Question about Apex Digital ADV3800 DVD Player/VCR
Will not power up no clock or anything - Apex Digital ADV3800 DVD Player/VCR
Losses Time
what frequency does Jordon use on their power is it 50 hz are the clocks 60 Hz designed power usage.
may need a device to convert 50hz to 60hz
search google for
50 hz to 60hz frequency converter
Apr 15, 2014 | Sanyo R-6800 2-IN-1 ALARM CLOCK AND RADIO...
Wolf ovens getting err message after power outage
I had a Wolf 30F wall oven with a similar problem
after power outage. It wouldnt stop beeping with error message related
to temperature control. My solution was to turn power of at circuit
panel, then reset by pressing and holding the clear button for 5
seconds.
Also note: in my case I had to close the display
before switching the panel off. When I tried to the reset process with
the panel showing, it wouldn\'t reset.
To reset other
various parts of the control panel Instructions said:
Time-of-Day Clock
Immediately after the oven is installed, set
the 12-hour clock to the current time of day. It may need to be reset
after a prolonged power failure. The clock is visible on the control
panel during all modes. If the upper oven timer is set, the clock will
not be visible in the upper oven control panel display.
SETTING CLOCK
1) Touch CLOCK.
2) Touch number pads to
set current time of day.
3) Touch CLOCK or ENTER to start
clock.
24-HOUR CLOCK
The time-of-day clock can be
changed from a 12-hour clock to a 24-hour clock. After the clock has
been set, touch TEMPERATURE for three seconds, touch CLOCK, and then
touch ENTER. Follow the same sequence to change back to the standard
12-hour clock setting.
Fahrenheit to Celsius
The
oven can be changed from Fahrenheit (°F) temperature to Celsius
(°C).
Oct 26, 2012 | Wolf Range Ovens
I have a stoves 720ef anf for no obvious reason the clock resets to 23.59 and the oven turns off, can you suggest anything
You obviously have a power loss somewhere. The oven will not work unless a time is set on the clock. I would suggest you have problem with the feed to the cooker which an electician should be able to check it out. If anything else is wrong on the cooker, it shouldn't reset the clock.
Nov 28, 2011 | Stoves 720EF Electric Double Oven
We used a differed sized power cord and it stopped working is it fixable?
It wouldn't hurt anything to try to use the original power cord. Its possible that the other cord just wasnt making a good contact.
Jan 03, 2011 | Homedics SS-4000 Clock Radio
Electricity is on because the colon is showing. But we can't set anything, clock, power, etc. . Cannot program anything. Beeper is beeping for two short beeps around every half hour--.
Hello. Try this. Push the clock button. Then enter the time in hours and minutes, THEN push the clock button a second time. Joe
Please give my answer 4 thumbs up since it is on target and also free to you. Thanks. Joe
Oct 05, 2010 | Danby DMW753 Microwave Oven
We tried to use or keypad lastnigt- nothing on it will do anything. Light inseide is on and is telling us to press clock.
Your description sounds like power failure, after failure on some machines you MUST set clock next. Before you do anything, unplug unit for longer than 45 seconds, then plug in, set clock and go from there.
Sep 26, 2010 | Microwave Ovens
Can't turn radio off or get anything else to work
Sorry it took so long to reply to your problem.You must try to reset the Clock/Radio's microprocessor. To do this you must disconnect the Clock/Radio from the A/C power source and remove the internal battery. Let the Clock/Radio set without any power source for about 3 hours. This should completely drain all the power from the microprocessor. After this is done, reinsert the internal battery and plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal. If they do not return to normal. Unplug the Clock/Radio from the A/C power source and remove the internal battery. Replace the internal Battery (CR2430). Let the Clock/Radio again drain all the power from the microprocessor. Insert the new battery and Plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal.If you should still be having problem with the functions of the Clock/Radio, you will need to call Emerson Customer Support. The telephone number for Emerson Customer Support is 1-800-909-1240. Call them between the hours of 8am-4:30pm CT. Give them the make and model number of the Clock/Radio and ask them for assistance with your problem. I hope this information help you with your problem. Thank you for using FixYa and have a nice day!Sorry it took so long to reply to your problem.You must try to reset the Clock/Radio's microprocessor. To do this you must disconnect the Clock/Radio from the A/C power source and remove the internal battery. Let the Clock/Radio set without any power source for about 3 hours. This should completely drain all the power from the microprocessor. After this is done, reinsert the internal battery and plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal. If they do not return to normal. Unplug the Clock/Radio from the A/C power source and remove the internal battery. Replace the internal Battery (CR2430). Let the Clock/Radio again drain all the power from the microprocessor. Insert the new battery and Plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal.If you should still be having problem with the functions of the Clock/Radio, you will need to call Emerson Customer Support. The telephone number for Emerson Customer Support is 1-800-909-1240. Call them between the hours of 8am-4:30pm CT. Give them the make and model number of the Clock/Radio and ask them for assistance with your problem. I hope this information help you with your problem. Thank you for using FixYa and have a nice day!Sorry it took so long to reply to your problem.You must try to reset the Clock/Radio's microprocessor. To do this you must disconnect the Clock/Radio from the A/C power source and remove the internal battery. Let the Clock/Radio set without any power source for about 3 hours. This should completely drain all the power from the microprocessor. After this is done, reinsert the internal battery and plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal. If they do not return to normal. Unplug the Clock/Radio from the A/C power source and remove the internal battery. Replace the internal Battery (CR2430). Let the Clock/Radio again drain all the power from the microprocessor. Insert the new battery and Plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal.If you should still be having problem with the functions of the Clock/Radio, you will need to call Emerson Customer Support. The telephone number for Emerson Customer Support is 1-800-909-1240. Call them between the hours of 8am-4:30pm CT. Give them the make and model number of the Clock/Radio and ask them for assistance with your problem. I hope this information help you with your problem. Thank you for using FixYa and have a nice day!
Feb 19, 2008 | Emerson Smartset Clock Radio
Apex Digital ADV3800 DVD Player/VCR Logo
18 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
Electro Med Services...
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
