Question about Dacor Epicure EF48NBSS Stainless Steel (297 cu ft) Side by Side Refrigerator
How do you raise the temp for the fridge, food consistently freezes, button raises reading to 45, then drops back to 29 instantly.
    Champion:
    Habit-Forming:
  • 279 Answers
A real problem, if your fridge continues to show 29f (-1.6c) then everything will obviously freeze, I know this sounds silly but you are trying to turn the temp up on the food compartment & not the freezer? Just a thought. If not please call the service centre @ http://www.dacor.com
Posted on Nov 21, 2013
Refrigerator section is freezing food
raise the thermostat setting to 4
replace the faulty thermostat
Nov 09, 2017 | Daewoo Refrigerators
Fridge freezes food, can't increase temperature setting with up arrow, can you help?
I have a problem with my Dacor fridge, do you still have a problem with your unit? If not what solved it? Bob 3104023794
Nov 20, 2013 | Dacor Epicure EF48NBSS Stainless Steel...
Hi i am having samsung fridge cooltsech plus silver nano i have a prob;em in my fridge that in winter the cooling in the refrigerator is very sytrong i have increased the temperatire to 7 degress which is...
If your veg is freezing you need to RAISE the temp in the fridge,if #7 is coldest,then #1 is warmest.SET IT TO #3.You should keep a fridge at +5C for best storage of CHILLED food.you should also adjust your fridge for summer and winter ambient temperatures.a fridge/FREEZER thermometer is ESSENTIAL.OTHERWISE YOUR WASTING MONEY/ENERGY.
Nov 12, 2010 | Samsung CoolTech Plus / Basic Bottom Mount...
Refrigerator is freezing my milk juice and everything. the manual says to lower the number Dont they mean to raise the number.
NO 1 is the warmest with 10(?)the coldest.best get a thermometer for the fridge and try to keep it at +5C,the most economical temp for chilled food.
Sep 16, 2010 | Kenmore Refrigerators
Idesit BAAN134 PSUK fridge keeps freezing food . The fridge part of my tower f/f keeps freezing food even though I have turned the dial down to the minimum the temperature regularly drops to below...
If it is an electronic thermostat it could be that the engineer has changed the board but not the sensor which reads the temp. If it is a mechanical thermostat it may be hes fitted the wrong type.It could also be that the system is short of refrigerant and the actual refrigerant charge is not getting all the way to the thermoststs sensor to switch it off, the back wall of the fridge should be frosted at least 3/4 of the way down and not just forming in a small part of the fridge.
Jan 05, 2010 | Refrigerators
VEGETABLES FREEZING IN LOWER LEFT DRAWER. I have an LG model LFX25960. If I raise the temp to 45 in the refrigerator it will be 34 in that drawer but that also makes the rest of the refrigerator too low a...
Hello, This problem is going to be the cold control, this can be located in the control panel inside the fridge. This part is also called the thermostat. What is happening here is it has opened and the freezer is getting to cold which is making the fridge too cold. This is why the food in your fridge is freezing. You should replace the cold control and you will be all set. Mike
Nov 07, 2009 | LG Refrigerators
Top mounted freezer on refrigerator not working
Move the refrigerator to a room that is at least 50 degrees F.
Temps on most refrigerators are regulated by the fresh foods temp. If your garage is let's say 35 degrees, the fresh foods temp will most likely never raise enough to turn the refrigerator on. With the refrigerator never running, the freezer compartment will warm to 35 degrees, resulting in everything melting. Even if garage is a bit warmer, say 45, the refrig will not run long enough for the freezer to maintain a low enough temperture. If the garage temp falls to below freezing, say 20 degrees, the food in the fresh foods compartment will freeze. (outdoor beverage dispensers have internal heaters to prevent product from freezing !) Please don't rate this if not a Fix-Ya for you, as anything else lowers my score.
Jan 22, 2009 | Frigidaire 5 cu. ft. / 142 liter Chest...
GE PFS22SISBSS Refrig compatment freezing
There is an internal door between the fridge and freezer section that allows the freezer air to enter the fridge side to keep the fridge cold. Sounds like the internal door is stuck open. Steve
Dec 21, 2008 | GE Profile PFS22 33" Artica French Door...
GE Profile fresh food getting TOO cold
Faulty air damper is the usual cause , or possible sensor fault
Sep 14, 2007 | GE PSS25NGM Side by Side Refrigerator
Dacor Epicure EF48NBSS Stainless Steel (297 cu ft) Side by Side Refrigerator Logo
71 people viewed this question
Top Dacor Refrigerators Experts
Charles T Nevin
Charles T Nevin
Brian Coughlan
Are you a Dacor Refrigerator Expert? Answer questions, earn points and help others
