Question about Samsung RS2630SH Side by Side Refrigerator
Condensor fan not working - Samsung RS2630SH Side by Side Refrigerator
    Sergeant:
  • 446 Answers
Check for voltage at the motor if yes replace motor if no possible wireing or PCB
Posted on Nov 23, 2013
Its been working great and now for the last two days it works fine the compresser kicks on but when it kicks off and trys to come back on it pops the electric breaker. its been working fine on the same...
Whether its a central air unit or a wall unit, make sure the condensor is clean and air can flow thru it
make sure the condensor fan is running, the condensor fan keeps the compressor from over heating
if the condensor fan stops running the compressor will over heat and trip the circuit breaker. good luck!
Aug 05, 2011 | Heating & Cooling
I have an amana 90 home air conditioner w/ a amana prestige compressor. compessor runs but cooling fan not turning ,fan is not locked up and unit has power .of course w/fan not turning home is not...
Could be a couple of reasons for this:
1. Condensor fan motor bad.
2. Condensor fan motor loss of power.
3. Condensor fan motor capictor bad.
Unit has control for fan for low ambient operation and unit is low on freon telling fan its cold out side and dont run.
Hope this helps. wally
Jul 22, 2011 | Amana Heating & Cooling
Refrigerator warm, freezer fine, condensor fan not working.
yes and it is the evaporator fan inside the freezer, and condenser fan near compressor
Mar 25, 2010 | Refrigerators
The AC in my 2004 Honda Accord only blows cool air when I am driving at higher speeds. When I drive slow or am stopped, it's warm hair coming out. My mechanic said the compressor isn't working properly...
it is a premature failure, That does indicate a bad/failiing compressor, or low oil charge, to low freon. If you trust the mechanic then go witht he compressor replacement and condensor. Unfortunately most oarts stores/shops require the condesor to be replaced for warranty purposes on compressor replacements.
Jul 22, 2009 | 2004 Honda Accord
Air won't cool when the car is stopped on a 2004 chevy cavalier. car temp is normal
make sure electric coolant fan is running.if not check or replace fan relay.the coolant fan has to be running to cool down refrigerant in condensor.so refrigerant in condensor is cooled back down to high pressure liquid so it can go to evaporator.see ifcoolant fan not working.the AC is not going to cool.when you driving the condensor is cooling down from moving air when car is going.when you come to a stop.cooling fan suppose to be on so condensor gased can be cooled down.
Jul 10, 2009 | 2004 Chevrolet Cavalier
Frig stopped cooling. Bad condensor Fan Motor.
sounds like a bad thermostat,that tells unit when to kick on and off.
May 15, 2009 | Maytag Refrigerator Light Switch -...
Radiator/Condensor Fan. Which is Which?
The condensor fan is on the left (passenger side) should have 4 blades.
Jan 23, 2009 | 1995 Honda Accord
Maytag Refigerator Condensor Fan not Running
yes it is your getting proper voltage, fan simply went bad, center mullkion was the unit trying to disperse the heat the fan was not able to!
Nov 01, 2008 | Maytag MZD2766GES Side by Side...
True TDD-1 beer kegerator condensor fan not running
cenck for volatge at wire harness and if you get the right volatge then repl condenser motor you can use a small portable fan just face it at compressor while you look for part and tha will kepp compressor from over heating and tripping the relay on it ok
Oct 15, 2008 | Refrigerators
Hot to the touch
Kathy, you probably have a condensor fan that failed. Remove the lower back panel behind the refrigerator. You will see the condensor, condensor fan and compressor. The condensor fan should be running any time the compressor is running. You might have something stopping the fan blades or the motor might be going bad itself. What you are describing is a classic example of a failed condensor fan motor. Catriver.
Apr 19, 2008 | KitchenAid (KSRD22FKST) Side by Side...
Samsung RS2630SH Side by Side Refrigerator Logo
41 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
