Question about Cuisinart DLC-2 Mini Prep Plus Food Processor
The blade quits spinning but you can hear the motor running
Cuisinart mini-processor, motor runs but blades get stuck and motor just spins? I tried replacing blade, no help
The set screw on the blade assembly is loose. If the motor does not spin then that is a different story.
Nov 24, 2016 | Cuisinart Food Processors
Hello there my food processor will not spin hear motor running lights on to go but no spin??
Post model no on line probably the rubber drive on the motor
they fall apart over time.found on line about 3or 4 dollars
Jun 19, 2015 | Kenmore Food Processors
Blade of cusinart dlc 7 superpro food processor will not spin when food is in the bowl- works when no food is in it. Is it is the stem? How do I replace it?
It'll probably cost more to fix than replace. If you have a collection of blades, maybe find one in working order on a shopping site and meld the two together. Happy hunting! Happy New Year!!!!
Jan 01, 2015 | Food Processors
My food processor blade keeps popping up (loose) when I put food into it.
You will probably need to replace the sleeve on the motor shaft and the blade. If overloaded the shaft can spin inside the blade which wrecks the connection between them. Replacing both together is the correct solution.
May 16, 2014 | KitchenAid Chefs Chopper KFC3100 3 Cups...
Spindle / shaft or mixer bowl?
if you say the motor is running but no blades moves in the cup.it means the shaft which is connected to the blades and the motors break down.
so i refer u to open it and check which shaft part is broken,or take it to the mechanic.
Jan 05, 2014 | KitchenAid KFP740 Food Processor
The motor post on my food processor has deteriorated to the point my blades will no longer turn (just sit there)Can I replace that part ?Or is it too hard for an amature fix it upper?Is that post even...
If the motor is running, the problem can be that the motor shaft is spinning inside the drive sleeve. Replace the sleeve. That is more common than a motor failure.
Nov 30, 2010 | Cuisinart DLC-7SFP Pro Food Processor
Motor works but blade does not spin. When I press down the glass while motor is running, it will spin a tiny bit but then stops.
check the interlocking part on the bottom of the blade piece. This part can wear down and then not interlock properly therefore it does not spin anymore. You can buy a new one from the website but it costs $30 and it comes with a bunch of other stuff. It's called the deluxe upgrade kit.
http://www.buythebullet.com/
May 11, 2010 | As Seen On TV Magic Bullet Food Processor
Stopped working
The motor has a plastic gear that breaks easy. It is hard to find, but the solution is to replace the plastic gear.
Dec 22, 2007 | Regal Ware K813BK La Machine Food...
Cuisinart DLC-2 Mini Prep Plus Food Processor Logo
59 people viewed this question
Top Cuisinart Food Processors Experts
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
Are you a Cuisinart Food Processor Expert? Answer questions, earn points and help others
