Question about Danby DIM1524W Ice N Easy Portable Ice Maker
Danby ice n easy not working dump tray gets stuck
Ice maker froze the ice and its stuck, it won't dump ice and it won't let me take out tray.
Some people use a hair dryer on it and dump it by hand. Then they spray some anti stick stuff on the ice cube tray so this will not happen again.
Apr 03, 2015 | Refrigerators
Ice dispenser does not work unit makes ice and water works fine
As long as the ice trays are filling with water, it's not actually the function of the ice maker to make ice. Ice simply forms because the freezer compartment is cold.
The icemaker's function is to sense when ice is formed in the trays and to dump the ice into its container.
This requires the use of a thermostat to sense the water/ice temperture and 'tell' the icemaker when it's time to dump the ice.
During the dump cycle, a heater briefly comes on as the arm swings through the ice cube compartments to assist in loosening the ice cubes and make them easy to dump.
If the icemaker is filling with water but you get no ice, I suspect that either the control circuit (thermostat, relays, and wiring) is not 'telling' the heater to come on, or the heater is burned out.
Some units also have a timer circuit such that both the timer contacts and the thermostat contacts must be close in order to initiate a dump cycle (i.e., it must be time to dump and the water in the cubicles must be frozen).
A skilled homeowner could make these repairs, but if you don't feel comfortable taking your icemaker apart and testing the components, I advise leaving the job to a qualified repairman.
I hope this helps. Good luck.
Sep 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker won't dump cubes
the problem is that the tray doesn't eject the cubes, they get stuck and it just breaks them and only parts come out instead of the whole cube/crescent, then the proper amount of water comes in as refill, the tray gets too full and your problem begins. Take the unit out, then take the tray out, its's easy, and give it a light coat of Pam, olive oil or corn oil, the cubes will eject properly. It took me 3 years to figure this out, it willl amaze you.
for everyone with the fan screech noise, replace the fan motor, don't buy the blade, look around the websites, I found it, my second replacement, for 28 but as high as 65.
yeah I hate this fridge too
Feb 08, 2009 | Samsung RS2630SH Side by Side Refrigerator
Ice maker problem
Clear the Ice tray by pressing the button under the ice maker. The problem is that the ice is in the first couple of slots is not dumping and the tray tries to fill again and over flows. I pressed the button and cleared the tray of ice (This will tilt the tray and twist it to empty it) that was re-frozen several times without dumping. My ice maker works perfectly after I did the above. I think the problem arises if the door did not close completely. I stopped hanging the dish cloth on the door and on my LG Dish wisher. I hope this helps
Oct 03, 2008 | LG LRSC26940ST 36" Side-by-Side...
LG SXS Refrigerator LSC26905 ice maker
I was able to order the ice tray myself and install it in the fridge - it's not hard. I ordered from one of the parts sellers linked to at the LG website, not those listed in other posts here.
Here's how to replace the tray:
You need to remove the tray dumping mechanism to do this.
  1. Remove the ice bin, set it aside (don't forget to deal with the ice melt).
  2. Turn the ice maker off (LG says to unplug the fridge, I didn't).
  3. On the left hand side of the ice tray dumping mechanism there is a screw helping to keep the entire thing suspended from the ceiling of the freezer. Remove that screw- don't worry, the mechanism will stay put for now.
  4. The dumping mechanism can now slide forward- note that you can't completely remove it from the freezer yet, but slide it forward and it will no longer be suspended from the ceiling. Don't let it drop or hang.
  5. You need to disconnect its power supply now. On the left hand side you should see a small bundle of wires coming from the back of the freezer to the dumping mechanism. It connects to the dumping mechanism's set of wires with a pair of white plugs. Pull these plugs apart. You may need to pry the catch on these plugs apart while you pull.
  6. Now you can take the dumping mechanism out of the freezer (and close your freezer).
  7. To remove the ice tray you need to slide the housing that contains the rotating motor out of the housing. This is on the right side of the mechanism. If you have trouble identifying it look at the underside of the entire thing and you'll see a small "test" button. That button is on the motor.
  8. To remove the motor you'll see two catches on the right side- you'll need to pull these catches out without breaking anything. You'll be able to slide the motor down and out when you get it right.
  9. Sliding the motor out lets you get the old ice tray out now. There is probably a set of white wires routed through a little catch on the old ice tray that you'll need to free.
  10. Put the new ice tray back on the motor. You'll need to get the left side secured at the same time you get the motor housing in its catches of the dumping mechanism.
  11. Reroute those white wires back on the new ice tray.
  12. Reconnect the electric wires to the housing.
  13. Slide the entire dumping housing back onto the ceiling of the freezer and screw in on the left side.
That's it. You can press that test button on the underside of the motor. This will dump the tray and immediately refill it with water so you can observe if everything is working.
Jun 03, 2008 | LG LSC26905TT Side by Side Refrigerator
Ice tray sometimes stuck when dumping off ice
Your icemaker tray has an update for the water flowing over the tray.  You will need to call a qualified LG technician to get it replaced.  Also, the tray is twisted because it binds itself against the hinge pin on the left side.  To stop this, spray some cooking spray oil in the left hinge pin and it should unbind itself and return to normal.
Mar 24, 2008 | LG LSC26905TT Side by Side Refrigerator
I had the same problem. I did the following and it now works great. The ice tray has a square tab on the rear leftside. As the tray rotates to dump the ice, the tab runs on a curved section of the the ice maker frame. The curved section becomes rough with use and causes the tray to stick when it is returning to the fill position. I carefully sanded the curved section of the frame to smooth it out. No problems since.
One does have to dismantle the ice maker to effect this repair.
Mar 09, 2007 | LG LRSC26980 Refrigerator
Samsung Icemaker Problem
I also had the ice tray stuck in the dump position. I unplugged it waited 5 minutes and pluged it back in. And the Ice tray moved back into the correct fill position, and the arm did drop down, But now it has not filled with any water. So now what should I try?
Feb 20, 2007 | Samsung RS2534 Side by Side Refrigerator
Ice cube dispenser not working
I had this problem. The root cause was that mineral deposits had built up in the ice cube tray. The ice would not "dump"... but stayed in the tray after the dump cycle. I did not catch it quickly and eventually the plastic frame broke. That was easily replaced. Inspect the ice tray to see that all cube surfaces are smooth. If there are mineral deposits, they need to be removed. Do NOT scrub with anything abraisive or you will ruin the tray. As you are looking straight on at the Ice maker, with the bin out, depress the small black retangular tab. The tray assembly will come apart to remove the tray. Rinse the tray, then fill with warm vinegar. Let it soak. You may scrub with soft cloth, finger or fingernail to remove deposits. Replace the tray and you should be in business.
Jan 02, 2007 | Samsung RS2578BB Side by Side Refrigerator
Danby DIM1524W Ice N Easy Portable Ice Maker Logo
23 people viewed this question
Top Danby Heating & Cooling Experts
Dan Webster
Dan Webster
Dennis Boxerman
mintvl
Level 1 Expert
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
