Question about 2004 Chevy Monte Carlo - SS, without spoiler - Weathershield HP Car Cover
CHECK ENGINE LIGHT STAYS ON WITH KEY OUT
WONT START AND THE CHECK ENGINE LIGHT STAYS ON EVEN WHEN THE KEY IS REMOVED FROM THE IGNITION
  • 34 Answers
I would disconnect the battery 5 minutes
Posted on Dec 27, 2013
98 mercury tracer wont start. Good battery but wont even attempt to turnover. No lights are working but the check engine light is on constantly, even with the key out. Any ideas?
Lights on the dash with key out sounds like ignition switch issue, but I would check the battery connections at both ends on both cables. Also make sure you have a good connection for chassis ground. If that is all good, suspect the ignition switch.
Do It Yourself Diagnosis and Repair
Dec 15, 2017 | Mercury Cars & Trucks
2007 dodge caliber has full power to all electronics. The engine light stays on and when you turn the car to start nothing. Turning the key does not even deam the lights like the starter is getting no
Sounds like the solenoid on the starter is not getting any power, check the small wire connection on the starter to see if there is power in the start position, if not you have an ignition switch problem or an open circuit between the ignition switch and starter solenoid... if you do have power in the crank position then you have a bad starter.
Jan 11, 2015 | 2007 Dodge Caliber 2.0
Immobilizer light stays on engine won't start
Make sure the key isn't on a keyring, and if you have a spare key try holding it against the ignition barrel whilst trying to start the car. Failing that, it's an auto electrician job. China OBD2 car diagnostic tools wholesale on CareUCar
Mar 20, 2014 | 1996 Jeep Grand Cherokee
My envoy wont start turn key and everything works but wont start
What ????? i try to sterted manuely and it start but turn off the light stays on with the ignition. What light stays on ????
i try to sterted manuely ???? I try to start it manually !!!!!!! You need to take your vehicle to a qualified professional technicia .
Jan 23, 2018 | 2005 GMC Envoy
Vw ingnition light stays with key off
one of the 2000 VW electrical gremlins. most likely cause is a bad ignition switch.
Sep 23, 2012 | 2000 Volkswagen GTI
Engine light stays on after I turn the key off and my car wont start
this sounds like an ignition problem, remove the cylinder lock and check it for any broken parts then look at the elctrical ignition switch that the lock goes on and check the operation of that, that might be the cause of your problem , hope this helps.
Oct 04, 2010 | Chevrolet Impala Cars & Trucks
Oil level low light comes on. When I turn
some cars with oil level warning light on, it doesn't mean that its only reading the engine oil level is low, sometime the transmission fuid too. Did you check your transmission fluid if it is ok or not? try to check and let us know, ok.
Mar 14, 2010 | 1999 Buick Century
2003 Prius sometimes will not start, engine light comes on. Removing key from ignition, reinserting key, & turning wheel till it locks will then allow the car to start. Engine light stays on for a
I had a wire connector on the front of the engine that had so much tension, the wires broke. I didn't notice until a wet day when the car wouldn't start (and the Check Engine light was on). (The error code was related to an Emissions error.) The connector is located on the engine, front, just left of center. Hope this helps!
May 25, 2009 | 2002 Toyota Prius
2004 Chevy Monte Carlo - SS, without spoiler - Weathershield HP Car Cover Logo
76 people viewed this question
Top Covercraft Vehicle Parts & Accessories Experts
Tenderfoot
Tom
baire
Are you a Covercraft Vehicle Part and Accessory Expert? Answer questions, earn points and help others
