Question about Fuji FinePix A330 Digital Camera
Zoom button broke on finepix A330 camera
My camera`s zoom button will work when you push it down but not up. It`s really frustrating because I cannot delete pictures or use the zoom. Is there anywhere I can get this fixed?
  • 1 more comment
  • kunk Apr 13, 2008
    I have the same problem: I can't scroll down in the menus and now the camera is locked in some sort of low-lighting mode!!
  • brendan0 Nov 04, 2008
    My friend's A340 (A430??) has the same prob. And after 3 years, mine has JUST developed same fault - zoom button goes up but not down.
    Since my camera's old and not worth much, I'm tempted to take it to bits...but then again, everything else works well!
    Doesn't seem worth forking out for prof repair.
    Unless someone out there knows better! Is it easy to do? Quick?Can I order a replacement switch and fit it myself?
    Brendan (and all the other non-zooming Finepix owners!)
  • fowlerfam Dec 02, 2008
    I have the same problem. I think my son might have dropped it when he was using it. For awhile I could zoom in but not out, now both out and in are broken. I am bummed because this means I can't erase pics anymore (uses same button as zoom) so I think my camera is finished. Has anyone tried taking it apart? I think I could hear a teeny rattling in the camera after I noticed the zoom no longer worked. I think there must be a broken piece in there? Help?!
  • 4,889 Answers
The best thing you can do is get to the nearest service centre.To find one in your location click on the link, scroll down to the end of the page and choose your region, Country/area, And topic from the dropdown menu and you will get the contact info of the nearest service center.
Posted on Oct 08, 2007
How do i take camera apart
perhaps you fine help on There they take apart lots of camera's and show the video or even a manual. They also help with buying spar parts and tools if you need some.
Jul 19, 2014 | Fuji FinePix A330 Digital Camera
Is the firmware for fuji finepix A607 the same
Heres the support site for that camera - theres no firmware listed I would not use the A330 firmware although considered identical - Its NOT it is identical to the A330, except for the fact that it uses a Super CCD sensor instead of the standard / conventional sensor in the A330...
why do you want to update the firmware ?
Apr 10, 2010 | Fuji FinePix A340 Digital Camera
FinePix A330 "CARD ERROR"
As long as the card is not an "H" or "M" type card (new configuration, not compatible with your camera, all you need to do is perform a "format" via the setup menu. That will prepare the card for use, however it will erase anything on it.
Aug 26, 2009 | Fuji FinePix 2800 Zoom Digital Camera
Zoom error the zoom will not comeout when the camer is urned on, is this somethinbg i can fix
No - it is broken..,
Unless you have a good camera shop near you, it will probably cost more to fix than replace.
Aug 20, 2009 | Fuji FinePix A330 Digital Camera
Lcd screen stuck in usb mode?
Try removing batteries and card and leaving them out for a while to allow camera settings to default.
Replace batteries only and see if you get "Card Error" message.
If you get this, then try again with card fitted
Check firmware version
Possibly card storage too big. Upgrade firmware to version 1.77
If you have no user manual there is a PDF version available to download here:
All the error messages are given in the manual with possible solutions.
Aug 25, 2008 | Fuji FinePix A330 Digital Camera
Card not initialized
Try removing card and cleaning contacts with a soft dry cloth.
Reformat and try again.
PDF manual can be downloaded if you do not have printed copy
Error messages and possible solutions to try are given in the manual
Aug 21, 2008 | Fuji FinePix A330 Digital Camera
Fuji Finepix Z1 Zoom Error
I saw another post in this forum were someone suggest banging it on a table a couple times, not to hard that you'd dent it but a good enough bang. Worked like a charm! I tried the trigger and slide method but while the error message went away the zoom wouldn't focus. Try banging it, it sounds bad but it worked wonders!
Mar 06, 2008 | Fuji FinePix Z1 Digital Camera
Kyle850. I have a fujifilm finepix camera myself, and just recently had the same problem. The camera worked fine until one day I turned it on to take a picture and there was the "card not initialized" message. To fix the problem, just turn on your camera, push the menu button and use the right/left arrow buttons near the zoom button in the top left corner of the camera. Push the right arrow button until you come to the "option" window in the camera's view finder and use the "up" function of the zoom to highlight the "set-up" window. Press "ok", and use the right arrow button scoll over to the "2" tab and press the ok button again. Then use the "up/down" function of the zoom button to scroll down to the "format" tab. Press ok button again and use the "left" button near the zoom in and out button to highlight the "ok" option in the format window. By pressing the ok button here, it will reformat and reinitialize your picture card. If you do have pics already on your pic card, you may want to take your pic card to a photo center and see about recovering these pics before you go through the reformat process because there is a good chance that when you reformat your pic disk any pics on it will be gone. Good luck. SG
Feb 26, 2008 | Fuji FinePix 30i Digital Camera
HELP! Zoom Error?
Common fix is to remove batteries hold the power on button down for five seconds and then try it.
I take it the lens isnt off true / loks straight?
Nov 13, 2007 | Fuji FinePix A330 Digital Camera
Fuji FinePix A330 Digital Camera Logo
141 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
