Question about Kodak Digimaster Ex110, Same As Canon Ir 7110 Copier,ir7110vp Printer
Kodak I1X09 fault code - Kodak Digimaster Ex110, Same As Canon Ir 7110 Copier,ir7110vp Printer
    New Friend:
  • 3 Answers
I1X09 One Line Description: INSERTER SUPPLY 3 stalled when it was moving down Error Type: Soft Shutdown Error Description: If the ELEVATOR STEPPER MOTOR uses more than 130% of the maximum number of steps to move the PLATFORM of INSERTER SUPPLY 3 down to the expected position, the INSERTER SUPPLY CONTROL BOARD determines that the PLATFORM has stalled. An I1X09 error code is recorded in the error table and you must either use another INSERTER SUPPLY or press OK on the OCI to clear it. Theory guide: I1INSER1 Possible Causes:
1 The input to LOGIC and CONTROL from the DOWN LIMIT SWITCH is not correct. 2 The input to LOGIC and CONTROL from the PAPER FED SENSOR is not correct. 3 Mechanical binds in the ELEVATOR DRIVE SYSTEM 4 The input to LOGIC and CONTROL is not correct. 5 The FLAT CABLE is damaged. 6 Circuit for the ELEVATOR STEPPER MOTOR is not operating.
Posted on Jan 16, 2014
Need to know what is error code external hardware fault in scanner -312472374 mean for a kodak 2500ds
http://graphics.kodak.com/DocImaging/US/en/Products/Document_Scanners/Departmental/Scanner_2500/Support/User_Manuals/Scanner_1500_amp_2500_Image_Processing_User_s_GuideImage_Processing_for_Scanner_1500_and_2500_User_s_Guide/index.htm copy and paste this link and download the manual see if that will help you and heres the support center phone number its the best I can do for you 1-800-822-1414
Feb 02, 2015 | Kodak Office Equipment & Supplies
My kodak dx6490 keeps showing error l-02
Hello Lester, These Kodaks use codes for diagnostic reasons, they will show a code when there is a reason for service. They are used by the tech for diagnostics just like your vehicles fault codes.
Best Regards, Russell
Nov 15, 2012 | Kodak EasyShare DX6490 Digital Camera
Kodak Easy Share CX7430 camera error 603
the fault code #603 means your computer and camera are not talking to each other this is a software problem download your kodak driver again after you have uninstalled it this will fix your problem
merry christmas
sonic boom electronics australia
please take time to rank this advice
thanks
Dec 24, 2010 | Cameras
E code is flashing on my printer, how do I fix
The printer contacts do not connect with the printhead contacts. The contacts may be dirty; the best way to clean the contacts is by reseating the printhead multiple times. . If that's doesn't work you will need to contact Kodak for a new printhead. Log onto www.kodak.com and find the relevant support team. Give them a call. The warranty on your AiO is 15 months so be sure to make your printer in warranty ;-). (By the way, most of the agents are happy if you tell a little white lie about your printers warranty coz it gives them less work. Also remember begore calling, ITS NOT THE AGENTS FAULT THAT YOUR PRINTER BROKE!!!
May 06, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Keep getting a code 1312x17x4252799284x and want install program.
I?m not sure if you?re fault code is showing on the computer, Easy Share Software, or the camera itself. Therefor I will list 2 possible solutions: If the fault message is on the LCD on the camera: There is no firmware available online for this camera model. Therefor you do need to set up a "repair" with KODAK directly. An Out of Warranty repair for this model for this fault is about 88 pounds + shipping. KODAK also offers a Trade up option where you will have the opportunity to trade up to a newer model 25-30% cheaper than the market price. In order to arrange your repair/Trade up: Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490 If you're experiencing this fault code on the computer: Please do a Clean Install on the Easy Share Software: Please follow the instructions: Uninstall Easy Share software: Select Start > Settings > Control Panel > Add / Remove Programs. For Windows XP operating systems, select Start > Control Panel > Add / Remove Programs. Select Kodak Easy Share software. Select Remove (or select Change, and then select Remove). Run the Clear utility: Visit the CLEAR Utility for Kodak Easy Share software Web page at www.kodak.com/go/clear Click the Download button, and then follow the on-screen prompts. After restarting your computer, visit the Kodak Easy Share software Web page at www.kodak.com/go/easysharesw and install the latest version of Easy Share software.
Jan 20, 2010 | Kodak EasyShare One Digital Camera
Device driver was not successfully installed. Why?
I?m not sure if you?re fault code is showing on the computer, Easy Share Software, or the camera itself. Therefor I will list 2 possible solutions: If the fault message is on the LCD on the camera: There is no firmware available online for this camera model. Therefor you do need to set up a "repair" with KODAK directly. An Out of Warranty repair for this model for this fault is about 88 pounds + shipping. KODAK also offers a Trade up option where you will have the opportunity to trade up to a newer model 25-30% cheaper than the market price. In order to arrange your repair/Trade up: Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490 If this fault message is on your computer, Easy Share Software: Please do a Clean Install on the software: Please follow the instructions: Uninstall Easy Share software: Select Start > Settings > Control Panel > Add / Remove Programs. For Windows XP operating systems, select Start > Control Panel > Add / Remove Programs. Select Kodak Easy Share software. Select Remove (or select Change, and then select Remove). Run the Clear utility: Visit the CLEAR Utility for Kodak Easy Share software Web page at www.kodak.com/go/clear Click the Download button, and then follow the on-screen prompts. After restarting your computer, visit the Kodak Easy Share software Web page at www.kodak.com/go/easysharesw and install the latest version of Easy Share software.
Dec 06, 2009 | Kodak EasyShare V1073 Digital Camera
Easyshare Z612 with an error code of #e45
Itøs a lends error. There is not much else to do than to send it in for repair or go for a trade up.
OoW repair for this model w. this fault: 88,07 Pounds.
Contact KODAK:
Nov 14, 2009 | Kodak EasyShare One Digital Camera
Camera code e45
Lense fault. It requires a repair, however due to spare part shortage KODAK no longer repairs this camera model. Instead they offer a trade up: Since you have a KODAK model. They will offer you a current model for 25-30% less than market price.
Contact KODAK:
Nov 14, 2009 | Kodak EasyShare LS743 Digital Camera
Kodak easy share printer dock series 3 faults
got same error, took the clear cover off the paper cartridge and kinda' force fed the paper thru. To my surprise...it worked.
Jul 02, 2009 | Kodak Office Equipment & Supplies
I have a kodak dx 6490. when i turn on the camera display shows error-L02 what is this.
Hello, You have just joined the ranks of many other owners,This code means your camera has a fault code and needs to be checked by a qualified repair person to determine the cause of the fault.
Best Regards,Russell
Jan 13, 2009 | Kodak EasyShare DX6490 Digital Camera
Kodak Digimaster Ex110, Same As Canon Ir 7110 Copier,ir7110vp Printer Logo
54 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
