Question about Apple MacBook Pro PC Notebook
Looking for instructions or directions to the notebook pro ++ app
Would like to know how to delete entries made into notes
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 80 Answers
Just go to apple support.
Posted on Jan 20, 2014
O how do i delete kik
Do you mean removing the app or deleting your account?
To remove the app, hold it down on the homescreen and you'll see an 'x' appear on the top corner. Press the 'x' and it'll delete the app.
To deactivate your account, follow these instructions:
https://kikinteractive.zendesk.com/entries/23593116-How-do-I-deactivate-my-account-
hope this helps
Feb 25, 2015 | Apple iPhone Cell Phones
Tip
You can no longer access the CD drive or the DVD drive or drives not seen in my...
Step 1: Start Registry Editor loadTOCNode(3, 'resolution'); Click Start, click Run, type regedit, and then click OK. Registry Editor starts. Step 2: Delete the UpperFilters registry entry loadTOCNode(3, 'resolution'); 1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE. 2. Expand SYSTEM, and then expand CurrentControlSet. 3. Expand Control, and then expand Class. 4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}. 5. In the right pane (topic area), click UpperFilters.
Note An UpperFilters.bak registry entry may also appear. To delete the UpperFilters registry entry, you must click UpperFilters and not UpperFilters.bak. 6. On the Edit menu, click Delete. 7. When you receive the following message, click Yes to confirm the deletion of the UpperFilters registry entry: Are you sure you want to delete this value?The UpperFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey.
Note Do not exit Registry Editor. You must have this program for the next step. Step 3: Delete the LowerFilters registry entry loadTOCNode(3, 'resolution'); 1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE. 2. Expand SYSTEM, and then expand CurrentControlSet. 3. Expand Control, and then expand Class. 4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}. 5. In the right pane (topic area), click LowerFilters.
Note An LowerFilters.bak registry entry may also appear. To delete the LowerFilters registry entry, you must click LowerFilters and not LowerFilters.bak. 6. On the Edit menu, click Delete. 7. When you receive the following message, click Yes to confirm the deletion of the LowerFilters registry entry: Are you sure you want to delete this value?The LowerFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey. 8. Exit Registry Editor. restart computer
on Jun 19, 2008 | Dell INSPIRON 1300 Celeron 1.4GHZ,256MB...
Delete an item in keychain
Go to applications, utilities, Keychain Access, look down the list for the entry you want to remove, select it, click the edit menu then click delete, Done :-)
Mar 02, 2014 | Apple Mac Book Pro 15.4" 2.53 Core2Duo 4GB...
Delete app in iphone
Pull the app up in the app screens (not the home screen), hold it down until it starts to shake and everything has an X in the corner. Delete the one you want and confirm it. When you sync again you may want to make sure you have removed it from your Itunes account or it may keep resyncing to your phone.
Jan 11, 2014 | Apple Iphone 4s - 16gb -blackat&t Model...
Duplicate printer entries
because every version OS has special driver , try uninstall driver and install again
Mar 22, 2013 | HP Officejet Pro L7680 All-In-One Printer
Sony VAIO GRV550 (PCG-GRV550) PC Notebook DVD/CD-RW drive disapeared from list of drives. It'still present in Device Manager with yellow sign and explanation: "Windows failed to start the device due...
Here is step by step solution (It works most cases) 1. first of all open registry editor.( in run write regedit.exe and press Enter)
Then go to: "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\IDE"
Once you're there, you should see multiple entries for your IDE drives.
Check your CD-ROM drives. Check the entry directly below your CD-ROM drives
to see if any of them have a property for the LowerFilter or UpperFilter. If
so, delete the property. If you get a prompt saying you can't delete the
property, you'll have to modify the permissions of the registry entry so that
you're allowed to edit.
Hope this helps...
Mar 27, 2011 | Sony VAIO GRV550 Notebook
I have a Dell VOSTRO 1700 running VISTA, purchased March 2008 (out of warranty). I used the Toshiba DVD Drive only a few times. Since Oct 2009, the laptop unit (softwarewise) does not ''see'' the Drive....
This is becoming a common problem. Let's see if we can save you $150!!
If your CD-ROM or DVD-ROM Drive Appears To Be Missing then you will need to manually edit your registry.
Follow the instruction below.
Click Start Menu. In the Search box, type regedit, and then click OK. A Registry Editor window will open up.
Step 4: Restart the computer.
This should resolve the problem and there is no easy fix unless you factory restore or reinstall the operating system.
Good luck and please let me know if there is anymore advice that you need.
Jul 20, 2010 | Dell Vostro 1700 Notebook
Bonjour, Je viens d'acheter un graveur DVD Sony Optiarc AD-7593A. Au démarrage de la machine, le bios m'indique Disk 1: Error. Aidez moi s'il vous plait
bonjour, essayer de vérifier votre Bios si le Disque était réglé dans le bios en appuyant F2
S'il a été réglé dans le bios essaie de vérifier ceux-ci traite dans l'enregistrement de fenêtres
Windows Vista loadTOCNode(2, 'resolution');
  1. Click Start Collapse this imageExpand this image vistastartbutton.jpg, and then click All Programs.
  2. Click Accessories, and then click Run.
  3. Type regedit, and then click OK. Collapse this imageExpand this image securityshield.jpgIf you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
  4. In the navigation pane, locate and then click the following registry subkey: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
  5. In the right pane, click UpperFilters.
    Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to step 8.
  7. When you are prompted to confirm the deletion, click Yes.
  8. In the right pane, click LowerFilters.
    Note If you do not see the LowerFilters registry entry, unfortunately this content cannot help you any further. Go to the "Next Steps" section for information about how you can find more solutions or more help on the Microsoft Web site.
