Question about Air Tools & Compressors
Need brushes for gen electric motor model 26135
This is an old belt drive compressor the motor needs new brushes I can't find a part number or anything on this motor anywhere please help
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
Take the old brushes into and electrical shop... they may have to make a set or match them up... some of those old numbers dont mean anything unless you know it IS the actual model number
Posted on Dec 30, 2013
digritz
  • 530 Answers
SOURCE: i need motor brushes for campbell hausfeld WL611105AJ air comp.
If you can find a match to the brushes that came out of the motor they will work. When I say match, I mean the size. Height, width and depth, length only needs to be close to allow for wear over time. The longer the brush the more wear you will get. If you can't find the exact size then you can always file a larger brush to fit. I just had to do that for a small motor in my shop-vac, works great. Also another consideration is how the line coming off the back of the brush connects to the Stator. If you can't match the connector soldering it is fine or crimp the appropriate connector to it. Beyond those two elements brushes are pretty much the same.
Your biggest problem is finding an assortment of brushes. Some hardware stores will carry some, (check the bins with all the small nut, bolts and other connectors), also automotive parts stores carry them, (for alternators),. Your best bet would be an electric motor repair shop.
Good luck
Posted on Jun 11, 2009
  • 2926 Answers
SOURCE: i need to convert my 220 wiring back to 110 on my
There should be a plate where the ires run thru, and on the plate or motor itself, there should be a diagram shouwing what terminals to connect the leads too.
Hope this helps.
Posted on Jan 18, 2010
SOURCE: electric compressor motor problem
Unloader valve on switch. That switch is not bleeding off cylinder head pressure,when it shuts off.
Posted on Apr 07, 2010
Testimonial: "thank you, this has had me stumped for days now. simply flipping the pressure switch off then back on again solved the problem. "
  • 1388 Answers
SOURCE: I need new brushes for
Brushes are not listed as a replacement part for your compressor. Not to worry because universal brushes are available at tool repair shops, hardware stores and ebay. Measure your brush and order same size or slightly larger and sand to fit. Dont worry too much about the length of brush as they can be shorter than factory and still work fine (just longer than worn brushes). Some motors have a spring pushing brush onto armature and others utilize the spring attached to brush to make contact. You can cut off wire from back of brush if needed, however if your motor needs brushes with spring attached, find close match and solder your old contact and spring to new brush. Also check for other problems because brushes should last the life of motor on your unit. Good luck
Posted on Aug 17, 2010
  • 214 Answers
SOURCE: IR MODEL 2475 COMPRESSOR 7.5
The WEG 7.5 hp motors often blow the start capacitors. The box on top of the motor has 4 caps in it. 2 start and 2 run caps. Mark the cap wiring or make you a diagram to have at replacement time. Remove one or both of the caps. It is easier to remove two wires and pull the start caps out as a set. They are the black, large ones. I think they are 286 Micro farad caps. To get identical caps you may have to order from IR. If you can find a WEG motor shop they may have them. I usually go to grainger or my local motor shop to purchase. The ones here will be larger in size but can be fitted into the box on the motor. Also inspect the wiring in the box. I have found some wires with insulation gone. This may have caused your problem or a problem latter down the road.
Posted on Aug 31, 2011
Canister vacuum
Without the make or model... We are speaking in GROSS GENERALITIES... but
ELECTRICAL Trouble...
The light & the BRUSH not working ... when considered TOGETHER.. would indicate a NEED to check your electrical connections...
My best advise would be to:
make sure the cords & wands are fully connected
make sure the (HEAD) motor is running ...
If the motor (brush head) is running... belt looks good and brush is not seized (or jammed)...
You will need to look to the DRIVE PULLEY on the motor OUT-PUT shaft...
Hope this helps
Jul 25, 2016 | Vacuums
Motor won't turn on
If you're Toro electric blower is slowing down, throwing sparks, or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
There are Electric Motor replacement carbon brushes on E-bay for all three motor sizes (7 AMP, 10.5 AMP, and 12 AMP) of Toro Leaf Blowers (Toro Rake and Vac Super and Ultra Blower Vacuums)
Search E-bay for: "Toro Blower Carbon Brush"
- 12 Amp leaf blowers Toro Super (Old model 51552) through Toro Ultra (New model 51609).
- 10.5 Amp leaf blowers Toro Old through Toro New model 51573.
- 7 Amp leaf blowers Toro model 51586 and other Toro 7 amp blowers.
