Question about Garden
Model 28n707 HOW MUCH OIL IN DOES ENGINE NEED 1QUART AN A HALF OR LESS
    Top Expert:
  • 12,223 Answers
All depend of your model , please read your owner manual, section maintenance, or download it from www.fitness.manualsonline. or www.retrevo.com
God bless you
Posted on Nov 21, 2013
2 Suggested Answers
SOURCE: Craftsman riding lawn mower 15HPOHV model 28N707
14.5 craft riding lawn stop moving i dont know what to do
Posted on Aug 23, 2010
My 2006 Suzuki Firenza my oil is coming on and getting hot on top half of motor cold on bottom half like it not getting oil very well
Try mixing 1quart of diesel fuel with your existing oil and run for 5 min and drain. Refill with good oil and a new filter. Make sure pcv is clean or equivalent.
Nov 10, 2016 | Suzuki Cars & Trucks
Eng was low on oil by 1quart
Add 1 quart.
Look for obvious oil leaks.
Check to see if it is burning oil.... sooty exhaust pipe.
Check PVC valve and where PVC pipe goes into manifold or air cleaner for excess oil.
Depending on age of engine and time between checks for oil level, this may not be excessive.
Mar 16, 2015 | Cars & Trucks
My Alto VXR 2004 has a problem that its engine oil is getting lesser fast in quantity. I am using Zic A as engine oil.local car mechanic says engine weak he says gas kit and engine head problem
is is odometer reading?
all cars burn oil if driven real fast, at 80mph, lots.
what i need is ,
1: speeds driven. avg.
2: and what weight, oil , is it hot there, sure, then run 10w-40 oil.
3: how many liters of oil per miles.
some cars go for years, burning 1quart of oil per 3000 mile.s
1L/5000 km to 1L /1000 km. (new car to old)
even more. on older engines.
if the engine runs good, drive it and change oil more often.
check oil at every petrol fill up, and learn what your engine needs
all engine burn oil by design. its a fact.
do an engine compression test.
2 times wide open throttle.
on a warm engine
if lower that spec, 150psi?
then add 1 teaspoon, of oil to spark hole , see if compression rises
if it does, its rings are old.
post the numbers, if all are 150 or more , drive it like you stole it.
half joking there, but drive it. and change oil often and check oil levels
every fill up or every other (depends on reality)
GASKET.
post the compression test readings. only NUMBERS count.
we need numbers and engine size.
Jul 15, 2014 | Suzuki Alto Cars & Trucks
How much oil does it take 15hpohv riding mower model 28N707
let taket your owner manualf see the maintenance matter or download from www.fitness.manualsonline.com or www. manualslib.com for free
God bless you
Nov 20, 2013 | Garden
Throttle linkage DIAGRAM for lawn tractor model 28N707
Here's a breakdown of your engine, however I believe you will need to consult your owners manual for your tractor for the throttle.
http://www.h-machine.jp/part_list/husqvarna/28N707.pdf
As you didn't list your tractor I can't offer any more on this.
Aug 25, 2012 | Garden
Jun 11, 2010 | Garden
Oil Pressure Gauge Drops to zero when Idle and there is some oil leaking
Low oil pressure can and will destroy your engine. Check the oil level. If it's full or just a little low (1quart or little lower) then you have a serious problem already. If it is lower than a quart and a half, re-fill it and check pressure. If it's OK, then find the leak and fix it. If after filling it pressure does not return to normal then you already have a serious problem. have the actual pressure checked with a mechanical gauge and proceed from there. (likely bad bearings) If main bearings are involved, unless you remove the engine and re-grind the crankshaft and clean out the oil passages, you are wasting your $. Usually cheaper to replace the engine and more reliable as well.
Feb 01, 2010 | 2001 Jeep Grand Cherokee
The 3.5 v-6 burns 1quart or oil per 500 miles
You say 2pts of oil per 500 miles well ...
First can you see blue smoke out of the side mirrors if yes ,then you have either Worn or broken piston rings/Valve seals worn and leaking/Breather valve on engine faulty/Dirty air cleaner/or a oil seal or gasket leaking ,,,and if so that also is caused to broken rings
Let me know how you get on Ron
Oct 11, 2009 | 2001 Oldsmobile Aurora
1997 f 150 does not have oil presure... it was stoped for about 1 year, its knoking in the cams.. whats the order to know whats happening?
You are going to need to remove the oil pan and clear the pump pickup screen. After replacing the pan, put one gallon of marvel oil and one quart of kerosene in place of the engine oil. remove the distributor and make an extension for an electric drill so that you can drive the oil pump with the drill (there should be a hex drive rod that fits into the end of the distributor) Run the drill to circulate the solvent, then let it sit for a few hours. Run the drill again then drain the pan. replace the filter and fill the pan with the correct amount of cheap oil. After replacing distributor, start engine, check oil pressure..If good, continue running for about a half hour. Change oil using good quality oil and add more marvel oil (no more than 1quart) Afterward, you can drive about 1,000 miles, then change oil and filter again and resume regular change intervals. I know this is an elaborate procedure but I have done it many times with good results. Providing the lack of oil when you first started the engine has not damaged anything, you should be OK.
Jun 03, 2009 | 1997 Ford F150 Regular Cab
Oil change
You dont say what model bike BUT .... if its an evo.... you have to drain the oil out from the oil tank. Theres an oil drain hose. It doesnt drain thru the engine. If its a twin cam it does...Maybe you were low on oil ? Theres also oil in the filter. A quart might be about it in that case
Nov 02, 2008 | Harley Davidson Harley-Davidson Motorcycle...
Garden Logo
22 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
