Question about Exercise & Fitness
Calibration sensor for cybex 600t - Exercise & Fitness
Cybex 530t error 1
Error 1, Err1 Belt didn't start (or no speed sense) 1. Perform speed calibration procedure
2. Check speed sensor
3. Check motor brushes
4. Check drive motor
5. Check lower board
I am attaching a link for the service manual. This information can be found on page 65. You can use this manual to determine the steps required for checking the above mentioned items.
http://www.sportsmith.net/images/product_support/cybex/Manuals/Service/LT177304-CybexProPlusTreadmillOwnersServiceManual.pdf
Cybex Pro 530T Treadmill Parts Deck Belts Motor Rollers SPORTSMITH net
Apr 09, 2014 | Exercise & Fitness
Displaying error 1 what could be wrong and how do I repair it?
Apr 09, 2014 | Cybex 44325 Pro 530t Walking Belt X07-07
How to calibrate speed on a treadmill
Make sure power switch is off; hold down any key on the display and turn power switch back on. Unit will go into diagnostic mode. Press and hold the start key until unit beeps and begins to calibrate. Make sure you are not standing on the belt during process. Let unit run its course and slow completely then hit stop. you're done.
Dec 30, 2013 | Cybex 530T Pro Plus Treadmill
Cybex 750T Treadmill
use the software calibration, and try again.
The Steps for Newer Style Console Calibration:
  1. Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
  2. Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
  3. Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
  4. If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
  5. Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
  6. Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
  7. Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
  8. Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
  9. Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
  10. Press ENTER. You should see "SS" or "55" in the console.
  11. Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
  12. Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
  13. When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
  14. Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step. The Calibration seq
God bless you
May 22, 2013 | Cybex 750T Legacy Commercial Treadmill
Cybex 445t err 1
Error 1 means belt didn't start (or no speed sense).
Speed sensor and motor brushes are usually the culprit. Most of the time this its just the speed senor is out of place. Remove the hood and next to the pulley on the front roller you'll see a little black pill with wire attached. Adjust the tip of that to where its sitting within about an 1/8 inch from the magnet on the pulley. Speed sensor can go bad and you can tell by using a voltage meter on the audible continuity setting. New speed sensor: Cybex CX 445T Speed Sensor Part # AX 21500
If that doesn't work check your motor brushes, continuity on communication cables and calibrate it. If that doesn't work you may have a much larger problem such as a bad motor. How to test your motor
Feb 07, 2013 | Cybex CX 445T Treadmill Deck
Error 3
Test the speed sensor by continuity with DVOM and replace, and RUN the software calibration.
see the block diagram.
God bless you
Nov 26, 2012 | Treadmill Doctor Trotter Cybex 450t Deck...
I bought a used Cybex Trotter 700 T treadmill that works fine except the increase speed (+) does not work. I tried to fix it and now all of the buttons don't work. Any sugestions?
Dear Sir:
This is probably a 1(faulty speed sensor or the 2( speed sensor is not plugged in properly. Its also possibly a 3(faulty motor control board or lower board+ 4( Main motor faulty. Adjust the speed sensor see the diagram.
Run the software calibration for easy diagnose and troubleshooting.
See my personal TIPS for HELP
sincerley. God bless you.
ernesto cuadra
managua, nicaragua.
Mar 10, 2012 | Exercise & Fitness
Cybex 520T error message 3
Error 3 is a speed signal lost error. Check speed sensor, lower board, drive motor then display.
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Feb 08, 2012 | RTO Cybex 520T Remanufactured Treadmill
About 10 second upon start-up, the Cybex 520T Treadmill would abruptly stop and display in the consul is an Err3. We transferred the speed sensor of the unit to another Cybex treadmill and initially the...
Error 3 is an indication that the speed sensor signal has been lost. Check the speed sensor gapping on the machine you were initially having the issue on. If the speed sensor worked on another machine, I would think adjusting it when you reinstall the sensor, should fix your issue. A lot of times, gapping or a build up of lint, dirt or other debris can cause the speed sensor error to occur.
Jul 29, 2011 | RTO Cybex 520T Remanufactured Treadmill
Error 3
Calibration error I believe. Try a reset to factory settings and follow the manual to set it up again
Sep 12, 2009 | Cybex Computers & Internet
Exercise & Fitness Logo
19 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
