SOURCE: When we are using are Nordictrack A2105 for about
From what I am reading the console also goes blank. If this is correct it very well might be a loose connection especially with it being incosistant with the duration of time between shut downs. The lubrication could be the issue but normally it will not cause the console to shut off also. It will normally only cause the thermal switch in the drive motor to shut down until it cools down to approx. 115 f then it will start back up. But with the time frame being so short if the user is around 275 to 300 pounds this could be a cause where the lubrication would be a greater issue.
Good luck.
SOURCE: My NordicTrack EXP 1000 stops in the middle of a
my nordic track 1000 stops several times during the workout. I can step to the side and the belt may or may not start back up. The display continues to display the set machine. any suggestions?
SOURCE: I have a nordictrack cx938 elliptical that will
Dear Sir:
Adjust the reed switch. see the attached diagram.
proceed according with your instruction manual, if you do not have go for free download: www. fitness.manualsonline. com or www. iconservice. com
sincerely. God bless you
SOURCE: belt stops while using nordic track c2255
this happen to due the lack of maintenance according the schedule manintenance. see the video and proceed.However if after you did, the problem remain,is TIME to replace the old board deck. God bless you
