Question about Jackson 25 in. Conserver XL Free-standing Dishwasher
ES2000 runs continuous timer not rotating - Jackson 25 in. Conserver XL Free-standing Dishwasher
Won't shut off
Timer comes with 1 year warranty:
KM-series dial should rotate continuously, no matter which mode.
Is this new timer? Maybe wiring is wrong
http://waterheatertimer.org/How-to-wire-timers.html
Buy another timer:
http://waterheatertimer.org/Woods-timers-and-manuals.html#KM
Gene
h
Nov 16, 2013 | Intermatic KM2ST-1G - 24 Hr. In-Wall...
Is the aspect ration of this Canon ES2000 4:3 or 16:9???
Yes, the aspect ratio of the ES2000 is 4:3.
Apr 05, 2012 | Video Cameras
An electrician installed a new Tork 1103 24 hr timer for the pool pump. You can only manually turn it on and off. When trying to set the time, the dial is loose and does not stay in position and does not...
I think you have 120Volt pool pump.
Add a comment if this is incorrect since wiring information is based on this assumption.
(1) Wiring problem:
Evidence shows timer is wired in reverse (dial only rotates when pump is ON, and dial stops rotating when pool pump is OFF)
Electrician reversed the wires, but wires need to be tested.
Hot wire from circuit breaker always connects to L
Neutral wire from breaker box connects to unmarked terminal.
This will give clock motor continuous power.
Next:
Black wire going to Load (pump) connects to X
White wire going to Load connects to unmarked terminal along with Neutral wire.
Tork 1103 is SPDT timer with 3 watt 120volt clock motor that can control multiple loads and voltages, and can be wired many different ways.
http://waterheatertimer.org/Tork-timers-and-manuals.html#1101
http://waterheatertimer.org/pdf/1103INSTALLOP.pdf
(2) Loose dial. The dial should only rotate counterclockwise when moved with hand. The fact that trippers work when rotated by hand says dial is probably not problem. If timer is used, and trippers skip over and do not turn on Load (pump) then order P47 replacement trippers.
http://waterheatertimer.org/images/Tork-1102-3-500.jpg
Aug 07, 2011 | Hardware & Accessories
Where can I find the manual for the Intermatic Incorporated Timer, Spst-125V 24Hr Mechanical 2 On/Off - PB913N84
There is no manual specific to the PB800-900 series timers.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#PB
http://waterheatertimer.org/pdf/Intermatic-PB800-PB900-timers.pdf
Timer uses 107TTN222 ON tripper and 107TN221 OFF tripper.
Push trippers onto dial at times you want timer to turn on-off.
Rotate dial until current time lines up with arrowhead located in center of timer dial.
images show that timer has override knob that can be rotated.
Timer has 4 terminal connections. 2 connections are for 120Volt clock motor, and 2 terminals are the switch for turning Load on-off.
Black hot wire and white neutral wire connect to clock terminals.
Switch terminals are dry.
Dry terminals mean they have no power when wires are connected to clock motor.
The switch terminals wire just like ordinary light switch: Power connects to one of the terminals, and wire to Load connects to other terminal. Neutral wire does not connect to switch terminals, just like wiring an ordinary light switch.
Offhand I do not know which set of terminals is for clock motor.
Use continuity tester on each set of terminals.
Clock terminals will show continuity at all times, no matter which position override knob is set.
Switch terminals will show continuity with override knob in one position, but not the other position.
Jul 04, 2011 | Intermatic TIMER,SPST-125V 24HR MECHANICAL...
We have installed GM40 time. which control shaft on / off cycle i.e 4 hours on / 2 off. i checked selector switch postion, i.e continuous on (upper position) and continuous off (lower position) in this...
I have GM40 timer sitting in front of me.
I cannot understand your question because I do not know what the 'control shaft' is.
If you mean the black-colored FM1 clock dial with captive trippers, then this dial is supposed to rotate continually as long as timer has power.
http://waterheatertimer.org/images/FM-1-Grasslin-Intermatic-20.jpg
Grasslin/Intermatic GM40 page
http://www.intermatic.com/products/grasslin/electromechanical%20time%20switches/multi-voltage%20time%20switches.aspx
The manual says quote:
With the manual switch in the middle position, the GM40 is in automatic mode and will switch at the programmed times. In the upper position "I", the load is permanently ON. In the lower position, "O", the load is permanently OFF. End quote.
