Question about Santa Fe 2010 Hyundai Owners Manual, Hyundia Owners Manual - Used Like New
My 2004 hyundai santa fe has its check engine light on when i run it for codes p0443 comes up how do i get this to clear
We have already replaced the erg selonoid, egr valve, the purge valve and the gas cap
  • 3,289 Answers
Hi Amy,
My Dad's Santa Fe had a similar issue. It was correctly determined that the filler tube (between the gas cap and the tank itself) had begun to rot through. This is because of the way the metal tube passes through the wheel well to bring gas from the filler opening to the tank. Dirt becomes trapped (and builds up) between the tube and wall of the wheel well. When wet, it takes a long time to dry out and is a sponge for moisture. He first noticed an occasional whiff of gasoline when filling the tank (not all that unusual really) and then later, as the holes got larger - drops of gasoline appeared on the ground when filling the tank. If there's a lot of dirt wedged in there - you may not see gasoline leaking onto the ground though, so don't think if you don't see the gasoline - it's not rotted.
my 2004 hyundai santa fe has its check engine ligh - bbc0a5fe-9dbf-4e8a-8bd6-fd4bb60f8f61.jpg
Santa Fe Fuel Filler Tube
The cost of the repair at the Hyundai Dealership was about $300. You might also want to visit the dealer to have them inspect your Santa Fe's "subframe" for rust / rot. My dad's Santa Fe had issues and this $2600 replacement was covered by the factory even though the car had been out of warranty for many years.
Let me know how you make out - I hope this helps & good luck!
Posted on Nov 20, 2013
Why my 2004 hyundai santa fe cuts off when i try to accelerate.starts and idles fine
You need to do a fault code test to see if any problems exist that could explain this. Also exactly when does it cut off.
Sep 29, 2016 | 2004 Hyundai Santa Fe
Tip
What you need to know about Hyundai
I am a mechanic ..most people ask questions about these foreign hyundai motors ..below is an example of engines that basically if you ask about a Hyundai Xg 350 ,xg300 ..well allow me to hammer 90% of your questions in case you want to grab another motor ..these motors listed will work on 90% of all hyundai products ...Look at the starter sizes ,,all the same for the selected models ..then look at the motor sizes ..This will help you in solving some problems most do not give the specific questioning
100% NEW REPLACEMENT STARTER
FOR
STARTER
12 VOLT / CW ROTATION / 8 TOOTH DRIVE
REPLACES:
MANDO M62957
VALEO TM000A14401
BOSCH REMAN SR4118X
BOSCH NEWMAN SR4118N
HYUNDAI 36100-37210
FITS ON:
HYUNDAI
2001 SANTA FE 2.7L ENGINE
2002 SANTA FE 2.7L ENGINE
2003 SANTA FE 2.7L ENGINE
2004 SANTA FE 2.7L ENGINE
2005 SANTA FE 2.7L ENGINE
2006 SANTA FE 2.7L ENGINE
2003 SANTA FE 3.5L ENGINE
2004 SANTA FE 3.5L ENGINE
2005 SANTA FE 3.5L ENGINE
2006 SANTA FE 3.5L ENGINE
2002 SONATA 2.7L ENGINE
2003 SONATA 2.7L ENGINE
2004 SONATA 2.7L ENGINE
2005 SONATA 2.7L ENGINE
1999 SONATA 2.5L ENGINE
2000 SONATA 2.5L ENGINE
2001 SONATA 2.5L ENGINE
2003-2008 TIBURON 2.7L ENGINE
2005-2008 TUCSON 2.7L ENGINE
2001 XG300 3.0L ENGINE
2002 XG350 3.5L ENGINE
2003 XG350 3.5L ENGINE
2004 XG350 3.5L ENGINE
2005 XG350 3.5L ENGINE
KIA
2004 AMANTI 3.5L ENGINE
2005 AMANTI 3.5L ENGINE
2006 AMANTI 3.5L ENGINE
2001 MAGENTIS 2.5L ENGINE
2002-2006 MAGENTIS 2.7L ENGINE
2001 OPTIMA 2.5L ENGINE
2002 OPTIMA 2.7L ENGINE
2003 OPTIMA 2.7L ENGINE
2004 OPTIMA 2.7L ENGINE
2005 OPTIMA 2.7L ENGINE
2006 OPTIMA 2.7L ENGINE
2002-2005 SEDONA 3.5L ENGINE
2005 SPORTAGE 2.7L ENGINE
2006 SPORTAGE 2.7L ENGINE
2007 SPORTAGE 2.7L ENGINE
2008 SPORTAGE 2.7L ENGINE
on Oct 24, 2013 | Hyundai Cars & Trucks
My 2004 Hyundai Santa Fe 3.5L Has a P0320 Code and the Tachometer has stopped working. What would I change out first?
