Daewoo dwc-ed1212 when i plug in it show e2 or e9 on the board
4 Suggested Answers
Master_Tech
  • 770 Answers
SOURCE: Daewoo Washing machine Problem
If it is new then it is under warrty plz call the dealer you bought iy from for service
Posted on Aug 02, 2008
reddyanantha
  • 205 Answers
SOURCE: water pouring out from under my washer as it fills...
hello mam please check the rubber sleeve of the drum if there is any crack it should be replaced and check the drum if there is any holes in it, so please call the engineer and make him to check these.
Posted on Sep 29, 2009
gerald_quima
SOURCE: E9 E2 ERROR
ERROR E2 PROBLEM
Posted on Dec 13, 2012
DAewoo DWC-LD1013 will not spin
The Daewoo DWC-LD1013 is a washing machine, you may wish to post your question in that category, not in air conditioners.
Jan 09, 2015 | Daewoo Heating & Cooling
THE ERROR IS 63 THE WASHING MACHINE MODEL IS DWC-ED1212
Under the machine should be a bag with
the diagnostic manual & codes
Aug 17, 2014 | Washing Machines
E9 E2 ERROR
Message = E2
Error = OVERFLOW ERROR
Cause & Solution =
The water is supplied continuously due to an defective inlet valve. Change the valve inlet.
The valve inlet is normal, but the water level sensor Change the water level sensor
(sensor pressure) is low. (sensor pressure).
The drain motor does not work - Test and if faulty change the drain pump
Message = E9
Error = SENSOR PRESSURE ERROR
Cause & Solution = The water level sensor is faulty. Change the water level sensor. (remove pressure tube and blow through it to make sure it is clear first)
Mar 10, 2012 | Daewoo Washing Machines
I have a Daewoo Air Conditioners dwc 055rl can i plug it into a regular wall outlet
features Cooling Capacity 5,340 BTU/h 10 Energy Efficient Rating Cooling Area (sq. ft.) 100 to 150 Low Noise Operation Washable Air Purifying Filter Effective Dehumidifying Operation Indoor Temperature Sensing Thermostat Window Kit for Easy Installation Power Supply (V/Hz): AC 115V/ 60Hz Power Consumption: 525 W
Answer = yes regular 115 vac outlet
Aug 21, 2010 | Daewoo DWC-056CL Air Conditioner
Water pouring out from under my washer as it fills...
Sep 29, 2009 | Washing Machines
I need to replace the plug on my Daewoo DWC-055RL Air C
You should be able to get this item at most hardware stores they are very generic. just take or draw a picture of the plug end there are only about 3 styles
Dec 23, 2008 | Daewoo DWC-056CL Air Conditioner
Aug 02, 2008 | Daewoo Washing Machines
Cleaning a daewoo
You usually grab it by the front and pull, but there might some screws holding it in.
Jul 24, 2008 | Daewoo DWC-073C Air Conditioner
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
