Question about Dewalt DC988ka 18 - volt XRP 1/2'' hammerdrill/drill/driver kit
Don't stop-- The drill doesn't break down when i release the trigger...hope it makes sense,don't know how to describe it better,,
    Habit-Forming:
  • 188 Answers
The switch pretty much has to be stuck/shorted. Does it do it in reverse also?
Posted on Nov 29, 2013
4 Suggested Answers
  • 313 Answers
SOURCE: dewalt 18 volt cordless hammer drill
when it suddenly stop running probably the motor is seized.possible broken magnet. motor comes in assy
Posted on May 28, 2008
mikeymiddles
  • 58 Answers
SOURCE: Dewalt drill binding
If you noticed this sound the first time you tried the drill, it is noise of the armature brake.  This noise is normal and not a problem at all.  Michael Mittelsdorf
Posted on Jan 02, 2009
  • 142 Answers
SOURCE: my dewalt cordless drill stopped working in the middle of drilling a hole. is the trigger faulty/broken?
First before you open the tool ground yourself. The switch is probably static sensitive. Now open the tool and check for wires that may have come loose from the switch, or motor brush area. If no bad wires make sure the switch terminals are ok (not broken or bent and are tight enough to make contact with the batery terminals). Next check the brushes and make sure they move freely in the brush holders. You didn't state the model so it may not have brushes you can access. If all that is good disconnect the motor from the switch and secure the motor in a vise. Take wires with alligator clips and connect the battery directly to the motor for just a second to see if it runs. If the motor runs you have a bad switch assuming your battery is charged.
Posted on Dec 17, 2011
Makita HR3000c green light comes when trigger depressed but doesnt work
From the owner's manual: Indicator lamp The green power-ON indicator lamp lights up when the tool is switched ON. If the indicator lamp is lit but the tool does not start, the carbon brushes may be worn out, or the electric circuit or the motor may be defective. If the indicator lamp does not light up and the tool does not start, the ON/OFF switch or the mains cord may be defective.
The easiest to check is the brushes. Most newer tools have brushes with a spring loaded pin in them so when they wear down the pin pops and stops the motor so you don't wear the armature. Even without the pin the wire from the contact to the brush is short so the spring doesn't contact and ruin the armature. If the brushes are OK, you'll have to check the switch for continuity.
Aug 24, 2012 | Makita Drills
I broke the rusted muffler off in an old push mower-it screws into the block-I don't have uch to grab to get it out-applied marvel mystery oil-how can I get it out without destroying the engine b
try heating with a torch or maybe wd-40 better than mystery oil on breaking bolts loose let it soak a long time then get a revers drill and dril and easy out it make sure reverse drill a must
Jul 30, 2012 | Briggs & Stratton Garden
Drill keeps spinning when trigger is released use to stop when trigger was released
the break is out or the brushes are worn excessively. I would think the brake is out and for that you would need to replace the switch. MAKE a wiring diagram before removing the switch it is polarity sensitive. You can go to makitausa.com for a parts diagram and also order from there or they have a service locator also where you can find parts locally. Let me know if you need more assistance.
Aug 29, 2011 | Makita Bhp452hw 18-volt Cordless Drill...
When i release the brake it quits
I don't think you are releasing the brake, you are setting it.The brake comes on when the saw kicks back and hits something like your wrist, It engages the brake so that it doesn't cut your arm off, Grab hold of that thing and give it a good yank backwards, It should reset it, and you will be all set. If this is not what is happening, Then I don't know what you have got there, I have never seen a saw with a brake or safety lever like what you are describing.
Jul 28, 2011 | Garden
My mp250 printer shows error p08, I can't use it in any way. I replaced the black ink tank with a new one and tried resetting the printer and it doesn't solve the problem.
Follow the instructions step by step
  1. Turn off printer, cable power still plug in,
  2. Press Stop/Reset button don't release
  3. Press Power Button don't release and than release Stop/Reset button
  4. Press Stop/Reset button 2X , wait until service mode to " 0 "
  5. Turn off printer, cable power still plug in
  6. Press Stop/Reset button don't release
  7. Press Power Button don't release and than release Stop/Reset button
  8. Press Stop/Reset button 4X , wait until service mode to " 1 "
  9. Turn off printer, and loose cable power, wait one minute.
  10. Connect cable power, turn on printer again, now this printer ready to use.
Jul 06, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
My break lamp,light on my dashboard doesn't turn off and my car and trunk light indicator says break on? but Its not on and I don't apply breaks
The brake light on your dash is for the e-brake. If its in the up position this will trigger the light while the car is on. If the light is on and the e-brake is down, then you probably need to change the pads.
Jul 01, 2011 | 1991 Honda Accord
My dewalt 18v cordless drill trigger is sticking in the on position. The model is a dc 988
In most cases triggers either work or they have to be replaced. There are no repairable parts in them and lubricating them usually results in more dust sticking to them and the plastic breaks down from the lube and the problems get worse. Try blowing any debris out of the trigger with compressed air while working the switch. If that doesn't work, the replacement trigger for your drill is part number 152274-22 and is fairly easy to replace. Shop around on the web for the part as they run $50 to $70 plus shipping.
May 10, 2011 | Garden
Describe how to remove drill bit and install a
Most cordless drills use keyless chucks these days. Shift the drill into reverse and hold the main body of the chuck. Pull the trigger and the bit should come out. Put it into forward and run it to tighten onto a new bit.
Dec 02, 2009 | Drills
Dewalt DC988ka 18 - volt XRP 1/2'' hammerdrill/drill/driver kit Logo
46 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
