Question about Jenn-Air JJW8527C Expressions Collection Electric Single Oven
Will not pre-heat
Oven will not heat or pre-heat.
    Master:
  • 560 Answers
How old is the oven?
Did the problem start after the oven went through a, "Clean" mode?
Posted on Nov 22, 2013
Testimonial: "No. This was not after the clean cycle. After some research the oven sensor seems to be the most likely problem. I have ordered a replacement and will post the results when I get it installed. Fingers are crossed. Thanks Dan"
  • Dan Greenfield
    Dan Greenfield Dec 14, 2013
    Thanks for the response. I ordered and changed the sensor but the problem persisted. The answer was replacing the oven control board. I think the key to troubleshooting this is there is no error codes displayed on the display board.
When baking when oven gets to temperature, and you open the door to put food in The grill comes on and burns everything. I use the middle of the oven, but it still happens. Any suggestions.
Not sure how your oven works, but older ones had a "pre-heat" setting that you would use to get the oven to temp. This ran both the upper (broiler/grill) and lower elements at the same time to raise the heat quickly to temp. Once the oven is pre-heated, you would switch the selector to "bake" and that would only allow the lower element to work after that. If you failed to remove it from "pre-heat", it would use both and burn the food. Just saying.
Sep 02, 2016 | Ovens
BOSCH HBL3450UC Single Oven weak/slow pre-heat
I have a Kitchen Aid convection wall oven. It takes 6 - 7 minutes to preheat to 325 degrees. You probably have a bad element. There are 2 elements.
Dec 19, 2012 | Bosch HBL3450UC Single Oven
Oven is taking to long to heat
look for the temperature sensor inside the oven cavity in the upper left or top center of the upper oven cavity,its will be a silver or copper colored rod about 1/4" by 2" to 6" long this rod senses the oven temp and cycles the heat to the oven
Jun 03, 2012 | Kenmore 30464 / 30465 / 30469 Gas Single...
Is it dangerest when your oven beeps f2
Typically an oven beeps when the interior temperature macthes the temperature where you set the dial. This is an audible signal to that fact and particularly helpful when you need to pre-heat the oven. For example it you want to cook something at 350 degrees, you set the dial at 350. When your oven reaches that temperature it beeps to let you know. Some cooking directions tell you to preheat your oven. In that case, when you set the dial to 350 and wait for the beep...you know you are safe to start your cooking process because the oven is now pre-heated to the temperature you set. If your recipe requires a pre-heated oven, and you don't wait for the beep, your taking a guess at what temperature you're cooking your food. Additionally, if you want to know what the internal temperature of oven is and your oven is heated...you simply turn you dial setting and listen for the beep. Again, if you set your oven at 350 and you want to know how hot your oven is... slowly turn the dial setting. If the oven beeps at 275 then that's how hot your oven has gotten. To let it finish heating to 350 just reset the dial and wait for the beep.
Jan 13, 2012 | Stoves 600GR Gas Single Oven
Bake pre heat isn't working broil and top burners
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Aug 07, 2011 | GE Ovens
I dont no how to pre heat the oven
To pre-heat an oven is to simply turn it on to the desired temperature and wait 5 to 10 minutes. If you have a timer then set the timer for the desired time you want to pre-heat then begin baking as usual.
There is no magic to pre-heating an oven and everyone that bakes has a different opinion.
Sep 23, 2010 | Ovens
Pre-Heated my oven, it beeped and I put muffins in. They began to cook and suddenly oven lost heat. When I try to pre-heat now, it clicks as if it is pre-heating but I am getting no heat. I have checked...
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Asker's Testimonial " thanks i will have my husband look into that. " - 2gunsally
Aug 10, 2010 | Kenmore Ovens
Oven won't pre-heat
This is a failed oven temp sensor. the control is not receiving a proper resistance signal from this sensor at this time. the control will shut down the unit if this is the issue. check the oven temp sensors connections form the control to the sensor housing for loose or worn contacts, if the wiring is ok, replace the temp sensor.
Sep 24, 2009 | Ovens
Broiler element comes on when "bake" is pressed
does the bake element come on at all?
if so, try the oven out. do a bake @ 350 allow it to pre-heat, and see if once the pre-heat is comlete, id the broil shuts off.
on many ovens at the beginning of the cycle during pre-heat both bake and broil elements are powered.
other than that it may be a control board, or a burnt and crossed wire in the harness.
May 28, 2009 | GE JTP15 Electric Single Oven
Jenn-Air JJW8527C Expressions Collection Electric Single Oven Logo
95 people viewed this question
Top Jenn-Air Ovens Experts
 Fix Your Board
Fix Your Board
Dan Webster
Dan Webster
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
