SOURCE: dark or no image at all
CHECK THE LAMP IF THE LAMP LUSTER HAS GONE OUT OR THE FILAMENT AT DOWN PORTION IS BLACK THEN THIS PROBLEM HAPPEN
SOURCE: DLP projector won't show bright images
This unit should be under warranty and can be fixed, also if it is not under warranty, they can also fix it.
check out fixmyprojector.com
SOURCE: BenQ PB8220 DLP projector - lamp button continues to flash after bulb replacement
Hello!
After 2 years I finnaly solved the problem. There was a flaw in the lamp´s temperature circuit. A technician disassambled my BENQ PB8253 unit and fixed the problem. Charged me US$ 75.00. I´m in Brazil.
Hope this can help.
SOURCE: Benq PB8220 lamp used for 375 hrs shuts projector automatically
Unplug any cables from the projector (except for power)
On the device (not the remote control) hold down exit for 3 sec
lamp status are shown
on the remote control use MENU, and then left right to reset lamp
SOURCE: Lots of details: LP120 stays on for a minute, then powers off
either the colorwheel motor is not getting up to speed to sync with the dmd chip, the wheel sensor is going, or the power supply needs replacing. you can try to replace them yourself or send it to an infocus authorized service center. try www.avsolutionsny.com . they're pretty good.
