RCA RTS 202 POWERBAR WONT TURN ON
This unit will not turn on. I unplug it for a while and turn it on, the blue standby light turns on but when i try to turn it on or touch anyother button the blue light goes out and turns off again.
SOURCE: rca rt2870 wont turn on
I have the same problem. In my case, the problem was the transistor that command the relay that supply the main transformer. You can find it in the power supply board, near of the relay.
Posted on Dec 01, 2009
SOURCE: lamp and power flashing amber
The problem is the lamp driver, it can be repalced by dell for $250 plus parts. The specific problem is a capacitor on the driver board, if you know someone who can work on electronics have them replace the 3300u 10v capacitor on the lamp driver board. Usually the capacitor will be slightly bulged on the top (not flat) indicating it needs replacing. Otherwise look for a electronics repair shop in your area and set them in the right direction. Hope that helps.
Posted on Dec 29, 2009
  • 4 Answers
SOURCE: won't turn on. unplugged, waited, tried again,
make sure u cycle main power switch before u unplug then unplug wait 30 seconds and repeat one more time
Posted on Jan 24, 2010
  • 979 Answers
SOURCE: tv wont turn on
Hello Charliebigwh, hi technically your monitor's power supply has a problem, this is either your switching regulator does not work or there is a short in that section, If you want to do it your self, need to replace all large value, and or high voltage capacitors(especially the capacitors with its top is bubbly), need also to replace the switching IC, and power transistor.
Have it checked by a technician if you cannot do the work.
Posted on Apr 15, 2010
Testimonial: "how helpfull thanku kindly !"
SOURCE: Technika lcd32-207 is stuck in standby. Blue standby light dims.
Hi brendafoud, have you had this fixed as mine is the same and has been for months. It happened just after the warranty had ran out(typical). Bought from ebay and the people I got it from are not very helpfull. Have you got yours fixed yet?
Posted on May 05, 2010
I have an RCA 32" LCD HDTV/DVD Combo model 32LB30RQD it has power, but no picture or sound and no turn off the blue power light.
Probable defective power supply board in the set. ebay RCA model # for replacement power board. Replace board
Dec 29, 2014 | RCA Televison & Video
RCA RTS202 POWERBAR SHUT OFF
There are many issues that may be at play here. Most likely, you are experiencing DC Offset(meaning you have a damaged amplifier). For more information, please visit my website at audioserviceclinic.com. Thank you.
Nov 20, 2013 | RCA RTS202E 200W Home Theater Sound Bar...
My pioneer plasma tv in standby mode and wont turn on
Try restting it by unplugging the tv for a few mins and it should rest to original factory default settings but leave it unplugged 10-15 mins to be sure.
Dec 18, 2011 | Pioneer PDP-4270HD 42 in. Plasma...
My RCA Model RTD325W On/Standby light is red but will not turn on, what do I do?
I have had the same thing happen. Unplug the unit (AC) and wait about 30 seconds. Plug it back in and it should be fine. I assume you tried both the remote and the front panel controls.
Nov 07, 2011 | RCA Audio Players & Recorders
I have a RCA DVD Home theater system and I plug it in and the blue standby light comes on, but when I push it or other buttons on the unit, it just powers off and then won't turn turn back on at all....
I am having the same problem...i plug it in the standby light xomes on but i press the power button and nothing happens...mine is a rca rtd315wr model
Sep 03, 2011 | RCA RT2360 System
Flat scren wont turn on
Try a power drain:
1. Unplug the TV's power cable so that the TV is not grounded to the house.  Do not simply turn off a powerbar if one is in use. 2. Press and HOLD the TV's own power button for one minute to drain the internal capacitors. 3. Plug the TV back into a wall outlet versus a powerbar, if one is in use and see if this makes a difference.
If the TV does not turn on, are you able to see any indication from an internal LED light in the back of the TV?  If not, the problem is usually with the power supply. If you do see a LED light anywhere, then you know the TV is getting power but the TV's mainboard is at fault.  In either case service would be required if the power drain does not resolve this.
Mar 24, 2009 | Sony Televison & Video
Ilo tv isn't working
Try a power drain:
1. Unplug the TV's power cable so that the TV is not grounded to the house.  Do not simply turn off a powerbar if one is in use. 2. Press and HOLD the TV's own power button for one minute to drain the capacitors. 3. Plug the TV back into a wall outlet versus a powerbar, if one is in use and see if this makes a difference.
If the TV still won't turn on but you have a LED light flashing, the problem is usually with the TV's mainboard and not the power supply or the LED wouldn't even be on.  Service is likely required.
Mar 24, 2009 | Televison & Video
Ilo 32 lcd
I have the same issue. Here's a temporary solution, which is what I've been doing for the last couple of weeks, unplug the unit from the wall, just long enough for the red standby light to go out, then plug the unit back up. as soon that the red standby light comes on, press the on button the the remote or the unit. You may have to do this couple of time before it works. Somedays it works on the first try for me and then somedays I have to do it 3 to 4 time. I sure that at some point this will stop working too.
Sep 08, 2008 | iLO 3200 32 in. LCD Television
RCA D52W136D 52 in. TV/DVD Wont turn on
Does the standby light flash in a set pattern? Some tv have a error code system which pinpoints the fault by flashing the standby light a certain number of times. Other than that my best guess would be a fault on the power supply or a fuse blown internally. Good luck.
Apr 08, 2008 | RCA D52W136D 52 in. TV/DVD Combo
Won't turn on - lights appear for a second then nothing
Probably a poor power connection either where the AC pack goes in to the wall (probably powerbar!) or where the plug from the power pack goes into the unit. Wiggle the various connectors to see which one solves the problem. As a last resort you may have a faulty power pack (try ask a dealer or friend to test your system on their power pack).
Apr 14, 2007 | JBL CREATUREIIWHITE Computer Speakers
 Grubhead
Grubhead
