Question about GE Microwave Ovens
Ounces to grams
Is it possible to change the auto-defrost from ounces to grams? GE over the range Microwave, model JVM1540
    Scholar:
  • 178 Answers
I don't believe that you can set this unit to grams but there are 28.4 grams in an ounce..... hope this helps.....
Posted on Nov 20, 2013
  • Lori Russell
    Lori Russell Nov 20, 2013
    Yeah the show that in the manual. This was sold in Canada, t sure why it has only imperial measurement. All our meat, etc. is shown in grams.
  • Lori Russell
    Our old panasonic could changed by unplugging and pressing start when plugged in again.
  • 833 Answers
SOURCE: gap between cabinet and top of microwave oven
eastlake...only if you think so. Most of these units use a submounting bracket set and then you hook your oven to it. This is a rather nasty installation...I've done several. If it's sturdy, you may just want to put in a filler piece.
Posted on Dec 13, 2007
mikedem7
  • 25 Answers
SOURCE: Removing an old old microwave oven
look in the cabinet above the microwave, there should be 2 bolts which go through the bottom of the cabinet and screw into the microwave. remove these 2 bolts holding the unit steady then tilt the unit down and away from the wall.
Posted on Aug 19, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: how to change the bulb in a jes1288sh02 ge microwave oven
You'll need to remove the outer cover (wrapper) to get to the bulb.
Always unplug a microwave before removing or installing any bulbs.
See these links before proceeding:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
You can find an exploded view showing the the lamp assembly (location refer# 280) here.
You can order the lamp assembly by entering your full model number here. It is part # WB36X951.
Posted on Jan 18, 2009
  • 4 Answers
SOURCE: need help selecting proper charcoal filter
It's Part No. WB06X10359.
Posted on Jul 18, 2009
Richie_asg1
  • 1036 Answers
SOURCE: GE JVM1540 keypad only works for some buttons
Membrane keypads are not very durable, and do fail after a relatively short time.
The only method is to replace them as a spare part.
Posted on Aug 20, 2009
The glass turntable broke. Where can I find a replacement?
Go to www.ebay.com Type: make and model of microwave, and refine search to glass plate.
Apr 02, 2012 | GE Spacemaker JVM1540 Microwave Oven
The GE Spacemaker Microwave Oven model JVM1540 noise
The problem is more than likely the magnetron when it is running.
Mar 13, 2012 | GE Spacemaker JVM1540 Microwave Oven
My GE JVM1540 microwave appears to run but it won't heat. The lights and turntable work but it does not heat at all.
you will have to replace the microwave, sounds like a burned out magnetron, replacing the magnetron is almost as expencive as a new oven...
May 05, 2011 | GE Spacemaker JVM1540 Microwave Oven
We have a GE JVM1540 space saver microwave. It is less than a year old. Will not heat and immediately starts smelling like burning plastic. Any ideas as to what is causing that?
CHECK THE MICROWAVE MANUAL LOOK FOR FACTORY WARRANTY ,MUST BE A BAD COMPONENT ,IF YOU MICROWAVE IS UNDER 1 YEAR WARRANTY THE FACTORY WILL REPAIR IT AT NOT COST TO YOU..CONTACT GE FACTORY.
Feb 18, 2011 | GE Spacemaker JVM1540 Microwave Oven
Have a Chefmate digital stainless steel scale. It weighs in grams and ounces. It was changed accidently to grams but I want it in ounces. Not sure how to do it and misplaced owner's manual.
Easy! On my Chefmate scale what I have to do is toggle so that "weight" is blinking. Then hit "0" - that is zero. Now you can change back and forth from grams to oz!
Jun 25, 2010 | Microwave Ovens
Where do you install the charcoal filter on spacemaker microwave oven model # jvm1540
remove the two and 3 maybe in the air grill at top of oven . behind inthe center is the filter . ( very pricey // about 60.00 / the make sure it seated properly so the air flow is through filter .. replace front grill and your done .. ****
Jan 09, 2010 | GE Spacemaker JVM1540 Microwave Oven
JVM1540 Above the oven microwave is not heating anymore
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
gfgf
Dec 15, 2009 | GE Spacemaker JVM1540 Microwave Oven
Aug 20, 2009 | GE Spacemaker JVM1540 Microwave Oven
Microwave Ovens Logo
44 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
