Question about Rancilio Classe 6 E 2 gr Espresso Machine
Programacion de tarjeta electronicaa rancilio epoca clase 6
No se como programar los niveles o tipos de face en la tarjerta electronica y la temperatura no la controla la resistencia nunca apaga la temperatura es tambien controlada por la tarjeta electronica
IrishDruid
  • 2712 Answers
SOURCE: Rancilio Epoca DE 2 group espresso machine
It could also be that the solenoid is of the wrong specifications, and hence not getting up to pressure.. Have them check both the temp and pressure cutouts again..
Posted on Jul 01, 2008
EsWorld
  • 1618 Answers
SOURCE: when i turn on my rancilio epoca all the lights keep blinking
That is normal until the machine heats up, its just saying that it is warming up.
Posted on Feb 26, 2009
EsWorld
  • 1618 Answers
SOURCE: Rancilio Epoca S1. Constant click noise??
It is the sound of the pressure stat turning on and off, that is normal.
Posted on Aug 14, 2009
  • 1089 Answers
SOURCE: my rancilio epoca s1 won't start.
HI
Without being in front of it, there are a couple of things to check.
1. There is a reset button on top of the boiler. It is a black top with a red button in the center between 2 wires.
2. The water tank needs to be emptied and then refilled.That is the first things I would check.
Posted on Oct 02, 2010
EsWorld
  • 1618 Answers
SOURCE: my rancilio epoca will not turn on
Sounds like the reset switch tripped, remove top panel and reset red push in switch close to the element.
Posted on Nov 26, 2010
Hola quisiera saver como programar mi segundo television.. Lo que pasa k se me desprogramo como le puedo aser para programarlo nuevamente...
Set-up (Programaci?n) procedimiento es demasiado que escribir aqu?, y no es pr?ctico y se diferir? mandos a distancia de la marca a-marca. Si desea obtener m?s; revisar los sitios enlazados aqu?. Tiene configuraci?n lista de c?digos y procedimiento de establecimiento de que muchos mandos a distancia de la marca popular. Uno entre Tiene c?digos de configuraci?n generales para comprobar con televisores y otros dispositivos se dan, en el orden de la "lista de la marca del dispositivo 'el orden alfab?tico. Tire hacia arriba de las entradas m?s antiguas. Buscar en los sitios por tipo en el nombre de la marca en el dispositivo en el cuadro de b?squeda en la parte superior derecha de la ventana de visualizaci?n. Le ayudar? a encontrar el documento f?cilmente.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Buscar en el sitio por tipo en el nombre de la marca en el dispositivo, en el "cuadro de b?squeda en la parte superior derecha de la ventana de visualizaci?n" para ver los c?digos de configuraci?n para su dispositivo, con diferentes controles remoto de marca.
Aug 16, 2015 | Televison & Video
Necesito los codigos del control remoto dish ir remote 103602 para programar television jvc de 27 pulgadas
Juan Francisco! Mi nombre es Kimberly y formo parte del departamento Social Media con DISH. Se que a este punto quizas mi ayuda ya no la necesite. Le proveere los pasos a como programar el control a su Tv por si en un futuro necesita la informacion. para que su control funcione con su TV, el control tiene que ser programado a la TV. Tendra que hacer lo siguiente: Siga este vinculo, http://www.mydish.com/support/apps/remotecodes.aspx seleccione el modelo de control (este se encuentra en la parte de atras del control) Una vez usted haga esto, seleccione el tipo de aparato al cual necesita programarlo (en su caso es TV) Y despues la marca de la TV. Una vez usted haga esto le aparecesaran los codigos que posiblemente funcionan con su TV. El procedimiento a programar su control es el siguiente Oprima el boton de T.V localizado en la parte de arriba en su control por 5 segundos, despues cuando vea que los botones de arriba se iluminan ingrese un codigo seguido por el signo de numero por ejemplo: 585#. El boton de t.v debe de iluminarce 3 veces, despues de esto puede intentar apagar el televisor, deberia funcionar. Si tiene preguntas adicionales por favor sientase libre de dejarme saber a kimberly.escobar@dish.com
May 10, 2013 | JVC Televison & Video
Necesito programar mi television sanyo pero no tengo control remoto
Hola Rodolfo, para que su control funcione con su TV, el control tiene que ser programado a la TV. Tendra que hacer lo siguiente: Siga este vinculo, http://www.mydish.com/support/apps/remotecodes.aspx seleccione el modelo de control (este se encuentra en la parte de atras del control) Una vez usted haga esto, seleccione el tipo de aparato al cual necesita programarlo (en su caso es TV) Y despues la marca de la TV. Una vez usted haga esto le aparecesaran los codigos que posiblemente funcionan con su TV. El procedimiento a programar su control es el siguiente Oprima el boton de T.V localizado en la parte de arriba en su control por 5 segundos, despues cuando vea que los botones de arriba se iluminan ingrese un codigo seguido por el signo de numero por ejemplo: 585#. El boton de t.v debe de iluminarce 3 veces, despues de esto puede intentar apagar el televisor, deberia funcionar. Si tiene preguntas adicionales por favor contacteme a kimberly.escobar@dish.com.