  9. On the Edit menu, click Delete.
  10. When you are prompted to confirm the deletion, click Yes.
  11. Exit Registry Editor.
  12. Restart the computer
Windows XP loadTOCNode(2, 'resolution');
  1. Click Start, and then click Run.
  2. In the Open box, type regedit, and then click OK.
  3. In the navigation pane, locate and then click the following registry subkey: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
  4. In the right pane, click UpperFilters.
    Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to step 7.
  5. On the Edit menu, click Delete.
  6. When you are prompted to confirm the deletion, click Yes.
  7. In the right pane, click LowerFilters.
  8. On the Edit menu, click Delete.
  9. When you are prompted to confirm the deletion, click Yes.
  10. Exit Registry Editor.
  11. Restart the computer
Feb 23, 2010 | Toshiba Satellite Pro M15-S405 Notebook
Program factory remote keyless entry for 2003 Hyundai XG350
This bulletin supersedes TSB# 02-90-001.
DESCRIPTION: The security system keyless adapter cable (SPX/Kent-Moore P/N 09900-21300) is a special service tool (SST) that is used for programming new keyless entry remote transmitters to the factory security systems. The keyless adapter is used in conjunction with the Hi-Scan Pro (with Hi-Scan SOL Pro Software Version 09-29-03
or newer) and Data Link Connector (DLC) Cable. SERVICE INFORMATION: The keyless adapter cable can be used on the following vehicles:
  • 2001 - 2004 MY Elantra
  • 2001 - 2004 MY Santa Fe
  • 2002 - 2004 MY Sonata
  • 2001 - 2004 MY XG300/350 0390020a.gif
NOTE
  • The 2003 - 2004 MY Tiburon does not need the Keyless Adapter Cable to add keyless entry remotes to the factory security system. Instead, the Hi-Scan Pro connects to the vehicle using only the DLC cable. See page BE-60 in the 2004 MY Tiburon Shop Manual for the latest instructions.
  • The most current Keyless Adapter Cable Instructions are available in the following shop manuals:
SHOP MANUAL
PAGES
2004 MY Elantra
BE-73 - BE-74
2004 MY Santa Fe
BE-43 - BE-44
2004 MY Sonata
BE-40 - BE-41
2004 MY XG350
BE-46 - BE-47
KEYLESS ADAPTER CABLE INSTRUCTIONS:
  1. Connect the keyless adapter cable to the Hi-Scan Pro DLC cable. 0390020b.gif
  2. Plug the keyless adapter into the vehicle's 10-pin multi-purpose connector located behind the driver's side lower instrument panel (next to the DLC). NOTE Sample vehicle shown is the Santa Fe.
  3. Turn the Hi-Scan Pro ON
    and press ENTER
    . NOTE "Release date 29. Sep. 2003" OR LATER
    must appear on this screen. To update your SOL card with the latest software go to www.hmaservice.com and refer to TSB 00-00-001.
  4. Select option "HYUNDAI VEHICLE DIAGNOSIS"
    and press ENTER
  5. Select vehicle model and press ENTER
  6. Select option "TRANSMITTER CODE SAVING"
    and press ENTER
  7. Ensure that the key has been removed from the ignition cylinder before proceeding. 0390020h.gif
  8. Follow the steps noted on the Hi-Scan Pro screen to program the remote(s). NOTE The factory security system can only be programmed to accept two remote transmitters and MUST be programmed for both remote transmitters at the same time.
  9. Press ESC
    on the Hi-Scan Pro and verify that the remote(s) are functioning properly.
  10. Turn the Hi-Scan Pro OFF
    and disconnect the adapter cable from the multi-purpose connector.
May 22, 2009 | Hyundai Motor 2003 XG350
Presrio X1000 DVD/CD Rom driver not working
From Microsoft KB :
This method provides step-by-step instructions for how to use Registry Editor to delete the following corrupted Registry entries:
  • UpperFilters
  • LowerFilters
Step 1: Start Registry Editor loadTOCNode(3, 'whattotry'); Start Registry Editor. Step 2: Delete the UpperFilters registry entry loadTOCNode(3, 'whattotry');
  5. In the details pane of Registry Editor, on the right side, click UpperFilters.
    • If you see the UpperFilters registry entry in the details pane of Registry Editor, go to step 6.
    • If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to "Step 3: Delete the LowerFilters registry entry."
  7. Click Yes when you receive the following message: Are you sure you want to delete this value?
The UpperFilters registry entry is removed. Step 3: Delete the LowerFilters registry entry loadTOCNode(3, 'whattotry');
  1. In the details pane of Registry Editor, on the right side, click LowerFilters.
    Note You might see a LowerFilters.bak registry entry. You do not have to remove that entry. Click LowerFilters only.
    If you do not see the LowerFilters registry entry, unfortunately this content is unable to help you any more. Go to the "Next Steps" section for information about how you can find more solutions or more help on the Microsoft Web site.
  2. On the Edit menu, click Delete.
  3. Click Yes when you receive the following message: Are you sure you want to delete this value?The LowerFilters registry entry is removed.
  4. Exit Registry Editor.
Step 4: Restart your computer loadTOCNode(3, 'whattotry'); Restart your computer. After you have done this, try to access the CD or DVD drive. If you can access the CD or DVD drive, and if you do not receive an error message, the problem is resolved. You can reinstall your CD or DVD writing or recording software.
Jan 16, 2009 | Compaq Presario X1000 Notebook
Apple MacBook Pro PC Notebook Logo
47 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
