Question about Toys
Tedco refrigerator gas electric manual
I have a tedco gas electric fridge. Works fine on gas but when i switch over to electric-no go. It says it is a 12Volt 12 Amp system and has a standard plug at the rear which I plug into an electical outlet. This gives me 120volts at the control. How do i get 12 Volts at the control switch?
2 Suggested Answers
d_hawke
SOURCE: I have a tedco gas electric fridge. Works fine on gas but when i switch over to electric-no go. It says it is a 12Volt 12 Amp system and has a standard plug at the rear which I plug into an electical
I also have a tedco older rv fridge and it would appear that the transformer for the electric side has been removed where do I find this part gas side works great and what is the cost for this part
Posted on Jun 07, 2015
110 volts works but 12 volt does nothing, checked voltage 13.6 v. Any suggestions. Thanks.
RV Refrigerator Stop Working? - RVing - Fun Times Guide
rv-roadtrips.thefuntimesguide.com/2009/09/rv_refrigerator.php
If your refrigerator works on gas, but won't work on electric, you may have a burned out.... Cirtis, We are camping in Montana and our dometic refrigerator decided to stop ......Won't know until you can confirm you have proper voltage to the fridge. ... If you have confirmed both 12 vdc and 110 vac power at the fridge, I would ...
[PDF]Dometic Manual Refrigerator Diagnostic Service Manual
www.nationalserroscotty.org/resources/dometic-service-manual.pdf
Dometic Manual Refrigerators. ... 110 Volt Plug. 2. .... This is Dometic's Manual Refrigeration Diagnosis and Troubleshooting program. In this ... we will discuss the way an absorption cooling unit operates, and the ... gas, 120 volts AC and 12 volts DC .....In this condition we are still boiling ammonia but have no hydrogen for.
Dometic Fridge problems - RV mechanic
Dec 28, 2015 | Dometic CF-050DC CF-50 Waeco CoolFreeze...
I have a tedco gas electric fridge. Works fine on gas but when i switch over to electric-no go. It says it is a 12Volt 12 Amp system and has a standard plug at the rear which I plug into an electical...
there should be a small black box transformer wired into the ac cord
that goes to your standard plug
the transformer should then have wires going to your heating element
If someone has removed the transformer just order a 110vac to 12v 12 amp transformer and wire it in like you would a doorbell
when the transformer is working you should feel heat at the rear of your refrigerator at the heating element
Nov 20, 2013 | RVs
I would like to know if a manual exists for a 2 cubic ft. Tedco 3 way RV fridge (1974ish). It works on propane but only sometimes and not on AC or DC although previous owner said it did when he had it and...
here's a site that may help you depending on how mechanical you are. Some basic stuff too, though.
http://www.rverscorner.com/RV_Fridge_Troubleshooting.html
Jan 05, 2018 | Refrigerators
Dometic RM2193 Works on 120V, but not on gaz. I succeded in cleaning the burner jet and I get a flame. It ligth well now but the flame very small. The frig doesn't cool. Help ?
These fridges require that the control switches be in the correct position for the power source you want to use. If you try to operate the fridge on gas and have the electric 120V-AC switch on, all you'll get is the gas pilot light to stay lit. Also, when running on gas, the electric has to be off.
Here's a link to the manual for your unit. Print a copy and save an electronic one for future use, in case you lose your printout.
http://www.alcovr.com/DATA/MANUEL/DometicRefrigeratorModelsRM2191&RM2193.pdf
Hope having the manual helps you to get the fridge working on all the power sources you need! Best regards!
Jul 03, 2009 | Dometic RM2193 Compact Refrigerator With...
Problem with the electric on fridge not working
Hello Paintinfool3,
I have worked on these in the DISTANT past...
They are a great CLASSIC design... Working on gas
means you are 90 to 95% all good
The electric comprises two basic elements
only confused because you have both AC & DC modes.
Just for simplicity sake the ELECTRIC section
(heater & thermostat) section in the BELOW begins
with SECTION 63...
You need a volt-meter with an OHM scale...
(the $9 kind... HARBORFRIEGHT gives away).
There is a yes/no trouble shooting guide.
Also CUSTOMER CONTACT numbers in the very back.
Phone TECH Support at ... 1 (219) 463-4858
Happy hunting!!
http://www.nationalserroscotty.org/resources/dometic-service-manual.pdf
Support Dometic Mobile living made easy
Carnac the Magnificent
Apr 12, 2017 | Dometic RM2620 Refrigerator
Fridge Light - you posted
Your bulb is shorted out internally. Try another bulb. Please post as as helpful if so.TY
Jan 10, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
FRIDGE WILL NOT IGNITE IN GAS MODE
The part you are looking for is the thermo couple. It senses the heat from the flame and holds the gas valve open. The clicking will try three times and then go into lock out. You then will need to reset on the front of the fridge. When installing the thermo couple do not over tighten.
Aug 11, 2008 | Dometic RM2652 Refrigerator
Toys Logo
117 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
