Question about Lionel Trains Holiday Express G Gauge Train Set
Lionel holiday special g gauge train set
Battery operated (size C), won't move, play Christmas carols, nothing. Batteries are new, but there was some corrosion that I attempted to fix using baking soda and vinegar.
4 Suggested Answers
  • 4 Answers
SOURCE: Remote is not working for my Lionel Holiday Tradition Express Train with new batteries. Any suggestions?
I rewired my train this weekend..it now works on my outdoor setup....I found that the circuit board inside the engine had a blown capacitor and the power transitor was fried. I by passed the engine board found that it only would run backwards....went into the tender and taped into the power from tack bypassing the rectifer... By the way the engine does not start up when one uses the remote...there is a 20 second delay before starting
Posted on Nov 29, 2011
SOURCE: i bought the set last year of holiday lionel
If all cars are not properly on the track, the engine does not have enough power to pull the cars. Try with engine and coal car only to zero in on cause.
Posted on Dec 27, 2009
SOURCE: WE are trying to get our lionel holiday train
There is no on/off switch. Remote will give no indication of working. Try putting engine and coal car only and try. I have had this train set for two years and the remote tends to work whenever it wants.
Have power to the track loco cab light turns on red bow lights up but train dosent move at all. No bell or ho ho and nothong on any of the other cars
Try new batteries in the controller Be sure they are in correct. The LED light should come on when it has power. Try moving closer to the train. Usually when the red light is flickering is when there is an engine problem. But here is the Manual just in case you did not have one. Also it has a number for lionel Service in there. Good luck. =) http://www.lionel.com/media/servicedocuments/60287110222501.pdf
Sep 30, 2014 | Lionel Trains Holiday Express G Gauge...
Lionel 6-30218 not working,The engine is making hissing sound the headlight bulb is glowing the cab cars have light ,The remote Red Light is glowing when turnig the knob of throttle to right & lef
Your best option is to contact Lionel Customer service:
598-949-4100 ext. 2
9AM - 5PM Eastern Time Zone
They will give you instructions if they think it needs to be sent in for repair.
Jun 02, 2014 | Lionel A Christmas Story Gauge Train Set...
Have a lionel holiday tradition express. Lights are on, but train won't sing or go forward. Changed batteries and nothing.
Have you let the loco charge first? The instructions are a bit vague but the loco needs to charge before it runs. Not easily understood from the instructions and many have spent some frustrating minutes wondering why their train wouldn't move.
Nov 12, 2013 | Crafts & Hobbies
Help please. Lionel (30190) Thomas & Friends remote O gauge. Train won't move. Light comes no, nothing. I took the roof off and made sure the switch was in the on position. ??
First, check to make certain that the batteries in the remote are good.
Second, if the train has been running and the problem is new, clean your wheels and pick up roller on the locomotive, then clean the track.
Make certain that when you use the remote, you orient the antenna in an upright position and are within 6 to 8 feet of the locomotive.
If none of the above helps, contact the Lionel Service Department.
586-949-4100
Oct 07, 2013 | Lionel (31956) Thomas The Train Set
Lionel battery operated g scale locomotive will not move
Replace all batteries in locomotive & remote.
You do need to be fairly close to the set with the
remote for it to work.
Jan 19, 2013 | Lionel A Christmas Story Gauge Train Set...
New bright santas christmas express no, 187 train wont smoke
This goes back about 40 years for me. Both Lionel and TYCO had "smokers" in their train sets. My recollection was that the "special smoke oil" was a mixture of very highly refined kerosene and parafin wax. Try a hobby shop such as Hobby Town or some such.
Nov 27, 2012 | New Bright 384 Holiday Express Animated...
Nov 27, 2011 | Lionel 11000 Holiday Tradition Express...
We have changed the batteries 3 times in both controller and engine. We have sound and light on engines but no movement of engine. What can we do to troubleshoot? 71-1163-250 manf. China 7/09
I bought this set for my grandson and had no problem. The booklet says to make sure all screws on the battery compartments are tight, and they are fresh batteries installed properly. Then i saw this post on another website:
http://screamingreviews.com/lionel-little-lines-freight-set-review-this-toy-train-christmas-present-was-a-big-hit-with-the-kids/
"The plastic train was another matter. I went through several sets of batteries trying to get the thing to run. No matter what I did it wouldn't run right. It didn't do anything. Then I took it apart and found that there was a sticker that indicated which way the batteries were supposed to go in and the sticker had somehow become lodged covering the battery contact on the inside. This is why nothing worked. Once I removed that sticker and replaced the batteries everything worked perfectly."
Look carefully at all contact surfaces to see if anything plast ic blocking the metal.
If all else fails and you can't return it, I would be interested in buying more track for my grandson! kohls@juno.com
Dec 31, 2010 | Lionel Little Lines Train Play Set...
I bought the set last year of holiday lionel trains g replaced batteries, have light on remote and noise from engine but no movement? any ideas
Dec 23, 2009 | Lionel Trains Holiday Express G Gauge...
WE are trying to get our lionel holiday train going. Is there an on/off switch on the train? the part that goes on the track is lit up but when we puch the remote control with train on the track nothing...
Lionel Trains Holiday Express G Gauge Train Set Logo
78 people viewed this question
Top Lionel Crafts & Hobbies Experts
Jeff Hogancamp
Jeff Hogancamp
J.D. Browning
J.D. Browning
ray gallant
Are you a Lionel Craft and Hobby Expert? Answer questions, earn points and help others
