Question about Electric Mobility Power Electric Scooter Power Wheel Chair Safety Flag
Charger blew after being repaired
What could be causing the charger to blow? Will a new charger fix the problem or will it blow too?
  • Electric Mob... Master
  • 1,263 Answers
Hi, Could have been a dodgy repair ,,, whoever has not replaced all of the faulty components, I offer a free testing service for chargers, you only pay the return postage...(UK only)
Regards
Rob
www.gewizrepairs.co.uk
Posted on Feb 08, 2014
Charger malfunctioned. Blew tablet inside
As long as it is not an Irulu, take it back for repair. It is Irulu just buy a new one, they are cheap Chinese junk.
Oct 03, 2015 | Tablets & eReaders
How to repair bosch lithium ion battery charger?
how bad.? there is a power supply tech in outskirts of Temple, TX goes by White Lightning on the cb radio.. may find him and see what he charges to fix.
Jul 14, 2014 | Radio Communications
P5113 not charging properly
There are a couple of common problems that can cause bad charging:
  1. Bad charging cable - try a new cable
  2. Bad charger - try a new charger, or try plugging it into a PC USB port overnight with the PC turned on
  3. Charger is not the right charger for your tablet - Samsung devices are known for being picky about what charger you use. If you don't use the original charger that came with the device, or a Samsung charger made for your specific tablet, you will have trouble.
  4. A bad/broken charging port on the tablet - this is not something you can fix yourself. You would likely have to return it to Samsung for repair, or find a local repair shop.
Jan 07, 2014 | Samsung Galaxy Tab 2
Rascal Scooter charger blew twice is it caused by something else or do I just need a new charger. Someone fixed it and it worked 5 minutes.
it is posible the batteries are not installed with the right poles or there may be a short, but more lightly the charger is dud.
Nov 14, 2013 | Electric Mobility Power Electric Scooter...
Rascal Scooter charger is dead
is this a built in charger ??? if not check the resistance between the two outside holes not the middle one, that's the inhibit hole... is there a short ? i never experienced batteries blowing up a charger normally the issue is with the wiring to the batteries....
Regards
Nov 14, 2013 | Health & Beauty
Schematic dewalt de0246
depending on the location of the diode in your charger just try replacing it with a ginaric type diode of the same size, but be forewarned that the diode blew up for a reason and you must first find the cause before you replace it for it will blow again and possibly cause more destruction, is it worth it to you to repair or just bye a new one ?
best regards Falco
Oct 31, 2013 | Drills
Phone car charger keeps blowing fuse
The only thing short of the socket being bad would be the wrong fuse being used, some fuses are special ones.
Dec 15, 2012 | 2004 Nissan 350Z
Plugged the chair into 220v electricity supply. i just wanted to know if there's a fuse that i can change or a circuit breaker that i can reset, and its location. Best regards, Graham D. Jjoseph
WOW!! Big OOPS huh? You probably blew the charger with that jolt. Does your joystick come on at all? Since the charger is connected to the controller or Power Module I hope you didn't blow that up. If you have a digital voltmeter you can set it to 200 volts dc and plug the leads into the 2 outter holes of the charger port located under the front of the joystick. You should read the battery voltage ot 24 - 30 volts. If you don't get anything at the joystick then you will have to remove the seat to get access to the batteries and check the fuses located on the positive posts of each battery. If those are not blown and you still don't have power to the joystick then I'm afraid you blew the controller cause there's no fuse for it. Sorry but if Medicare paid for your chair then you can call a repair service like Roadrunner Mobility @ 1-800-467-2668 or Repair Xpress @ 1-877-581-3733 to have them fix it for you. I might not mention that you plugged into 220 volts tho. Hope this helps
Nov 06, 2010 | Invacare Pronto M51 Power Wheelchair
Blew up something
You must have used a charger that has too much voltage and current delivery. You overloaded the power supply circuits and what you heard blowing up was a capacitor. This is a repairable problem. You must open up the dvd player and see how much damage was done. You can try to replace a few parts that will appear damaged and get a correct voltage adaptor and see if it works. Most likely though you have damaged the player beyond repair. Sorry to give you the bad news. If it is that damaged you should just buy a new dvd player. The cost of the repair and findign the parts will be a lot more expensive than buying a new player. I hope this information help you with your problem.
Oct 11, 2008 | Mintek MDP-1810 Portable DVD Player
Electric Mobility Power Electric Scooter Power Wheel Chair Safety Flag Logo
75 people viewed this question
Top Electric Mobility Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
wcdoc1953
wcdoc1953
Are you an Electric Mobility Health and Beauty Expert? Answer questions, earn points and help others
