Question about Binks Air Tools & Compressors
Air and fluid still pass when triger is nor pulled
Saw idles ok just when i pull the triger it boggs down and stalls
idle settings isnt ok! Air/Fuel mixiture problems- Or - It can bea a problem with crancase sealing, Ther is maybe air leak!
Mar 07, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Changed spark plugs and wires and the car will not change to overdrive and will not go into passing gear 1987 lincoln givenchy
Check the passing gear cable, this cable is connected next to gas cable under air cleaner on throtle body. make sure cable is connected and also disconnect and pull cable it should spring back if it pulls out then cable poped. start there.also make sure trany fluid is full.
Jul 26, 2010 | 1987 Lincoln Town Car
175handler quit spooling the wire . it still clicks when you pull the triger but moter does not turn
Do the drive wheels turn? Take wire out of drive rolls to see if they will turn! If they turn you could have possibly pinched the liner in your mig gun that your wire passes through. If so you will have to change it out. Good luck!
May 22, 2010 | Welding Tools
How do i remove the bolt from the mossburg 308 win. and is there a product you offer to modify the triger
if i were you i would leave the bolt alown,,its a hell of a job getting them back in,,,as for the triger i know there a bit on the heavy side to pull at nearly 4 lbs but its a safe pull,you could drop the gun into a gum smith and get him to snip off a coil off the triger pull spring,,and stone the sear,, but be warned it will make the triger twitchy,,you realy dont wont to light a triger on a hunting rifle 4 - 6 lbs is normal
Nov 18, 2009 | Optics
Fires like a machine gun without pulling triger. Close call
Bostitch N60FN finish nailer:
I replaced the o-rings and reassembled now when I put air to it the driver does not return and when I pull the trigger I get a "puff" sound.
Sep 07, 2009 | Stanley Bostitch N88rh Framing Nailer...
Piston drives down when hooked up to air...piston does not return up. is this a problem with the triger valve? I am not pulling the triger, just hooking up the air. This gun hasnt been used in 10 years,...
Sounds like the head valve is stuck in the head. Take black head off and see if the valve is spring loaded by pushing down and see if it comes up. This is the usual problem.
Jul 08, 2009 | Stanley Bostitch N80CB Coil Framing Nailer
Air leaks not the problem
sounds like the piston or the head valve is stuck. Open up the back with an allen wrench. Look it over really well. Clean it out with some WD40 after you pop out the head valve and take out the piston and cylinder. You're probably gonna need a kit with seals and o-rings. There is also a bumper (towards the front of the gun that seats inside the cylinder, make sure everything looks good and not dry-rotted or dirty. Lemme know. Please rate me
Jun 16, 2009 | Hitachi NR83A2 2" To 3 1/4" Full Head...
Roofing nailer wont fire porter cable rn174a
9 times outa 10 this is an oring on the driver blade regulator inside the head. it can be removed by undoing the top you may probably find your problem there
May 16, 2009 | Air Tools & Compressors
Paslode finish nailer wont fire
CHECK THE SPARK! IF YOU HAVE A JOBSITE RADIO YOU CAN HEAR THE SPARK ON THE AM BAND AND TELL IF THE TOOL IS FIRING!
Nov 02, 2008 | Air Tools & Compressors
BOSTITCH AIR POWERED NAILER - AIR LEAK THRU TRIGGER
sounds like the rubber seals have dry rotted prob from not oiling it enough, but you should be able to go on the Bostitch web site and order new rubber seals for the gun
Sep 29, 2008 | Air Tools & Compressors
Air Tools & Compressors Logo
Top Binks Air Tools & Compressors Experts
JOHN LAPIER
john h
russ davis
Are you a Binks Air Tool and Compressor Expert? Answer questions, earn points and help others
