Only have part of pages
Only have part pages have to move blue line on side to get full screen
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 70 Answers
I would assume you are using windows8 ?
drag the very top of the screen across and it will open right out.
Posted on Nov 20, 2013
    Genius:
  • Computers & ... Master
  • 1,177 Answers
If that's a problem within your browser, you can hold down the Ctrl key and press the "-" (minus or hyphen key) to make the display smaller. You can also increase the Control Panel's Display settings to a higher resolution.
My tv blue screen and line
replace the vertical amplifier if the line is side to side if the line is top to bottom replace the horizontal amplifier and you will.have full screen
Oct 03, 2015 | Konka Televison & Video
My Samsung TV developed a a single blue vertical line on the left side. what could possibly cause that.
If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Type in the brand name and type (TV, VCR, DVD player etc:) of your device, in the search box [at the top right] of the home page. It will make surf easy.
Jun 13, 2015 | Samsung UA-40H5500 40" Full HD Smart...
How do I remove three vertical colored lines from my Television. One vertical line is green another is red and the final one is blue.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
May 24, 2015 | Panasonic Viera Tc-p50u50 Hd Plasma Full...
HP Dv7-1130us LCD screen displaying vertical blue line
the actuall screen LCD is bad.
in most cases.
supper common failure.. 2008 PC.
see page 31 , part 5 here. bingo, change that out.
there are 2 types used, only your full PC part number on
the service tag show this, post that and we go to the HP parts surfer and look it up.
http://h10032.www1.hp.com/ctg/Manual/c01918142
Sep 28, 2017 | HP Pavilion dv7-1130us laptop
What will cause a wavy blue lines running left to right from the top down
That is knon as a convergence failure. Its real common an a failry easy DIY fix. You can read more about how to fix it here in this video and on the fixya tips page below.
07e70208-1f08-4826-857e-065c46e4dbb8.pngFixya Tip Page
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 15, 2013 | Philips Televison & Video
Full Color fading to blue then screen turns off. Repairable?
Here is what you need to do.
1.) You need to remove the entire plastic piece below the front of the screen. You most likely will find 3 screws on either side in back that you have to remove.
2.) The grill will not come out easy, pull from one side and then when it starts to come loose from the other side(there are several plastic pegs that hold it in.) Then from the bottom pull out( most of these sets have square plastic tabs at the top that tuck in.)
3.) With the grill removed locate the inspection plate behind it (it usually has 6 screws.) You will have to tilt the grill to the left and on its side as several cables are connected to it--they are held in place with trash bag like ties that you can release to get some room.
4.) With the inspection plate removed you will see a fairly small (about 3 inch square) BLACK PLASTIC BLOCK WITH SIX CONTROLS-usually they are marked with whiteout so someone can tell if they have been adjusted.
5.) You need to look very close at the block with a flashlight----usually the top three controls are FOCUS--don't touch those.
The lower three are usually marked Screen and if you look very close you will see b, g, r(blue green red)
6.)Usually the blue will be on the bottom left--it does vary
7.) Once you locate the BLUE screen control have the set on and turn it down--if the set is shutting down you may have only a few seconds to try to turn it down---usually to the left with the Blue Screen control.
8.) Best way to do this if the set is on is on a video input with nothing connected--you turn the blue down until the set stays on and then very slowly turn it up until you see a slightly blue screen with or without diagonal trace lines----if you get it to turn on this way turn the blue screen back down slowly until the blue screen and trace lines just disappear.
Let me know if you get it to work--Like I said if it is shutting down you may have to slowly turn the blue screen down a few times to get it to stay on.
I do this here for free and if this helps you at all give me a vote here--it costs you nothing.
Regards, SD TECH
Sep 17, 2009 | Sony KP-65WS500 65" Rear Projection...
My HP 2840 is printing blue lines on the side of the page
3 Causes for printing Blue Lines on the side of the pages.
01. If it happens with test pages from the machine itself as well as docs;then most likely it is a bad cyan cartridge.if you open the drum shutter on the cyan cartridge,can you see a line on the drum?
02. If the Drum is opened and you can see a continuous line of blue toner is at both sides of the drum. Chance of getting blue lines printed on the side of the pages.
03. If the cartridge is leaking then and will need to be changed.thats why it's ending up on the belt also and it prints blue line on the side of the pages.
Aug 06, 2009 | HP LaserJet 2840 Printer
When printing, the page is full of vertical lines.
Look on top of the toner cartridge, there should be a blue slider....move it back and forth 10 times.
If that doesn't cure it, replace the drum unit.
Jun 25, 2009 | Brother HL 1430 Laser Printer
Blue vertical line at reght side of screen
This is normal. Depending on what you have connected to it the lines could be white, black and white specs, or green. Just mode will show the entire picture event the parts that aren't supposed to be seen. I would not recommend that setting. Full is the best mode if you want to see the entire picture in the correct ratio.
Apr 24, 2009 | Panasonic PT-56WX53 53" Rear Projection...
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