P0320-is Ignition/Distributor engine speed input circuit. Inspect the wire harness and electrical plug ins in the area of the distributor. Replace the Ignition/Distributor engine speed sensor. This should clear up your Tachometer problem. Good Luck and happy new Year. From Ernie @ RedDeer, Alberta, Canada.
Dec 27, 2010 | 2004 Hyundai Santa Fe
Cruise control will not engage. Just stopped
check your fueses first, is the check engine light on, if it is it might give u a code?
Jun 07, 2010 | 2004 Hyundai Santa Fe
2004 santa fe hyundai
it is probably going into a fail safe mode, get it to a dealer and have it scanned for dtc's
Apr 24, 2010 | 2004 Hyundai Santa Fe
2004 Hyundai Santa Fe, check engine light just came on when turning on the heat control. What could be the causes? Heat is nice and hot, blower works great. Otherwise in excellent condition.
Hi, turning on the heater didn't cause the check engine light to come on, it just came on at the exact time. It does indicate something is going on, but if your auto is doing fine, don't panic.Usually, it indicates an emissions problem. Take you're vehicle to auto zone, and ask them if they will come out and read the code for you, they will do this for no charge, and it will tell you what the problem is. They will also give you a print out of most all the codes. I have done this several times until I bought my own obd-2 meter. After you have the code, just have them erase it with the meter to clear the check engine light. It may come back on again depending on what the problem is, but I would recommend you doing this. Cant beat it, no charge and friendly service.
Good Luck, Shastalaker7
Oct 30, 2009 | 2004 Hyundai Santa Fe
Had the battery of 2004 santa fe replaced now the malfunction light won't go off.
Whenever the "Check Engine" light comes on, there is always a DTC (Diagnostic Trouble Code) stored in the ECM (Engine Control Module). You'll need an OBDII (On-Board-Diagnostics) scanner to retrieve any codes recorded/set in ECM. Once you do this and let us know what, if any codes are set, then we can go from there.
Jun 26, 2009 | 2004 Hyundai Santa Fe
2004 hyundia santa fe had a clicking noise by the power steering pump then later at a red light stopped running and wont start. all gauges showed no indication of anything wrong
Does the Check Engine light come ON when this happens? Whenever the "Check Engine" light comes on, there is always a DTC (Diagnostic Trouble Code) stored in the ECM (Engine Control Module). You'll need an OBDII (On-Board-Diagnostics) scanner to retrieve any codes recorded/set in ECM. Once you do this and let us know what, if any codes are set, then we can go from there.
Jun 14, 2009 | 2004 Hyundai Santa Fe
2004 Hyundai Santa Fe check engine light
I have a book for the Sante Fe, and that code is not in it. I would go back to them and have them re-run it. The person may have just misread the screen.
Aug 08, 2008 | 2004 Hyundai Santa Fe
Santa Fe 2010 Hyundai Owners Manual, Hyundia Owners Manual - Used Like New Logo
97 people viewed this question
Top Santa Fe Radio Communications Experts
eradiostore
eradiostore
Are you a Santa Fe Radio Communication Expert? Answer questions, earn points and help others
