Question about Tablets & eReaders
Tokio tablet froze on android at startup
Brand new tablet.. won in arcade but as it turns on... it freezes on a blank screen with word android.. has been like this since got it??
    Problem Solver:
  • 26 Answers
Sounds like it's cheap junk if you wont it in an arcade.
Probably has an internal memory issue.
Posted on Nov 21, 2013
TechyDrood
  • 2072 Answers
SOURCE: Brand new archos arnova 10 tablet. It is stuck on
To hard reset a tablet, hold the power button down until it shuts off then press it to turn back on. Should take about 5 - 10 seconds for the device to power off.
Posted on Oct 16, 2011
brimknows
  • 10 Answers
SOURCE: my android tablet is "frozen". Will turn on but
has anything been deleted from it when it has been plugged into a computer or has anything been deleted from the device itself from its root directory? if not and its gone like that by itself, it could be corrupted software or a missing root file which is usually bad at first, now what i know about some tablets is if it wont work theres a recovery file usually internally but this is in some tablets only that ive read about, i also have one but havent needed to try to restore it and it can be done from an engineering mode, this is possable by pressing the power button and another button like the home button at the same time once the unit is off untill it turns back on with options, but as for some models im not sure of but i will have to look this up at some stage as i am working on tablets at this time so unless you know what you are doing i wouldnt attempt it, once i have gotten through some tablets ill be able to give a better resolution on this subject with others. the advice ive given wont work for all as pressing power and home will start different options up on different tablets and versions.
Posted on Oct 26, 2011
jrolph621
  • 7 Answers
SOURCE: how do i unfreeze my android tablet after factory reset
let it sit at room temperature until it thaws out :-D
Posted on May 31, 2012
TechyDrood
  • 2072 Answers
SOURCE: galaxey 2 tablet freezes
Press and hold the power button for 10-15 seconds. This should hard reset the tablet.
Posted on Dec 08, 2012
scamper_69
  • 11 Answers
SOURCE: Android tablet stays in Android screen
Try to do a hard reset on the tablet. Since you cannot get to the menu options, you are going to have to do it through external keys. Here is how to do a hard reset using the external keys:
1. Turn tablet off. You may need to use two hands in this process to press and hold buttons properly.
2. Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the manufacturer logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears)
3. "Android Recovery" will appear on top of screen if timing is done correctly. Release volume button. (if you continue to press volume down at that message, the message will cycle through "RSD, Fastboot, and back to Android Recovery. Make sure message states Android Recovery before you go to next step). If stuck at a RSD protocol or Fast boot screen, reboot the tablet by holding power button then pressing the volume up)
4. While screen states "Android Recovery", Press volume up button, the screen will say "Entering Android recovery mode" and a few seconds later an Android robot graphic will appear alone on the screen. Release buttons
5. Hold down power button and then press the volume up key together to see the Android Recovery screen menu selections
6. Use the volume buttons to move up and down through selection in this menu
7. Using the volume down button, scroll down to "Wipe data/factory reset"
8. Tap Power hard key to select option
9. Scroll down to select "Yes, delete all user data"
10. Tap the power button to select. Wiping and formatting data will take a few minutes.
11. You will return back to the Android recovery screen menu.
12. Tap the Power button to "Reboot system now" which will power-cycle tablet and eventually power back on to the Initial Set-up / Welcome screen present when you first turned on your tablet.
Posted on Feb 27, 2013
How do i factory rezet my nobis tablet when its froze and wont go past the nobis emblem screen?
Hi Jeffrey, The link below is a YouTube video showing how to fix your tablet, Also there's video's down the right side of the link that may help as well....CHEERS..
How To fix any Android Phone Tablet that won turn on
Apr 30, 2016 | Tablets & eReaders
What would cause my Kocaso M1050S tablet to be froze on the screen with android across it?
I had a kocaso tablet...M9100. After I Googled it, I found that Kocaso tablets are junk...bought a Google nexus 7...best on the market
Sep 14, 2014 | Kocaso M1050 10.1" Android Tablet PC with...
How do I get into the system?
You may need to reboot your tablet. Try turning it off, then at the same time, Press the "On" button, press the volume up button at the same time. Keep holding till you see the little Android light up, and you should see your tablet come back up. I think your tablet may have froze up on you. Freezing screens is common on these types of devices. Good luck.
May 13, 2014 | Irulu Black 7" 4gb Mid Google Android 2.3...
My Fisher Digital Tablet 7.1 completely stopped working, all the applications already in the tablet won't turn on "Google Market" or anything for that matter. Pop ups saying everything has stopped
I AM HAVING THE SAME PROBLEM, MY FISHER DIGITAL TABLET 7.1 HAS FROZE ON THE INTRODUCTORY SCREEN, I HAVE TRIED THE HOLD VOLUME BUTTON DOWN+POWER BUTTON AND STILL DOES NOT WORK, I HAVE HELD THE POWER BUTTON, PLEASE HELP ME! I HAVE ONLY HAD IT 2 DAYS! :(
Jun 12, 2013 | Fisher Digital New Tablet Pc Android 2...
My brand new Wolvol Android won't even turn on
I recommend you contacting the seller. They seem to have prompt service.
Dec 24, 2012 | Coco Android 2.1 Tablet (837121001186)
Kurio kids tablet is froze
Kurio won't come off blank screen, i've used the reset button, and the power with volume+ button and it's still the little kurio guy making the smiley face. i took the cover off, it's not hot. Any other suggestions as to re-boot it?
Nov 12, 2012 | Techno Source Kurio Kids Tablet With...
Android vimicro logo stuck on screen
ANDROID Tablet Freezes at Android startup screen
For Superpad VI - 10.1" Android Version 4.03, this worked for me!
1. Press & hold START button
2. When "VIMICRO" appears, Then Press & Hold the MENU button
3. The Android System Recovery <3e> Menu should appear
4. Scroll down using the Volume Key to "wipe data/factory reset"
5. Press HOME Button
6. Scroll down to "Yes - delete all user data"
7. Press the HOME Button
At this point the system will do a recovery and hard start, and will be on "reboot system now
8.Press the HOME Button
Your system should reboot normally, but you will need to enter all new data, as it has been wiped clean.
Apr 03, 2012 | Tablets & eReaders
Android tablet screen freezes
I have an apple android tablet and it freezes at the android with black backround
Jan 26, 2012 | Tablets & eReaders
I have a Toshiba Tecra M7 that won't boot and up until this morning nothing worked. This is what I've done so far this morning WHEN it does decide to boot. 1. Power up computer from off with ESC...
Your hard drive may have gone south. Remove it and check with diagnostic software. Bad sectors in critical areas of operating system data will do this.
Apr 01, 2017 | Toshiba Tecra M7 Tablet PC
Tablets & eReaders Logo
395 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
