Question about Kyocera FS-1135MFP
No suitable paper
Message No Suitable Paper
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 70 Answers
Your paper guides also tell the printer what size paper is in it. if the guides are not tightly touching the paper, the printer will think there is no paper or wrong size.
tl;dr set the paper guides tightly.
Posted on Nov 20, 2013
My konica bizhub 163 CAN'T ACCEPT PRINTER SIZE MODE AND GIVE ME MESSAGE-- NO SUITABLE PAPER
Incorrect media check to ensure the media is set for Metric I assume not inch for USA. Check your print driver for proper media settings metric versa inch
Sep 12, 2015 | Konica Office Equipment & Supplies
Why does the display show no suitable paper
Check the original paper size and the paper size in cassete
Jul 18, 2014 | Kyocera FS-1035MFP Printer
When i try and print with photo paper. the paper goes 1/2 way in a gets jammed.
the photo paper is too thick and it does not suitable on the type of printer you're using.
May 16, 2011 | Office Equipment & Supplies
Paper size not support
use suitable size of paper for the matrix paper...
Apr 28, 2011 | Tally 6306 Matrix Printer
Two day ago i managed to print on a Konica Minolta Di1611, and now it's giving me "PRN ERR" message and "LOAD suitable paper", even though I'm using the same type of paper. I tried to...
is the driver set correctly with the type of paper you have loaded in the draw also when you select the the job to print is it correct in the properties showing the correct type of paper and what draw it is taking it from
Jan 08, 2011 | Minolta Bizhub Di1811p Copier
Canon mx850, paper jams when reloading for two sided copies. once the 1st side is printed the paper is released, recaptured and starts to feed back into the prt. 1/3 into the feed it jams, paper is...
Mel, this is what I found in the online manual:
Set the Ink Drying Wait Time longer.
Doing so gives the time enough to dry the printed surface so that paper curling and ink blots are prevented.
(1) Make sure that the machine is turned on.
(2) Open the printer properties dialog box.
See Opening the Printer Properties Dialog Box Directly from the Control Panel.
(3) Click the Maintenance tab and then Custom Settings.
(4) Drag the Ink Drying Wait Time slide bar to set the wait time, and then click Send.
(5) Confirm the message and click OK.
Make sure that the actual size of the paper is suitable for automatic duplex printing.
The sizes of media suitable for automatic duplex printing are A4, Letter, A5, B5, and 5" x 7".
Load paper of suitable size and then press the OK button.
Make sure that the Page Size or Paper size setting matches the actual size of the paper with a size suitable for automatic duplex printing.
First, check the Page Size or Paper size setting in the application software you are printing from.
Then, check the Page Size setting on the Page Setup sheet in the printer properties dialog box (Windows) or the Paper size setting on the Page Setup dialog box (Macintosh).
Note
Depending on the version of the application program, the automatic duplex printing may not be supported.
Make sure that the type of loaded paper is suitable for automatic duplex printing on the Main sheet (Windows) or the Quality & Media sheet on the Print dialog box (Macintosh).
Note
To switch to manual duplex printing, follow the procedure below.
Open the printer properties dialog box, clear the Automatic check box on the Page Setup sheet, and reprint.
When performing manual duplex printing, note the following.
If you are printing three or more pages of a document with manual duplex printing, one side of all sheets of paper will be printed first. Turn over the paper and reload the paper in the machine, and then the reverse side of all sheets of paper will be printed. Be careful not to change the order of paper in the stack.
The procedure for reversing the paper varies depending on the staple side and printing orientation. Follow the on-screen instructions.
MX850 series On-screen Manual for Windows:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=16279
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 11, 2009 | Canon PIXMA MX850 multifunction InkJet...
Nothing prints on paper
Kodak printer 5500 make out photos with UltraPremium Paper very flashy even with darker photos shots,
tried calibrations with photo paper kodak says: no suitable paper format
Feb 11, 2009 | HP PSC 1315 All-In-One InkJet Printer
"Out of paper" error message
i would try clening the paper feed tires and roller and if that dose not work i woudl replace them.also pull the paper tray out adn look in top of the printer where the paper feeds out of the tray to see if the is a peice paper is blocking the sensor that reads that the printer has paper.
Apr 03, 2008 | HP Photosmart 3210 Printer
Printing to card
The solution in this case is to either use Canon card paper to print on or set the media type in your printer driver to the correct paper.
The paper you are using is not absorbing the ink correctly, so when the paper exits the machine the rollers are contacting the ink and causing the smudging.
Either you have to alter how much ink is being used by changing the media type in the printer driver, or you have to buy the correct Canon paper
I've seen this happen on Canon's Photo printers when a generic glossy paper was used. Switching to canon paper solved the problem.
Sep 28, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Kyocera FS-1135MFP Logo
599 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
