Question about Delta Faucet Plumbing
Spout blew off - Delta Faucet Plumbing
Head gasket repair cost
If it's spraying out of the spout and is boiling, it's very possible that one of the head gaskets blew depending on how long it takes to overheat.
A few things to look for:
Inspect the radiator. Make sure all of the cooling fins are there, and not obstructed by dirt/debris.
Make sure the cooling fan is turning on (it should turn on when the temperature is approximately at the halfway point of the temp gauge).
Look at the color of the "smoke" coming from the tailpipe. White = steam. Some steam is normal, however, if it's constant, and a lot of it, it's a blown head gasket indicator.
Blue = burning oil. Black = unburned fuel,
May 07, 2014 | Infiniti FX35 Cars & Trucks
91 4.9 won't run with spout in, runs with spout out.
spout is computer controlled timing check the spout circuit for short to ground corroded insulation on harness where it runs along the intake also look for swollen or oil soaked sections of the harness
Dec 05, 2012 | 1991 Ford F150
Replaced delta valve with moem. when water to toub is turned on at high pressure water comes out of the shower head. Valve is installed correctly. Took cartridge out of valve and blew back through shower...
The pipe going from the main valve to the tub spout(not the sprayer above)needs to be a full 1/2" pipe if you used a pex 1/2" to the tub spout-the inside is usually smaller and causes it to back pressure and make water release thru the sprayer above-needs to be installed with a full 1/2" ID PIPE-AND DONT USE GALVANIZED
Sep 29, 2017 | Moen Posi-Temp Single HandleTub And Shower...
Water comes out spout and shower head at same time
Hello gruber d, you need a new spout. When a spout is working properly you raise the knob on top and it slides a baffle over the outlet at the spout. Once the water is blocked from flowing out of the spout it forces water up and out of the shower head.
You may also remove the spout and see if you can get a closer look and see if you can make some kind of adjustment to it.
Removing the spout;
1. Put a cloth around the spout to protect the finish.
2. Adjust a pipe wrench to fit over the spout and the cloth.
3. Turn the spout counter-clockwise to loosen.
My goal was to provide timely and accurate information. If this has been helpful to you, please
consider taking a second to click on the, " this was helpful ", button.
Than you!
Jan 13, 2011 | Grohe Grohmix Thermostat Valve & Trim -...
What`s the function of starboard outlet spout ?
The water squirter out the side is there to show you that there is cooling water going through the engine. If the outlet spout stops shooting water out the side you need to stop the engine and investigate. I have had mine stop shooting water. I stopped the boat and blew air through the hole backwards to clear the tube. One time I had to pull the hose off the motor(where the squirting water enters a hose to the outlet spout) and push a piece of wire into the engine outlet hole to clear it. Fortunately , the motor was never in any danger of overheating only the wizzer hole was blocked , water was still cooling the motor. Again if the outlet spout stops shooting water turn off the motor and make sure water is entering and cooling the motor.
Sep 20, 2010 | Yamaha 12V Air Pump
Delta RP34357 Traditional Diverter Tub Spout has been leaking around base and/or water running along bottom of spout toward wall from opening; today, whole spout blew off wall when faucet was opened only...
If this spout is less than one year old, I would contact my general contractor to get his plumber over to look at it. Most GC's (general contractors) will warrant their work for one year. If it is not under warranty, you should be able to fix this problem. Spouts do not typically blow off like that, so I am wondering if there is not an underlying circumstance. At any rate, I will assume the best and tell you how to reinstall the spout. There are several variations on spouts, but the one that is most common is a slip connection. Meaning that the spout will slide over a 1/2" copper water line protruding about 3" from the tub. After sliding the spout on, there is an allen screw on the bottom of the spout that snugs up against the copper pipe (again this is the most common type of install). If yours is different, let me know, and I will walk you through other processes. Before sliding the spout back on the copper, use plumber's putty around the opening that the copper is sticking out of. This will help to prevent water from getting behind the tub. Also, after the install; check the spout to make sure there are not any leaks. If no leaks are detected, use a clear silicone tub/shower caulk and go around the faucet. The caulk does not have to be a 1/4" bead to be effective. Run it around the spout, and using a moist towel, go back over the caulk to remove the excess. If you have done it right, you will not even notice the caulk, except for the gaps. Hope this is helpful.
Nov 20, 2009 | Delta RP34357 Traditional Diverter Tub...
The steam spout (pannarello) will not stay on
there is a rubber sleeve inside, and also a hard plastic olive (like a wedding ring). When tightened, the hard olive compresses the rubber sleeve and it grips.
If you lose the plastic olive, the rubber remains uncompressed and the pannarello will blow off.
The olive is about the size of a wedding ring for a person with a 5mm finger (impossible I know - but the shape is like a tiny black wedding band all the same.).
Oct 31, 2009 | Saeco VIA Venezia
A tube rubber like blew from what looks like the
its the airbox beather connect it to the spout on the engine wen the bike is running you should fill air comming out of the spout pop the tube back on and just cable tie the pipe on
Oct 23, 2009 | 2005 Honda CG 150 Titan KS
Plumbing Logo
54 people viewed this question
Top Delta Faucet Plumbing Experts
Donni Steen
Ed Mac
Are you a Delta Faucet Plumbing Expert? Answer questions, earn points and help others
