Question about Bosch Classixx KGV28323 Bottom Freezer Refrigerator
Thick ice build up in freezer - Bosch Classixx KGV28323 Bottom Freezer Refrigerator
Frost free fridge freezer build up of ice
The defrost timer has quit.
They have a relatively short life.
Jul 25, 2015 | Hoover Refrigerators
How to stop ice building up in freezer
Ice buildup is generally caused when you have a leaky door seal. Make sure that the door seal is intact and the door is properly closed. Another cause could be that the tube to the ice maker has detached. Hope this helps
Dec 06, 2014 | Refrigerators
Fridge not staying cold and build up of ice on back piping
One of you fans is not running and causing the compressor to eventually making your compressor overheat and eventually shut off
Apr 14, 2013 | Refrigerators
Ice crystals forming on inside front freezer panel
Very possible the door seal is not properly sealed. Warm inflowing air onto a cold coil will cause ice build up at the lid.
Oct 08, 2009 | Kenmore 22.7 cu. ft. / 643 liter Chest...
Thick ice build up behind freezer fan
check door rubber,if is oblate heat it with fan,if it is ragged change it.
Jun 29, 2009 | Freezers
Neverending ice cystals buildup in freezer
Hi Rachel,
Opened 3-10 times per day, per week, per month?
There is only one possible source of these ice crystals -- moisture precipitating from the air (condensate) -- this air is coming from outside the freezer. It's either getting in when the freezer is opened or coming in around the gasket.
You might try a very thin coat of vaseline on the gasket to get a better seal.
Charlie
May 07, 2009 | Refrigerators
Fan in freezer very loud noise
There is probably an ice build up behind the plastic rear panel. The ice build up gets so thick that eventually, it obstructs the fan and then you get that loud noise as the tips of the fan are chipping away at the ice.
What you need to do is to remove the rear panel and thaw the ice build up. To remove the rear panel is usually only 2 screws at the bottom.....you will find that the panel is difficult to remove due to ice build up behind it, so gentle heat from a hairdryer is a good way to accelerate the thawing process....once the panel is removed, you will see the ice build up......mine was about 2 inches thick!!!
I used the hairdryer to thaw it all out and then once cleared, switched it back on and have never had a problem since.
By the way, my F?F is a Beko CDA563FS......the one with the water dispenser on the front and frost free.
Hope this helps
Feb 01, 2009 | Freezers
ICE BUILD UP ON THE BOTTOM OF MY FREEZER BELOW THE LAST TRAY
clear ice and with hot water pour into the drain hole till open and drains ,, take back panel of freezer out and wrap a piece of thick cooper wire around the heater and drop into the drain hold about 1in and it will keep drain open / thanks
Jan 14, 2009 | Maytag MSD2732GR Side by Side Refrigerator
Ice build up on the freezer floor then leaks out the door
thats the THERMOSTAT , is defective , this unit is connected underneath the freezer floor , when you remove it your gonna see like a black thick line running all around the freezer floor ,every 4 or 6 hours this line heats up avoiding ice to build up on your freezer. hope this info helps
Apr 18, 2008 | Refrigerators
Bosch Classixx KGV28323 Bottom Freezer Refrigerator Logo
16 people viewed this question
Top Bosch Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
