Question about Whirlpool Refrigerators
I have water leaking around my fridge. Top freezer
Everything is working good it is leaing water. I blow compressed air up the tube in the back that goes to a drain pan but it is still leaking and i never can catch it leaking so i am not sure ere it is coming form
    Champion:
    Habit-Forming:
  • 275 Answers
The defrosted water should flow into a hat that sits on your compressor, I would check that area first.
Posted on Nov 22, 2013
  • 54 Answers
SOURCE: Fridge with top freezer
ram a piece of wire down there
Posted on Feb 12, 2008
freetek
  • 5568 Answers
SOURCE: GE built in Fridge does not defrost and freezer ices up
Defrosters are commonly controlled by a primitive timer and this may have a 'dry' and a 'wet' (humid) climate setting that will cause the defroster to cycle generally every 12 or 24 hours.
If set wrong (by accident or on purpose), it can allow too much frost to accumulate before attempting to defrost.
This can cause a gradual buildup of ice.
Also the heating element for the freezer may have failed open so it never heats at all. The connections that need to be checked are often buried between the in- and outside walls.
The timer is probably still OK since you apparently aren't having a problem on the refrigerator side.
Posted on Jun 10, 2008
  • 3422 Answers
SOURCE: frost in top freezer - water leaking in refrigerator - ice maker not working
If your frig is freezing the food in the chilling compartment as well as the freezer, it means one thing--its thermostat isn't shutting down the compressor when the set temperature has been met. You stated that you had it checked by, I assume, a professional service technician. Being a retired tech myself, I'm surprised that he didn't check this out and discuss it with you. Check the temperature IN THE FREEZER! If it is less than 10 degrees F., turn the thermostat to "warmer". If the temp in the freezer is 10 degrees F., leave it alone and go to the temp control in the frig, which is a damper that controls cold air flow from the freezer compartment. Close this damper until your temperature in the upper part of the refrigerator is 38 to 40 degrees F. If these efforts don't shut down the compressor and correct your problem, then the answer is simple. Your thermostat is bad and needs to be replaced. It isn't expensive, and should cost you less than the labor for a tech to install it. Good luck!
Posted on Oct 08, 2008
tborn6
  • 700 Answers
SOURCE: Water forming in fridge part of fridge/freezer
check your gasket on the refrigeratordoor with a dollar bill. it should have resistance when pulled out from between the gasket and door. if not then replace the gasket. or the drain tube in the freezer compoartment is clogged up and not draining properly. good luck and contqact me if theres more to the problem ok.
Posted on Jan 11, 2009
TheRepairGur
  • 27 Answers
SOURCE: Freezer drain plug
Self defrosting refrigerators as well as freezers all have a defrost drain system. This drain system can become plugged or frozen causing defrost drain water to back up into the refrigerator or freezer compartment. The water may gather under the crisper drawers on top freezer models. On side by side, bottom or stand alone freezers ice will build up in the freezer at the bottom and eventually leak out the door.
Plugged Defrost Drain - Freezer on Top (Water under the crisper drawers)
At the top of the refrigerator next to the temperature controls there usually is a cup-like part that carries the defrost drain water into a tube and out the back of the refrigerator to a defrost drain pan behind the unit. Pull the cup out of the tube and clean the cup with hot water and soap. If there is no cup, pull the refrigerator out away from the wall, go behind it and disconnect the drain tube to clear it. If the drain tube is not accessible from the back or the drain can not be cleared from there the main back panel in the freezer can be removed to access, thaw and flush out the drain under the cooling coil.
Use a turkey baster to flush HOT water into the tube to clear any obstruction. The water squirted into the tube should end up in the defrost drain pan.
If the tube will not clear with hot water try blowing it out with compressed air.
Put the cup back on and make sure it is all the way on or in the tube.
Plugged Defrost Drain - Side By Side, Bottom-Freezer Refrigerator or Stand Alone Freezer
The defrost drain pan is located at the bottom of the freezer compartment behind the back wall of the freezer. On some models, the pan is accessible without removing the back panel and others are not. After you get to the defrost drain pan use a hair dryer to melt the ice from the pan.
Once the ice is removed use a turkey baster to squirt HOT water into the drain hole to clear the drain.
When the drain is clear you should hear or see the water you are squirting into the hole enter the pan under or behind the refrigerator.
TheRepairGuru ---- www.repairclinic.com
http://www.repairclinic.com/Whirlpool-Refrigerator-Parts
Posted on Jan 26, 2009
My Samsung French Door, Bottom Freezer Model RFG297AARS was leaking into the refrigerator & pooling under the deli drawer.
Freezer /fridge water/ice in fridge and or freezer
Usually due to CONDENSATION due to bad door seals or a plugged evaporator drain line? Can use a soft flexable tubing and very hot water to clean it out. Bad door seals usually need replacement, but u can use a blow dryer and something to pry it closer to the door wall while blowing hot air on to it. To create a seal, to test for bad door seals place a dollar bill in between the door and wall of fridge where it closes. Then slide out the dollar bill with door closed. It should offer some resistance and not be easy to pull out.
