I own a Jen Air JGR877tQDS, Serial # 1643713JJ and some of the digital touch pads are not responding. Can you help please?
SOURCE: jenn-air jes9800AAB keeps buzzzing, front function panel flashes on and off
Your control panel is getting ready to quit. Mine did the same thing, I ignored it and now nothing on the touch panel works. About $150.00 for the part.
SOURCE: oven door back on
My Jenn-Air oven door also comes off to clean. To remove the door you just open it slightly (to the first position) and lift the door up. To replace it just pull the hinge out about the same angle (about 15 degrees) and slide the door in place on the hinge levers and close the door.
SOURCE: jen air locked latch after cleaning
I finally got my oven to work properly by shutting off the breaker and resetting the main clock. Cured the always locked problem as well as the beep twice when self cleaning.
Have to repeat this every few months since the problem seems to come back.
SOURCE: Jenn Air slide in range JES9750AAB - Touch Pad
put on tree belt . having the same problems replaced ERC $200.00 now they are telling me touch pad touch pad is $240.00 .the stove cost $1300.00. $1740.00 how much more will i have to put in this stove
SOURCE: My touch pad will not work thus rendering the oven
HI. Unfortunately, the touch/key pad is not repairable. Once the circuitry is damaged, the entire board must be replaced. Most units will have an Incorporated control board, that will have the touch/key pad integrated into the main board assembly. If this is the case, simply replace the entire oven control board. If the touch pad is separate from the main control board, replace the touch pad board.
NOTE_ This may be a simple control fault. In this case, simply unplug the unit, or shut down the appropriate circuit breaker for five minutes. This will reset the control. If the issue's persist, replace the failed component.
