Question about Keurig B60 Coffee Maker
Lead warning - Keurig B60 Coffee Maker
  • 1,511 Answers
No lead warnings
Posted on Jan 31, 2014
The Keurig Hot K200 has a warning for Canada that the machine contains Chemicals including Lead. Is safe to use or harmful to your health?
anything containing lead is harmful to your health and should be disposed of
Lead in the body causes gum problems and brain damage and accumulates in the body
Feb 19, 2018 | Keurig Coffee Makers & Espresso Machines
Is there lead in this product? I bought some and it came with a Prop 65 warning.
Ask replacements.com for the model / style dinnerware and manufacturer's website. If they can not provide the info you need - return it if you suspect that it may contain lead. If they do provide the manufacturer's info, you should contact the them for their explanation of the lead content (if any is present). Replacements.com may simply be stuffing every box that contains *anything* being sent to CA with this warning to cover themselves - while possible scaring more people than should be. I doubt any stainless steel utensil would contain lead - but who knows!
Mar 23, 2015 | The Computers & Internet
2012 cbr 1000 check engine light 2 slow 3 fsst
warning lamp some used for warn low oil pressure, etc.
Wtith the bulbs use for most warning light circuit it is hard to determine whether or not the filamente is good. Will be a good idea to replace the bulb.
For test the faulty warning lamp, turn the ignition switch to START, this light the warning lamp. I f the light does not come on , disconnect the sender switch lead. . Use a jumper wier to connect the sender witch lead to ground. With the ignition in RUN the warning lamp should light. If the lamp is illuminated replace the sending switch. If the light does not come on,either the bulb is burned our or the wiring is damaged.Use test light for confirm voltage is present at the sensor terminal connector. If there the bulb is bad.
God bless you
Oct 05, 2012 | Cars & Trucks
Why always display ''lead '' fluke 88v
Fluke 88 V displays "LEADS" warning if test leads are in A or mA/uA terminals but switch position does not corespond with those terminals.
Remove all leads and if you still get "LEADS" warning try cleaning all terminals with air. Sometimes dirt gets in A terminals and unit thinks that leads are connected.
Use compressed air or airduster to blow dust from all terminals and hopefully that will fix the problem.
Jan 08, 2012 | Measuring Tools & Sensors
What is the meaning of warning battery exhuasted?
It means the power left in the battery is almost nearing minimum and further it may lead to dead condition. Please charge it as soon as you see this warning message else it may lead to degraded battery life or will not get charged when you charge it with the charger.
Nov 22, 2011 | HP Cameras
Lead in the coffee maker
It does contain a small amount of lead inside a copper coil located in the electronics of the machine. This part does not come in contact with the water, heater or any other part that would cause lead contamination of your coffee.
This page has a great write up explaining it:
http://coffeebreak.today.com/2009/04/08/keurig-lead-warning/
May 24, 2009 | Keurig B60 Coffee Maker
Lead
The boiler is brass, and brass is an alloy that contains lead. Grades of brass used in boilers like this are designed not to corrode, and supposedly do not release lead into the water. You probably already have brass fittings on the water pipes in your house anyhow..
Jan 13, 2009 | FrancisFrancis! X3 Espresso Machine
Warning of lead in keurig coffeemaker
The solder joint in the tubing. Personally, I don't see a risk but the environmentalists see a risk in any lead at all. The plumbing in my house has ALL lead soldered joints. Now, plumbers are not allowed to use lead type solder. If the water just passes over the lead, there is absolutely minimal chance of problems. Keeping wine in a lead crystal decantor will also leech lead into the drink but, you don't hear all the hype about that. It's all about making the earth green. Toy wagons are being recalled because of lead in the paint. I don't know of ANY kids who ever ATE their wagon.
Jan 02, 2009 | Keurig B60 Coffee Maker
The car shakes when in neutral, and also when im accelerating the car is getting held back so its shaking then also. the engine warning light is also on.
Sounds like you have a misfire. basiclly the engine is only running on 3 cylinders instead of 4. The cause of this could be a spark plug, plug lead or ignition coil failure. I would go for the cheapest first, so a new set of spark plugs and leads would not go a miss.
The engine warning light is on because its either picking up the wrong resistance through a coil which indicates coil failure, or its picking up hydrocarbons(unburnt fuel) through the catalyst due to a faulty plug or lead.. If you want the exact source of the fault, a garage can plug a computer into your car and tell you where the fault lies.
Nov 03, 2008 | Fiat Strada Cars & Trucks
Keurig B60 Coffee Maker Logo
176 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
