Question about Clarion Car Audio & Video
Connection diagram MODEL No. PN-2165M - Clarion Car Audio & Video
Ford 1700 tractor. Wont start unless clutch is depressed.
Hey Ray,
I would think this is normal... its a safety feature..
Sep 25, 2017 | Ford Garden
Where can i find sears pn 192749 diagram
Seat switch electrical diagram. For full electrical diagram post back using the equipment model number.
Jul 31, 2014 | Sears Garden
I have a 1997 niss maxima infinity am/fm/cass/cd model pn 2213n i would like to know the power wire colour and the ground wire colour that come out of the radio
NISSAN 1997 RADIO MODEL PN-2213N AM/FM/CD/TAPE PLAYER SERIAL NO 00068783 MANUFACTURED 8116 JUNE 1997
DEAR SIR
my nane is wayne and i am looking for the wiring diagram from this radio any help would be very thank full
Sep 05, 2011 | Car Audio & Video
Replacing oem car radio/CD (Clarion PN-2165M I) from 2002 Nissan Sentra GXE. I ordered Scosche Car Stereo Connector to avoid cutting OEM connector. Im confused about the OEM Radio/CD wiring colors as to...
2002 Nissan Sentra Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Pink
Car Radio Switched 12v+ Wire: Blue
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Red/Green
Car Stereo Dimmer Wire: Red/Yellow
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Blue
Right Front Speaker Positive Wire (+): White
Right Front Speaker Negative Wire (-): Black
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Light Green
Left Rear Speaker Negative Wire (-): Violet
Right Rear Speaker Positive Wire (+): Blue
Right Rear Speaker Negative Wire (-): Pink
May 25, 2011 | Clarion Car Audio & Video
I have model no. MMV1153BAB and my coupler(pn
The exploded view diagram shows just the motor, coupler, roller, and glass tray.
Unless you were given the wrong parts, I'd say the motor may not be mounted up in the proper position.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.This one is made by Samsung for Maytag / Whirlpool. Here are the Samsung part numbers from the exploded view / parts list and the Samsung parts are cheaper than the Maytag numbers, and you can order them here.
REF PART # DESC
24 DE31−10104D Motor, Turntable
25 DE67−00180A Coupler, Glider
26 DE97−00192C Guide, Tray
27 DE74−20015G Tray, Cooking
May 02, 2010 | Microwave Ovens
Deive gear is gone. Where can I order one for a model m30016
I found an IPL for your saw here:
Remington.com
http://shoppingcart.msservicecompany.com/Default.aspx
  • Type "YourModelNumber" into the "Search for your unit by Model:" window, then click search.
  • Click the “YourModelNumber” - Remington Electric Chain Saw "View Model" link.
  • Click “View Owners Manual” or "View Illustrated Parts Diagram" link.
  • Type "YourPartNumber" into the “Search for your parts by Part #:” window, then click search.
Your saw Illustrated Parts Breakdown
http://shoppingcart.msservicecompany.com/msservice_net/product_files/113005-01D/113005-01D_PL.pdf
Item 18; pn 113004-01; Sprocket Gear changes to pn 122513-01; Price $24.
Item 19; pn 059606-02; Drive Gear Price $7.25; Back Ordered - forever?.
Master Distributors
http://www.masterparts.net/remingtonelectricchainsaw.html
pn 122513-01; Sprocket Gear Kit (pn 113004-01, 075676 (Bearing) & 059606-02) ; $18.99 Appears to be available. I would waste little time ordering this.
You could have added this to your previous question as I asked. Then I could have provided a complete answer and my rating been Very Helpful, as this one should be. It can still be changed, Ratings and a few kind words are our only payment. I probably invested 1.5 hours getting to this point.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Apr 05, 2010 | Remington Electric Chain Saw
Chain oil pump does not work when pumped. Eager ****** MAC 100 series
Your Eager Beâver model number is 600016. There are many prefixes and suffixes. The one below I used when repairing a similar problem with my Mac 110 (earlier version of your saw). Both the automatic and manual oilers work now.
I get the best results for new McCulloch parts here:
This is a little complicated so I am going in small steps.
M & D Mower
http://www.m-and-d.com/parts.html
Click “Illustrated Parts Diagrams ON LINE”
Click “Click Here for Parts Lookup”
Changes to “Select OEM” Window reads “Briggs & Stratton ▼” Click the arrow and select “McCulloch Power”
Click “Gasoline-Powered Chain Saws”
Click “18-600016-27”
There is a shipping and handling charge from M & D (about $9) if all parts in same container only one fee.
See “General Assembly” print
Item 33; pn 85557; Oiler body; most likely failure, on bottom of Item 31
Item 31; pn 217755; manual oiler piston; It pulls through the top of the tank. I ordered a new one but got Item 36, they were the same pn, I complained, seems they fixed it.
See “Powerhead Assembly” print
Item 07; pn 219989; oil pump assembly
Item 04; pn 217168; pump/bar pad connector (hose)
Item 05; pn 217167; pump/oil tank connector (hose) The new one was to long, I used the old hose. I have an earlier model.
Item 17; pn 110653; O-ring
Lou
Mar 06, 2010 | McCulloch Garden
Clarion Model #PN-9881l plug wiring
yellow battery
red accessory
black ground
purple right rear + speaker
purple/black right rear -
green left rear +
green/black left rear -
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
blue auto antenna
blue/white rem amp
brown phone mute
orange/white illumination
grass green handbrake but if u want to play dvd's
whilst u drive connect this to earth
pls rate people arnt rating hope this helps
Jan 11, 2009 | Clarion XA-311 Cassette Player
Car Audio & Video Logo
44 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
