My technics sx-KN3000 only one speaker plays the other crackles when touched
2 Suggested Answers
SOURCE: I have a Technics Kn3000
We have Keyboard KN3000 position Blank LCD not open music, how solusition, not spart parts from Indonesia.I waiting information from your.
Thanks,
Best regards,
Dedi Hendra Email : nadagenta@yahoo.com
Posted on Sep 06, 2008
Why dose my i pod touch 5 generation speaker crackles
Check the speakers for any defect. Connect an other speaker in place and check. If crackles are present to both the speakers, the amp circuit inside should be defective. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jul 08, 2014 | Audio Players & Recorders
Problems with receiver
Check out switches and volume pots . Inject cleaner into all and work them for a few minutes.
Jul 07, 2017 | Audio Players & Recorders
My su-g95 technics Stereo integrated amplifier wont play any noise. and when i adjust the volume it makes a popping/crackling noise. i am 100% sure all the speakers were hooked up correctly.
Well it sounds like your amplifier IC's are working correctly since you are hearing that pop. I have the same amplifier and every 10db increment it pops. Have you tried every input? Possibly try starting at a low volume, plug an RCA plug into CD or any other input, and touch the center prong of the other end of the cable. You should get a 60hz hum if your in the USA, otherwise it will be 50-55hz. Regardless it should make noise.
Sep 29, 2011 | Technics SUV500 2-Channel Amplifier
Sound from my speakers is crackled or distorted. when I play music, at start it's working well..then afterwards there is a crackled or distorted sound...then return to normal...
Try updating your sound card audio driver and that would fix the issue.
Also install the KLite Codec pack which will enhance your audio and Video quality and also will allow you to play any video and audio formats
You can download KLite codec pack by simply searching it on google.
If you need online technical support, you may very well contact TheBestPcDoctor. I get my all issues fixed by them and it is a reliable support according to my experience. If you want you can also get in touch with them @
www.thebestpcdoctor.com or via 877-407-9229
Please Rate if you find it useful
Sep 04, 2011 | Acer Audio Driver Realtek.exe
Technics amp crackle and ''hiss'' noise
in my car when I press the accelerator there is hissing sound,did check the air filter by disconnecting the plumbing but still the sound is present any idea what could be causing this sound.
May 25, 2009 | Audio Players & Recorders
Problems setting midi channels using KN3000 and Cubase
If you are sequencing midi tracks you can imbed the patch change in the track and the midi channel assignment and when the sequence plays the info will be sent to the keyboard. Do you have it set to receive Omni?
Apr 23, 2009 | Music
Slight crackle on left speaker if turn volume up
the speaker is bad when you set the loud button on, you're putting more pressure on the speaker beacuse its bad it wll make that crackle sound. My advice change it.
Mar 03, 2009 | Panasonic CT-27G7 27" TV
Speakers are crackling
This could be caused by one of your speaher wires being shorted out to ground, OR one of the speaker terminals in the doors or rear coming into contact with metal. If you remove the unit and test it with the speakers hooked directly to the back of the unit and they do not crackle, then the unit is fine. If they still crackle - then you either have two diferent sets of bad speakers, Or more than likely the outputs of the kenwood have been damaged by an improper installation in the past.
Jan 17, 2009 | Car Audio & Video
I have a Technics Kn3000 keyboard. Sound is now fuzzy; also some of the keys need to be placed. Any suggestions?
Thanks,
Best regards,
Mar 05, 2008 | Audio Players & Recorders
20 people viewed this question
 Grubhead
Grubhead
