Luxor TUTV2500 display shows undefined...no info or tv guide and can't record?
Digital TV Recorder
SOURCE: how to record from a cctv camera to a digital tv recoder
You can't do this at all. It will only record from its own freeview tuners.
Posted on Jun 23, 2008
elecgooroo
  • 57 Answers
SOURCE: sansui tv with dvd installed
it could be on your first or last channel on the tv.
click through the channels on the tv itself not your cable box good luck I hope this helps....
Posted on Jan 11, 2009
SOURCE: Panasonic DMR-E85 DVD recorder TV Guide problem
Try unplugging the DMR-E85 power cord. It is important that you unplug it from the back of the recorder, not the wall. Leave it unplugged for 10 or 15 minutes. For good measure disconnect the cable 'in' connection as well. Once both lines are plugged back in it will go through its self-check diagnostics. Leave it alone for awhile (give it time to consider the error of it's ways). If you are lucky, when you turn it back on it will ask you to verify the channel lineup. If this does work, and all the channel info is correct, press 'enter' (lineup 1 highlighted). Good luck! This is an awesome machine, WHEN IT WORKS!
Posted on Jan 24, 2009
MooseMe
  • 30 Answers
SOURCE: panasonic DVD Recorder recently not updating on screen TV Guide system
I have two Panasonic DMR-EH50s and one DMR-E85H. I also have a Sony DHG-HDD250 which also uses TVGOS, but it is a HD recorder (that means full DIGITAL capabilities, including the TVGOS ) My TVGOS went out in the middle of April. I messed around on the support sites for about two weeks and found little real info.
The bottom line: I live in Madison, WI & have Charter Cable. None of my DVRs were receiving the TVGOS. Charter was not processing and/or transmitting the TVGOS properly (doesn't really matter the DVRs couldn't receive them), so I called them up, got to their "Level 3 Technical Support" and explained to them that I could not receive the TVGOS digitally or analog (converted digital) on any of my DVRs. They called me back a week later and told me to try it again....
So, all you need to do (if your local Cable Company is sending it properly):
WARNING - All SCHEDULED programs that you have previously scheduled by using the TVGOS will be deleted (NOTE: not the programs that are already recorded on your hard drive, they will NOT be deleted)
Turn the unit off.
Press the up channel & down channel (on the box, not on your remote control) at the same time & hold them for at least 10 seconds. This will reset the entire TVGOS system back to the default settings that were present when you first plugged in your DVR. This erases all previous info that your DVR had about what station it used to get the signal from and forces it to scan all the channels looking for the new channel. This is the only way to force this to occur.
When you turn on the unit, it will run you through the setup like it did when you plugged it in for the first time. Enter your zip code, etc. and when you are done, turn it off & leave it off overnight.
If your TVGOS has the Station Grid but no listings, be patient, TVGO updates its own firmware on your DVR automatically, and that may be all that happens the first night. It should start updating the listings the following night.
If it found the station grid, this is a great sign!!!! This means that your cable company is working on it!!!! It took my local Cable Company about 7 or 8 days to get it working properly, but now my 3 Panasonics and my HD Sony are all receiving full listings!!!!
If you are still getting nothing, complain to your LOCAL Cable Company. It is up to them to ensure that the signal is converted to analog & sent out over cable.
Posted on May 14, 2009
  • 909 Answers
SOURCE: how to record digital tv thru reocrder
You need to go into the menu and set the "av-2 out put" to DTV, that should solve the problem, remembering to connect the "in" scart on the recorder to AV-2 on the tv.If there is only 1 scart on the recorder it will be a 2 way connection, sending and recieving a signal.
Posted on May 29, 2009
Panasonic troubleshooting
I guess you mean a Set Top Box to convert digital TV transmission to old analog TV. Choose the correct video format for your screen.
Ah... Perhaps Your recording at an old standard & passing it to a modern TV or HD TV with the digital output from 1080 HD to 720 or lower still.
OR
Get a Digital Hard Drive recorder.....
The modern way to Record video is to use a Hard Disk Drive Recorder rather than a VCR. They have a built in tuner and can record 2 stations at once and have a built in Electronic Program Guide. The EPG info is transmitted with the Digital TV transmission from the broadcaster.
I bought one 2 weeks ago for an old 85yo friend so he could record late night stuff and play back later. He still uses the VCR but only for old VHS Tape playback. It was a TEAC HDR9650TS Digital Video Recorder and I picked it up new for Aus$188.
Here are the unit features
Main Features:
DVB-T Twin Digital Turners
DVR Recording: Record three channels while watching a 4th from same network Smart Series Record feature to record a whole series at a touch of a button
2.5" Sata Hard disk: 500GB
Time Shift Function (Pause live TV)
HDMI Digital Output
Digital Audio Output
CVBS/YPbPr/SPDIF connectors
Supports TV formats 4:3 and 16:9
Electronic Program Guide (EPG) up to 7 days in advance
EPG searching and auto download
Recorded program edit
Parental Control
Copy files from internal HDD to external HDD
Built-in WiFi
Network Playback
USB 2.0 Interface
Aug 14, 2014 | Panasonic Televison & Video
F10500PVR ferguson digital recorder
After 5 years, and you have tried to set it up again, its probably had it.
Turn off all power to it for 10 mniutes then carefully do the setup again. If its still bad its time to replace it.
Dec 15, 2013 | Televison & Video
Technika 46-270 tv need luxor tutv2500 universal remote codes
Codes for Technica TV are: 0031 0004 0005 0009 0051 0053 0105 0109 0170 0000 0174 0001 0008 0012 0042 0058
Oct 01, 2012 | Televison & Video
Recorder has stopped decoding SD digital TV but analogue TV is OK
Dry joint - faulty capacitor on the PC board of the decoder. Found by wiggling the components and resoldering
Feb 07, 2010 | Panasonic Televison & Video
Luxor TUTV 2500 digital tv recorder device code
You have this backwards. The code is in a compatible remote control, not the device. If a search through all codes fails, you may have to try a different universal remote control. All universal remote controls do not contain all possible codes.
Feb 10, 2018 | Televison & Video
I can't get the recorder to keep my guide.
There might be a TV Guide issue located in your area, since the transition to digital, TV Guide have been updating there broadcast frequency which is know been done by CBS. Have unit reset by holding down channel up and down button for 15 second on the unit itself until 12 flashes on display, then power on unit and setup TV Guide, then have unit off for 24 hours especially between 11pm to 6am for listing. If issue still exist contact Panasonic to have issue send to TV Guide.
Sep 28, 2009 | Panasonic DMR-E85H DVD Recorder
Taping to vhs from digital cable
You do not need to leave the TV on. To get the clearest picture you should connect the AV cables (yellow, white, red) from the cable box to the VCR, and from the VCR to the TV. There should be a setting on both the TV and the VCR to set the input to VIDEO so you don't have to use channel 3. You can shut the TV off while recording if you want. Also be careful because if you use the channel guide or info button while recording, it will show up on the tape.
May 20, 2009 | Samsung VR8460 VHS/S-VHS playback VCR
Tv guide not working
I get this problem from time to time when I have more than one Panasonic DVD recorder scheduled for programing (or updating) at the same time -- or recording when the other would be updating. It is really annoying. If I restart from the beginning and disconnect the other recorder, it works fine. It appears to me that they interfer with each other in some way. Sorry, I don't have a real solution -- just that my DMR-EH55 will download the TV guide and work again if I disconnect the other panasonic recorder.
May 26, 2008 | Panasonic DMR-EH55 DVD Recorder/HDD...
Televison & Video Logo
Top Televison & Video Experts
