Combo
NEW TV WONT TURN BACK ON
polorid known for going out take it back asap those have worse revies back panel go out ok no good please upgrade yourself to a nice samsung or sharp ok for best quilty for yrs to come u be happpy u did
Jan 29, 2008 | Televison & Video
RCA RTS202E 200W Home Theater Sound Bar with built-in DVD Player Logo
101 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