In any switch position, the FM1 clock dial will continually rotate.
If your Load does not turn on-and-off according to the trippers set on FM1 clock dial, then 1) wiring is suspect or 2) if dip switches are not correctly set before applying voltage, and timer could be damaged.
The timer arrives with dip switches pre-set for 277Volts.
You can also manually rotate clock dial clockwise to observe when the load turns on-off.
Add a comment and give more information.
I would like to know what the 'control shaft' is, and what voltage you are using, and what dips switch setting you have, and which wires are connected to each terminal.
Apr 13, 2011 | Intermatic GM40 - 24 Hour/7-Day Dial...
I want to reset the timer for hours of on-off for out water heater but can't figure out how to push the little white teeth in or out. Model is 265-1.
1) Open following link to read about re-circulation systems:
http://waterheatertimer.org/Water-heater-recirculation-system.html
2) Image below show typical FM1 analog timer dial with pins:
Move pins with fingernail or small tool.
To test if pins need to be moved in or out, set pins each direction and manually rotate dial clockwise and listen when pump turns on-off.
How timer operates: clock motor rotates dial continually, pins on dial move lever that turns circuit on-off.
To set current time, manually rotate dial clockwise until current time lines up with arrowhead located on inner dial.
Some timers have a selector switch: move switch to Auto, or Timer, or Timer ON. Again you can manually rotate dial and check which setting is correct.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 14, 2011 | Taco 265-1 / 563-2 Combination Analog 24...
How do I use SKU: 15112 timer
GE 15112 timer manual:
http://www.jascoproducts.com/support/manual-downloads/applications/DocumentLibraryManager/upload/Outdoor-15112-Manual-eng-spn.pdf
Same as Tork 652A manual
http://waterheatertimer.org/pdf/651A-652A-manual.pdf
Made for permanent outdoor usage. Outdoor usage only.
Timer has 2 grounded outlets located bottom of timer, maximum wattage for both 1000Watts
50-mini-bulb string of Christmas lights is 25 Watts
Plug timer into 125 Volt GFCI protected outlet.
Do not plug timer into extension cord.
Indicator light shows when timer has power.
Timer turns ON automatically at dusk.
Plug lights, small pump, fountain, motor into grounded outlet located bottom of timer.
Rotate dial to choose timer function.
Rotate dial to select timer function
- ON at dusk & OFF 2, 4, 6, 8 hours later - Rotated dial to number shown on dial
- ON at dusk, OFF at dawn - Rotate dial to dusk-dial
- ON continuously - Rotate dial to ON
-OFF - Rotate dial to OFF
Dec 03, 2010 | Jasco Ge 8HR Mechanical Blk Timer 2 Outlet...
Will the Brother ES2000 sew a buttonhole without the buttonhole attachment installed. If so, what do I do. I have set the style number plus length and width as shown on machine. It does not sew the...
Have you made sure the buttonhole lever is in the buttonhole tab?
This tutorial will show you how to make a zig-zag buttonhole - http://www.ehow.com/video_4433258_making-hole-using-zigzag-stitch.html
The demo is a little sloppy. I stitch into the ends and I set the stitch length to zero when making the bar tacks across the ends. It takes a little practice.
I hope this helps.
Mar 07, 2010 | Brother ES2000 Computerized Sewing Machine
I need the owner's manual for a Computerized ES2000 Brother sewing Machine.
Hi, Justmanuals.com has the manual that you need. They do charge $11.77 for each manual. If you're interested, just follow the link below. Hope this helps! Hal
http://www.justmanuals.com/sewing-machines-c-353.html
Jun 04, 2009 | Brother ES2000 Computerized Sewing Machine
Washer would not stop
danby parts department: 18000-496-6049
i found the timer for this model: DTT420
timer part # 420.4.05
can be bought for cheap at www.partstop.com or www.topapplianceparts.com
----china part #-
DXT-15f-G
120V 3A AC 2008y10M
Aug 07, 2006 | Frigidaire FWSB7800DS Top Load Washer
Jackson 25 in. Conserver XL Free-standing Dishwasher Logo
18 people viewed this question
Top Jackson Dishwashers Experts
jhnolson
Are you a Jackson Dishwasher Expert? Answer questions, earn points and help others
