Question about GE GTWN4250DWS
Washer drum is banging - GE GTWN4250DWS
Kenmore 970-C42062-00 washer drum squeaky and bangs
The bearing may be shot. A common problem with front loaders. At 10 years of age, the machine has replacement in its future.
Apr 27, 2017 | Kenmore Front Load Washer
Banging drum when spinning
if the drum in the washer klunks/bangs in ANY brand of washer when it is spinning, your load is off balance. stop the machine, re-distribute the wet clothes so that the weight is evenly distributed, then restar the spin. u may have to do this more than once if u did not evely distribute the weight. this is an easy one. just be sure to stop the spin soon as it starts banging. letting it bang thru an entire spin cycle could result in actual damage to the machine. some of the new machines auto shut off at an imbalance so u can correct the problem. think of spinning a top. u unevenly add weights to it then spin it again, it WILL wobble.
Feb 22, 2014 | GE G.e. Gtwn4950lws He Top Load Washer
Kenmore 500 bangs when spinning
Sounds like the bearing in the drum has bust but shouldnt be too expensive to replace.
Nov 19, 2013 | Kenmore 24902 Top Load Washer
Kenmore washer started making banging noise in last spain cycle. Now unable to spinn drum by hand.
Having same problem with my Kenmore 500. Tomorrow will be the second time a repair man has visited the house. Washer on 5 weeks old. Drum bangs every other load. Load not unbalanced. Avoid this washer, it is a POS.
Mar 20, 2010 | Kenmore 24902 Top Load Washer
Loose drum bangs during spin cycle turn by hand with nothing in drum and still bangs?
your front drum support blocks have failed. remove the tub and, replace or, rebolt them in place so they hold the drum front in place.
Jan 25, 2010 | Frigidaire 14 Cycle Tumble Action Washer
Loud banging
Several possibilities for noise. check concrete balance wieghts at top and bottom of washer, make sure they are not loose.
Check drum restraint spring(s) are not broken.
Check suspension legs for wear.
Check for loose motor fixings.
Finally, remove drum belt, and spin drum by hand, tjhere should be noise from bearings, if it feels rough or is rumbling , then main bearings have failed.
Please rate my comments.
Thanks.
Jul 27, 2009 | Hotpoint Aquarius WD63 Front Load...
Wd10 indesit washer banging
It could be the drum bearings. If you can move the drum up and down, the bearings is worn. It could also be the balanceweight that sits on the top of the outer tub that have gone loose. It's usually made of cement, or cast iron.
Jan 23, 2008 | Indesit W 123 Front Load Washer
GE GTWN4250DWS Logo
96 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
