Question about Lexmark C543DN Laser Printer
Toner leaking
Magenta toner leaking into printer, comes out all over page, like a dusting
2 Suggested Answers
SOURCE: The Magenta cartridge doesn't print properly, and
I had same problem with refurbished cartridge. Trow it away
Posted on Feb 16, 2010
Printer Ink Leaking
I suggest you contact Konica Minolta bizhub printer support technician, Because may be dust available in printer so not access full cartridge. So first full servicing and then you used or change cartridge in printer.
Thanks,
Sep 09, 2014 | Konica Minolta bizhub C250 All-In-One...
I have a Lexmark C522 Color Laser printer, all cartridges are showing as ok, no error messages but printed pages have specks of magenta toner on them
It sounds as though you have a leaking toner cartridge. If you aren't using Lexmark brand toner, that is VERY likely.. nobody seems to be able to make a good compatible cartridge. Test by replacing it.
Feb 22, 2014 | Lexmark C522n Laser Printer
Dear Sir, I have one HP Color LJ 2500 Printer. Problem is that when I am taking printout all colors are not coming. Red Color and others colors are missing except black one. Model number: C9706A
I have worked/ serviced similar Laserjet Color Printer with same issue.
Actually, prints with faded colors or different colors are due the the dust/ toner dust accumulated on the optics (mirrors and lenses) inside the printer, which refect the laser beams to form prints. For instance, red color is formed by a mix of yellow and magenta toners. The color is replaced by yellow due the the partial or complete blocking of the image laser beam for
magenta as the mirrors which reflect laser beam get covered with dust and toner (which partially blocks the laser beams). Hence the image is not produced properly. This needs professional hands for servicing and cleaning of the optics inside the printer. Note that first magenta goes off, followed by yellow, then cyan and lastly black. This is due to the mirrors placement inside the printer. Magenta is the last one facing upwards at 45 degrees angle and gets most of the dust and goes off first.
Rest assure that the printer requires ONLY CLEANING OF THE MIRRORS, which are inside the printer. So, it is advised that you get the printer serviced by any printer repair/ service professional. (Please note that the mirrors, lenses and scanner assembly inside such printers is extremely complex and can get damaged very easily especially the mirrors).
Hope it would help. If you need any clarification, let me know
Good Luck!
CreativeTECH
Apr 08, 2011 | Office Equipment & Supplies
Cyan and Magenta does not print on the right side of the paper. Toner indicator shows three quarter of the cartridge to be full. Yellow and black prints are perfect.
Good Luck!
CreativeTECH
Mar 31, 2011 | HP COLOR LASERJET CP 3505 N PRINTER
Hello, I have HP lj 2600n. It does not
the problem is due to scanner mirror dust.you have to clean the scanner mirror.
Oct 26, 2009 | HP Color LaserJet 2600n Printer
Just changed both magenta and yellow toner cartridge on my color lazer. When I print the page comes out covered in blue, magenta and yellow streaks. i have re-installed everything and cleaned everything...
is that a new toner? or a refilled one?
its hard for you to ressolved the issue because you need to open all the cover in order to clean all the necessary mess.
try to send your printer to a repair center.
Aug 28, 2008 | Office Equipment & Supplies
Magenta print out very light
This is caused by dust in the scanner assembly. There's a fan right by the magenta laser scanner that blows dust and particulate matter in the air directly on that laser scanner.
Requiring its removal and careful cleaning of all lenses and mirrors. Unfortunately, this is not covered in the service manual. Getting the laser/scanner out is not too bad: Start by removing the printer covers, the rear plate, and the plate on which the DC controller and formatter mount. Remove the four laser/scanner unit corner screws and the single screw for its cover. Be careful to remove the small shutter spring on the cover before removing the cover. Use a strong flashlight to carefully examine the copper-colored mirrors for dust. Use dry cotton swabs to carefully clean all dust from the mirrors and the lenses. Blow dirt and dust from the inside of the scanner box. You will notice that the bottom mirror, facing up, is the one with the most dust.
Jul 23, 2008 | HP Color LaserJet 2600n Printer
Magicolor 7300 printing everything pink
hi
resetr youor printer settings.
change fuser assembly.
then try it.
Apr 02, 2008 | Konica Minolta magicolor 7450 Laser...
Magenta colour comes through on all prints right across the page, it is faded but is still clearly there. I can temporarily fix problem by using the printer menu to clean the magenta developer, but it...
We have over 50 of these printers and a few have had the magenta bleeding problem. On everyone of them the problem was corrected by going to the clean developer function under Maintenence from the Menu and choosing to clean the magenta color. Usually have to run it a couple times but it has always corrected the problem so far.
Mar 29, 2008 | Dell 5100cn Laser Printer
Fatal error 163
Fatal Error 161-Toner Sensor Error, Color:Magenta
When magenta toner sensor error has occurred
Fatal Error 163-Toner Sensor Error, Color:Black
Both are Sensor errors....You would first check the lock levers that hold the toner cartridges in, if everything is fine with them then you could possible have toner dust on the sensors. First take out the cartridge that you are having problems with, then use a dust off can and carefully clean out any axcess toner that you can see where the toner sits. there is a sensor that looks like a clear plastic or glass eye that reads the cartridges and it sometimes gets dirty.
Jan 11, 2008 | OKI C5200n Laser Printer
Lexmark C543DN Laser Printer Logo
197 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
