Where is wps button on cisco router? - Office Equipment & Supplies
  • 138 Answers
There should be only one button on the front of the router, just push it and the WPS should look for new wireless devices,
Posted on Nov 20, 2013
2 Suggested Answers
Rider On Way
  • 1679 Answers
SOURCE: HP Photosmart printer gives me
If your router does not has WPS button, there is another way to Enable it from Router configuration under wireless settings
If you enable the WPS option from Router, you will have to press the WPS option from printer for automatic setup of printer on wireless network.
If you are not able to locate it then the WPS on your printer is of no use ( to connect to router )
Instead, I believe you have wireless router and you want to setup the printer wireless on network.
This is touchsmart printer and it has a setup button
Press SETUP option
Press WIRELESS option
Check for Wireless Setup Wizard
If it has Wireless setup wizard, select it and continue to search for wireless router and enter your network key if your router is secured with a key.
Run the software disk on pc and choose wireless connection and continue with the rest of the installation screen to complete.
If this option is not available, you will have to setup the printer thru usb cable and make it wireless
Run the disk on your pc
Choose Network Wireless connection
It will prompt you to connect thru USB
follow the instructions and it will ask you to disconnect
Continue with the remaining instructions.
Posted on Oct 23, 2010
How i reset to factory defaults without passwords?
That depends upon the brand of the router. It would be wise to google for the particular brand.
There often are software means to perform a reset but here are the hardware means.
For Netgear:
  1. Press and hold the Wireless On/Off and WPS buttons until the Power LED blinks red (about 6 seconds).
  2. Release the Wireless On/Off and WPS buttons and wait for the router to reboot.
For Linksys:
1. Press the red reset button on the back.
2. Unplug it from power for 30 seconds. Plug the power back in.
For Belkin:
1. Find the reset button (depends on the model).
2. Depress the reset button for 15 seconds.
3. Wait one minute for the router to restart.
Here is a tutorial for Cisco routers:
http://www.networkworld.com/article/2343961/cisco-subnet/how-to-reset-a-cisco-router-to-factory-default--removing-the-startup-configuration-file.html
Here is one for TP-Link:
http://www.tp-link.us/article/?faqid=496
For D-Link:
Push a paperclip into the hole marked reset on the back and keep it depressed for 10 seconds.
The default user name is usually admin and there is no password (password is blank).
May 11, 2015 | Computers & Internet
WPS button
I have a WRT54G router and there is no WPS button.
This is a cut and paste from Cisco engineer:
Wi-Fi Protected Setup or WPS is a somewhat new feature on most routers. However, I believe that the WRT54g was release prior to this feature. The installation disc for your wireless adapter is trying to circumvent network discovery and the process of entering a wireless password by using the WPS feature. Without using the installation disc to setup the adapter should still be able to connect to your Wi-FI network. Only use the disc to install the drivers for your wireless card and the wireless access utility. After you have done this:
1.Open the wireless utility and you should see available networks
2.Select your Wi-Fi network
3.If the network is open (not password proctected) you should be connected immediately
4.If the network is secured (password protected) then you will prompted to enter your password or preshared key
5.After entering the key you should be granted access to the network
Apr 19, 2014 | Linksys Wireless-G WRT54G Router
How do i find the wps on my router
Look in its manual; I would've provided a link to it, but you didn't bother mentioning what router you have.
Mar 31, 2014 | Cisco Computers & Internet
Change WPS Default Settings
You will need to login to the router web page of
Jan 20, 2014 | Linksys WRT54G2 V1 Wireless-G BROADBAND...
I need a password to reach the interneton my ipad...it asks for a cisco password
If your wireless router was setup using the default configuration, the password, also called a security key should be on the bottom of the router. Alternatively you should be able to specify on your ipad that you want to connect using WPS, and your router will have a WPS button on it. Pushing it for 2-3 seconds would allow your ipad to connect without needing the password. You should be able to google "connecting ipad to wifi using WPS" and if necessary include your router model to get specifics about the location of the WPS button on your router.
Jan 16, 2014 | Computers & Internet
Where is the was button
I'm guessing you mean the WPS button - "Wireless Protected Setup" - As far as I can see from the User Guide this router doesn't have an actual WPS Button - You need to log onto its admin web interface and browse to the WPS setup page - Press the WPS button on your client device (laptop, printer, etc) then Click the WPS button in the router's web interface and let them talk to each other to establish a secure connection - The WPS light on the Front Panel should then light up when connected - You can find a user guide at the following url:
http://downloads.linksys.com/downloads/userguide/1224642967100/WRT54G2-EU_V10_UG_combination_NC-WEB.pdf
Jun 14, 2013 | Linksys WRT54G2 V1 Wireless-G BROADBAND...
Where is the WPS button on my Cisco E1500?
You're kidding, right? Can't you "inspect" it, looking for the ONLY button that is "obvious" to push?
Apr 03, 2013 | Linksys E1500 Wireless-N Router with...
Does my WRT160N have a WPS button and if so, where is it?
The Linksys WRT160N has WPS (Wi-Fi Protected Setup). If you are using WPA-PSK encryption (recommended), then you can easily connect the C4780 to your wireless network using WPS:
1) On the Linksys router, press the WPS button that is top of the case just under the Cisco label. When the LED on the button starts to blink, then the WPS process has started.
Jul 06, 2011 | Linksys WRT160N Wireless Router
Where is my wps button on my Cisco WRT160n router
Are you trying to connect to the wireless network ?
You don't need to press the any button on the router .
You just need to check the wireless settings of the router and connect to the wireless network.
If you press the button on the router , it will change the wireless settings of the router.
Open the setup page of the router and check the wireless settings.
Click Here for step by step by instructions
Sep 12, 2010 | Computers & Internet
32 people viewed this question
jasbo
jasbo