Apr 14, 2014 | Toro 51599 Electric Blower 12 Amp
Brush roller not spinning. belt, spindle okay. roller taken out and cleaned, no thread. replaced but no dice. ???
Use only BISSELL Style 10 Replacement Belts (#32074) in your BISSELL PowerForce Bagless.
  1. Unplug cleaner from electrical outlet.
  2. With Rotating Floor Brush removed from vacuum cleaner, grasp old Drive Belt and remove from Motor Pulley. Discard old Drive Belt.
  3. Place new Drive Belt over Motor Pulley and stretch other end over Rotating Floor Brush in the space between the bristles.
  4. Place ends of Rotating Floor Brush down into slots on sides as shown.
  5. Turn Rotating Floor Brush by hand several times in the direction of Motor Pulley. If properly installed, Drive Belt will center itself on Rotating Brush.
  6. Reposition Brush Cover and snap back into place. Check to be sure all three latches are secured.
  7. When you turn on the vacuum, do you see the motor that spins the belt spinning at the bottom? If not, it sounds like you may have a burned out motor.
If suggested solutions do not correct the problem, call:
BISSELL Consumer Services 1-800-237-7691
Monday - Friday 8 a.m. - 10 p.m. ET
Saturday 9 a.m. - 8 p.m. ET
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jun 01, 2011 | Bissell 6594 PowerForce Bagless Upright...
Need to replace belt and cannot figure how to take it apart to get at the belt --- Took Screws off on the bottom but could not get to the belt
You have already removed the screws so lift the brush cover off. Then grasp rotating floor brush at both ends and lift. Clean strings,hair and other debris from rotating brush, paying close attention to the brush ends. Clean the debris from motor pulley and drive belt areas.Grasp old drive belt and remove from motor pulley. Place new drive belt over motor pulley and stretch other end over rotating floor brush in the space between the bristles. Place the ends of the rotating floor brush down into slots on the sides. Turn the rotating floor brush by hand several times in the direction of motor pulley. If installed properly, drive belt will center itself on rotating brush. Reposition brush cover and screw back into place. I hope that this helps you!
May 26, 2011 | Bissell 3591 CleanView Bagless Upright...
Hi i have an Ingersoll rand 80 gal, 7.5 hp, model #2475 air compressor and the electric motor is arcing when trying to run then blows the breaker. Any ideas? thanks
It sounds like either a problem with the brushes in the motor or the engine shaft is jammed. Have you on many previous occasions run the compressor on that circuit with no problems? It may be as simple as the breaker is not sufficient for the power draw of the compressor.
If you have had the unit for awhile and it has been run lots and the engine shaft spins easily when turned by hand (unplug first) then it may be an issue with the brushes on the electric motor. Take the engine apart and replace the brushes with new ones from an electric motor shop. Take pictures as you disassemble the unit so you will be able to refer to them when it comes time for reassembly.
If the motor shaft does not turn by hand, remove the belt that connects it to a compressor and try again. If this works, reconnect the power and see if the electric motor now works with power on and the belt off. If the motor works and there is no short to throw the breaker, then your compressor is in need of a rebuild and that will cost money and time.
Mar 15, 2011 | Ingersoll Rand Electric Driven Two Stage...
I need new brushes for Powermate Air Compressor motor. Where can I purchase them or do I need to have a Technician install? Model #CL0551109 Thank You J.L. Brooks
Aug 17, 2010 | Coleman Powermate 27 Gallon Air Compressor
Broken belt i need a replacement belt for eureka altima bagless vacuum
Eureka says size U BELT... NO!! I have tried this numerous times. I finally took off a belt from an old vac. and it works !!! dirt devil size 5 belt is the way to go!!
May 08, 2010 | Eureka Altima Upright Vacuum Model 2996AVS...
Motor on mod 51591 died, nedd replacement
The Mamco motor is WAY too much money.I bought brushes on E Bay and made them fit. #51591 takes 1/4 " square brushes.
Nov 28, 2009 | Toro Blowers Rake and Vac - Electric...
Will not spin
make and model number for accurate diag, but most common problem is broken wqasher tub drive belt, turn washer on its side and check for a broken belt.
Sep 27, 2009 | Washing Machines
I need motor brushes for campbell hausfeld WL611105AJ air comp.
Good luck
Apr 15, 2009 | Dewalt 2 Hp 4 GAL Air Compressor
Air Tools & Compressors Logo
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