Dec 26, 2012 | DISH Network IR Remote Control
Como enlazar un control remoto IR 103602 con una caja receptora DishDVR510
Juan Carlos Hola, se que ha este punto quizas no necesite asistencia con la programacion del control. De todas maneras le dare los pasos a seguir en caso de que los llegue a necesitar en un futuro. Para programar el control de DISH Network a su recibidor puede seguir los siguientes pasos: primero debe de accesar la pantalla de System Info esto lo puede lograr con tan solo oprimir el boton que dice System Info enfrente de su recibidor. Una vez este la pantalla de System Info tome su control y oprima el boton se Satellite por 5 segundos hasta que todos los demas botones se iluminen en rojo una vez esto suceda oprima el numero 8 seguido por el signo de numero (#) y despues boton de Record 3 veces. El control deberia de funcionar, puede intentar su funcion oprimiendo el boton de Cancel esto deberia de llevarlo de regreso a su programacion. Puede usar este link que tambien le puede servir mucho en como arreglar su control y los pasos seguir http://www.dishnetwork.com/SupportSection/remote-control
Nov 20, 2012 | DISH Network IR Remote Control
Anomalia electronica en el tablero y tarjeta no detectada
esta coche es una renault ,fin de historia ,concensionario solo .mechanica muy bueno pero los systema electrica ??? mas grande brome en el circulo de los mechanics
Nov 12, 2012 | 2005 Renault Megane 2.0
Codigos de programacion para mi tv tecnomaster
mi televisor teenomaster modelo ttv-2124pf y chasi 01-11-ttv2124pf1026 se bloqueo y solo prende y apaga por el control no realiza ningun mando adicional no cambia ni puedo vajar ni suvir el volumen
Mar 05, 2012 | DISH Network IR Remote Control
Como programar un control de dish para un recividor de dish
Hola mi nombre es Kimberly Escobar con DISH Network. Sera un placer ayudarle proveyendole la informacion que necesita. Para programar el control de DISH Network a su recibidor puede seguir los siguientes pasos: primero debe de accesar la pantalla de System Info esto lo puede lograr con tan solo oprimir el boton que dice System Info enfrente de su recibidor. Una vez este la pantalla de System Info tome su control y oprima el boton se Satellite por 5 segundos hasta que todos los demas botones se iluminen en rojo una vez esto suceda oprima el boton de Record 3 veces. El control deberia de funcionar, puede intentar su funcion oprimiendo el boton de Cancel esto deberia de llevarlo de regreso a su programacion. Puede usar este link que tambien le puede servir mucho en como arreglar su control y los pasos seguir http://www.dishnetwork.com/SupportSection/remote-control. Tambien puede contactarme directamente a kimberly.escobar@dishnetwork.com. Gracias y espero esto le sirva de mucha ayuda.
DISH Network
Kimberly Escobar
Kimberly.escobar@dishnetwork.com
Aug 17, 2011 | DISH Network IR Remote Control
Como puedo programar una tv samsung con el control de dish
Hola! Mi nombre es Kimberly Escobar con DISH Network, sera un placer proveerle la informacion que necesita. Para programar el control remoto a su televisor Samsung hay ciertos codigos que puede integrar al control para que funcionen con la t.v. Los codigos para un televisor Samsung son los siguientes: 738, 516, y el 680. El procedimiento a programarlo el el siguiente: Oprima el boton de t.v localizado en la parte de arriba del control por 5 segundos hasta que todos los demas botones se iluminen rojos, una vez esten iluminados ingrese uno de los codigos seguidos por el signo de numero (#) por ejemplo 738# el boton de t.v deberia iluminarce 3 veces, despues de esto puede tratar las funciones. Si tiene preguntas adicionales puede contactarme directamente a kimberly.escobar@dishnetwork.com
Kimberly Escobar
DISH Network
Aug 07, 2011 | DISH Network IR Remote Control
Tengo problemas con una batidora hobart. hl 600. lellega voltaje a la tarjeta de controles ( velocidad y tiempo) pero no enciende nada y no tengo control de el arranque y paro.
Hola amigo, mi nombre es ramon, a mi me sucedio algo parecido, primeramente debes revisar los 24V Ca en la tarjeta, este es rectificado a 24v cd y 12 Cd quienes son los que alimentan el control, no te desgaste buscando en los interruptores de proteccion, el display debe encender autamaticamente cuando la maquina esta energizada, esto es un defecto al parecer comun en estas maquinas, esta tarjeta tiene un Circuito integrado que alimenta a relay C3 y este a C2, hay varios relay de control los cuales pueden o no activarce pero es fundamnetal que arranque el microprocesador de esta tarjeta, quizas con un poco de tiempo puedas reparar esta tarjeta revisando el relox de control y todos los circuitos de control para el funcionamiento de la misma, hubiera que buscar los datos de estos y hacer una ingenieria inversa para detallar el funcionamiento de la misma, pero para que sea mas facil revisa el cable del puerto de comunicacion entre la tarjeta de mando y el variador de frecuencia, si este esta bueno teniendo continuidad, Ah en este cable hay una linea de color ***** que no se utliza esta solo conectado en uno de los estremos, si todo esto esta bien sustituye esta tarjeta por una nueva la misma esta averiada y si no tienes mucho conocimiento en electronica no la podras reparar o poco tiempo que es lo que sucede a mi, que tenga suerte.
Ramon
Aug 19, 2010 | Hobart HL600 Legacy Stand Mixer
Rancilio Classe 6 E 2 gr Espresso Machine Logo
Top Rancilio Coffee Makers & Espresso Machines Experts
vilhj
Level 1 Expert
andy just round the...
Level 1 Expert
Are you a Rancilio Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