Most all fridges have a drain. Look inside your fridge for a "V" shaped channel with a small hole. This hole leads to a tube and a small pan which sits on top of your refrigerator's compressor. The defrost cycle causes water to run into the channel, down the tube, and then it generally evaporates with the heat of the hot condenser/compressor.
However, if that tube is clogged with food crumbs, particles , debris etc, you will have to clear it to get back to a normal mode of operation. A toothpick, pipecleaner, straw or a cotton bud can often do the trick.
Even a frost free freezer will still ice up at times in the areas away from the heated defrost area and the drain line can freeze. This icing causes the pipe work to the compressor to ice over or sweat and cause a puddle. Or if the drainage has frozen over, it will need to be de-iced. ( usually the line is under the freezer bottom plate covering. Towards the back of the unit) And there is another inside the fridge area also.
Give the freezer a good overnight defrost until it's totally clear of ice in addition to making sure the drain is clear to the pan at the back and then restart the freezer.
Apr 05, 2015 | Samsung RFG297AARS Bottom Freezer French...
Water dripping from freezer into refrigerator. Leaking from cold air chase that comes from freezer to refrigerator. Drain line is clear. Leaks more if using ice maker.
Dec 16, 2014 | Refrigerators
Why is water leaking out of the freezer
Jul 04, 2014 | Kenmore Refrigerators
The drainage tube in our GEProfile keeps freezing
After defrosting, take compressed air and actually make sure that you can blow air through the tube....if the tube is open then there is no way that the water should not be going down....
Heatman101
Apr 13, 2010 | Kenmore 64802 Top Freezer Refrigerator
Freezer leaking water and freezing
you probably have a plug in the drain line that normally drains the water when your freezer goes into the defrost mode. at the base of the refrigerator there is a evaporative drain tray where the water drains from the freezer into the tray and evaporates during normal operation of the unit. You should be able to see the drain tube just above the tray. Attach a hose to it and use compressed air to blow through it and clear it out.
Mar 16, 2010 | Refrigerators
Our roper fridge is leaking water onto the bottom shelf and into the bottom drawer area where it puddles. After a few days it is enough water to saturate 2 kitchen towels. Otherwise the fridge works...
Good day,
Sounds as if the drain in the freezer compartment is iced up.
Remove the rear panel in the freezer compartment, and check for ice blocking the drain hole. If so melt out with hot water (no heat such as a hair dryer).
Depending on your style,the defrost water runs from there into the top of the fresh food compartment, out a fitting to the back of the machine and down into the drain pan.
The blockage is there somewhere.
Service techs use compressed air to blow the drain system clean, once all ice is melted.
If you have no access to a device like that, a standard tire pump with a 1/4" stub piece of tubing makes a good substitute.
Be patient. Do not force air if any ice still exists. May cause damage to connected fittings.
You'll know when you get it right. Water, when poured on the cooling coil will run thru the drain and wind up in the drain pan.
Mar 02, 2010 | Refrigerators
Fridge is leaking water-- pool appears overnight coming out from under fridge-- everything else is dry-- where is water coming from?? We DO NOT have the ice maker or water tube hooked up so it can't be...
LOOK ON THE BOTTOM OF THE FREEZER. IS IT FULL OF ICE? IF SO YOU HAVE A DEFROST DRAIN PROBLEM. THE BEST WAY TO REMEDY THIS IS UNPLUG IT OVERNIGHT AND REMOVE THE BACK FREEZER PANEL YOU WILL SEE A HOLE THAT LEADS TO THE DRAIN PAN. YOU NEED TO CLEAR THIS, COMPRESSED AIR WORKS BEST.
Jan 13, 2010 | Jenn-Air JCD2389G Side by Side...
Kenmore fridgerator is leaking water in the bottom 2001
the drain tube above &be hind ceiling has drain cup on older fridge this gets stopped up with gunk and stuff. held on back wall by 2 screws. This is a top freezer Your describing other wise the drain tube is in the freezer and you'd have ice in the floor of the fridge. If your fridge doesn't have it in the top back of the fridge compartment it is entirely in the upper freezer compartment and is still stopped up probably w ice and gunk. Defrost w hair dryer and while you can see the drain pan and hole pour in a cup of water if it goes down your good other wise blow out the drain with compressed air and retry the water. Please rate me accordingly and good luck.
Mar 13, 2009 | Refrigerators
Water leaking onto the floor
You have a condensate line plugged up. So when the defrost cycle melts the ice from the freezer coil, it drains down to the condensate pan underneath the fridge via a tube (frozen pipe). Find the pan underneath the fridge, get the pipe that ends up at the pan and blow air through it. compressed air works the best, but lung power has worked for me in the past. After the clog is passed, there should be no back pressure. If the air doesn't work. You may have an ice blockage. You can try looking for the block, or turn the unit off, and then blow air after the ice has melted.
Nov 13, 2007 | Whirlpool ED5VHGXM Side by Side...
Refrigerators Logo
52 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
