Question about American Standard Plumbing
Piping size wrong - American Standard Plumbing
Furnace stays lit and runs only with the cover panel off. Is that an air flow issue related to the flue pipe?
If it is a high efficient furnace with pvc pipes, there could be a blockage (kids ball, bird, ect.) or the drain could be plugged or the flue could be slopped wrong or have a bow in it causing the flue to fill with water. Or if this is an ongoing problem the flues could be sized wrong.
Dec 01, 2017 | Heating & Cooling
While driving, should I'd overwhelming
Hub bearing get them checked
Mar 10, 2013 | Cars & Trucks
Can propane gas lines cause pilot lights to go out?
It could be a blockage in you pipes or blocked pilot on water heater nees cleaning or your pipe size is too small for both or you are low on gas or reg on tank not working ie wrong working pressure .
Dec 28, 2012 | Heating & Cooling
What is the main difference between pipe threads and bolt thread?
pipe threads taper. measurements are different.names are drefferent.pipes are called ips or iron pipe size.bolts are by size and noumber of thread per inch or mm
Dec 06, 2010 | Computers & Internet
O rings on oil coolant lines wont stop leaking have changed several times and it just pours out am i using the wrong size ?
Its possible you are using the wrong size o rings, but you should check to see if the pipe at the connector end is not cracked or has a porose hole etc also check that the connector on the oil cooler is not cracked too
Jul 06, 2010 | 1995 GMC Sierra
Moved into house with damaged joint in external soil pipe from upstaira shower room
You didn't state the size of the pipe or if it is PVC(plastic) or Cast iron. Two rubber couplings can be used to repair the joint. A 12" section, 6" on either side of the joint needs to be cut out. Cut a piece of schedule 40 drain/waste pipe same diameter as existing pipe to size(just under 12"). Take two rubber couplings (sized for your pipe) and place on each end of pipe joint, and tighten clamps.
This fix will work on cast iron pipe, but there may be another means of repairing the joint, so get back to me with more info about the pipe and joint.
Aug 02, 2009 | Plumbing
How to lay out 3'' pipe 45degree to 10'' pipe size
measure both opens from center too floor then mulip;t it times 1.41 thats your cut piece
Mar 25, 2009 | Plumbing
Pipe sizes
depends on the distance between the source and the unit
Feb 27, 2009 | RTO Hubbard Supply Co 250 Up to 1" CTS...
HELLO
It has the size pipe the service manual says it has, or whatever the mechanic replaced it with. Get a calipers and measure it; look at the ends and see if it was the wrong size in the first place.
You'll be pleased to know that there is no single size of course, because flex pipe comes super fat and has to be conditioned to the right size carefully. Additionally, the other pipes merely have minimum sizes in the spec. repair manual, not given sizes.
See why muffler people don't seem all that fenced in?
Let us know how your Compag Presario/Mitsubishi Accent thing goes, eh?
May 18, 2008 | Compaq Presario 5000 PC Desktop
Plumbing Logo
69 people viewed this question
Top American Standard Plumbing Experts
Donni Steen
john h
TED
Level 1 Expert
Are you an American Standard Plumbing Expert? Answer questions, earn points and help others
