Question about Danby DPAC8020 Air Conditioner
Everstar Portable air
What do I do when I have P1 error and it won't work at all. we haven't had it that long.
  • Anonymous Jun 08, 2008
    Thanks!  I remembered that P1 meant empty the water, but not the part about pushing the Turbo button.  I can now continue to survive this heatwave thanks to you guys!
  • avalon22 Jun 23, 2008
    we have everstar air conditioner and the p1 lights up but the water container is empty. Where is the tube suppose to go?
Molotov you saved my sweaty night! I hated computers until this very moment! I purchased my Everstar port.AC from Craigslist and of course have no manual or man in the house to help me tinker w/ this...and now thanks to google and you, we fixed it! Thanks a million I did exactly what u said and it works! Turbo all the way! God bless and thanks again!
Posted on Jun 10, 2008
That was my EXACT problem. At 2am, while my bunnies were about to overheat b/c the AC had shut off, you saved us! The drain wasn't draining, and I emptied the machine, pressed turbo, and poof. It works. Thank YOU!!!!
Posted on May 20, 2008
Well, sorry the response is so late but here goes. I just went through the same problem a few days ago. Press and hold the turbo button while plugging in the unit. The AC will cycle through a few tests and mine showed that it had excess water. I have long vinyl tubing so the unit could drain outside the window but it thought whenever it would start or stop there was excess water (thus stopping the flow). I drained the excess water out of the line and voila. I hope this helped you.
Posted on Dec 31, 2007
SOURCE:
SOURCE: everstar portable ac unit displaying error message P1
According to my Everstar manual, P-1 is a drainage problem.
EverStar owners manual pg. 16 -
1. Release the drain hose from the ruber clip and pull out the rubber plug, let the drain hose slant down to a water container.
2. Press the TURBO button on the unit control panel for more than 3 seconds and the WATER INDICATOR light begins flashing. It indicates the forced water drainage feature is activated.
3. Waiting until the WATER INDICATOR light stops flashing and there is no water flow.
4. After the water has drained, remember to secure the drain hose and plug in the upright position and clip it to the unit.
The unit will return to normal operation.
....I had to do this and it worked - Good luck!
Posted on Jul 10, 2009
  • 6 Answers
SOURCE: What is the P1 error code on an Everstar portable
U need to empty the internal bucket, its full of water.
I have this air conditioner. What I did was get a long plastic tube from home depot and connect it to the middle back drain. I then put the plastic tube outside my window, or if u have a drain somewhere put it in there or put the end into a big bucket. Let gravity do its job. I did not connect the tube to the internal bucket b/c I would have to empty it too often. The air conditioner is on top of a table so that water will flow down the tube and out the window.
Posted on Aug 19, 2009
motor1258
  • 6674 Answers
SOURCE: New air conditioner not working P1 error
Check float for drain pan is not taped up for shipping, and remove whatever is holding it up & let it drop down, into pan.
Posted on Jul 26, 2009
  • 4 Answers
SOURCE: My Everstar mpm-08cr-bb4 stopped working and dislays P1
Make sure the water container is clicked in properly. I found this to display the P1 and flashing red light if the floater switch is not properly engaged.
Posted on Jul 14, 2010
  • 39 Answers
SOURCE: My Everstar MPK-10CR portable 10,000 BTU's is blinkink P1 all tim
Make sure the level arm is also making good contct with the water bucket when you insert it. You can awlas pull the level towards you to adjust for better contact.
Posted on Aug 21, 2010
Bucket full light is on, I have drain tube out the window, air won't work. How to fix?
Hi Kathleen King - Typically when the error code P1 displays on panel it indicates that the unit has a sensor error. I would recommend contacting a professional to accurately diagnose and repair the unit.
Oct 02, 2012 | Frigidaire FAP094P1Z Portable Air...
Everstar mpm 08cr bb4 manual
Try Googling (Everstar)(mpm 08cr bb4)(manual) without parens.
Oct 23, 2017 | Everstar Portable Air Conditioner Everstar
Whats does P1 mean on my portable ac unit everstar model # mpn1095cr-bb6
What if you don't have the drain hose that came with it can you use any hose?
Jul 30, 2012 | Heating & Cooling
Jul 26, 2009 | Heating & Cooling
The P1 code means the lower water bowl is full.
Put a pan under it an pull the lower plug (some 10" below the upper drain plug that I hope you have a hose attached to.
Jul 07, 2009 | Heating & Cooling
Need owners manual for Everstar Portable AC MPM1-10CR-BB6
Needed the manual to clarify a P1 error message. Figured how to fix the error P1 on my own. there are two drains on the unit, one is always open as an overflow drip, the other at bottom of unit has a plug. I opened the plug at the bottom of the unit, drained the water, and the P1 error code cleared.
Jun 25, 2009 | Danby DPAC8020 Air Conditioner
My unit has a P1 error and has stopped
Pull out the water container. Make sure the black floater switch is not stuck or impedes from working properly. If this doesn't work, need to look at replacing this
Jun 25, 2009 | Heating & Cooling
Need manual for EVERSTAR model MPM1-10CR-BB6 air conditioner
This site has the manual. It doesn't state the same model, but it's the same manual.
http://www.supportuscenter.com/product.asp?specific=90
May 17, 2009 | Heating & Cooling
Everstar portable ac unit displaying error message P1. The unit turned itself off and will not come back on. It had no symptoms of not working well before turning off.
Mar 25, 2009 | Heating & Cooling
Everstar Air Conditioner
probably, the p1 signals that the water pan is either full or not sitting properly. There is a small lever that it pushes when the tray is pushed in. It is a switch that might have pushed out of its housing. Mine had and I had to dissasemble the unit to get the switch back in place, then it worked fine. Good luck. Dean
Aug 06, 2008 | Office Equipment & Supplies
Danby DPAC8020 Air Conditioner Logo
595 people viewed this question
Top Danby Heating & Cooling Experts
Dennis Boxerman
mintvl
Level 1 Expert
Bill Long
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
